    [Plugin] bim-tools 0.13.4(june 22, 2015)
    206 Posts 37 Posters 263.6k Views 37 Watching
    • U
      unclex
      a “thin” Face,not even Thicken it
      Others just like you said
      And not crash everytime,just sometime, so no example file.....
      • tt_suT
        tt_su
        When you experience a crash, do you submit the BugSplat?
        Please do so, and fill in some information and let us know so we can look it up.
        • brewskyB
          brewsky
          New version 😄
          Should be a bit faster!
          still a bit experimental, needs some more testing but seems to work OK
          I also took the time to update the source on google-code...
          https://code.google.com/p/bim-tools/source/browse/
          Please let me know if you find any issues(or ideas for improvement)!
          Cheers!
          Jan
          Experimental version for SU2014
          Sketchup BIM-Tools - http://sketchucation.com/forums/viewtopic.php?p=299107
          • brewskyB
            brewsky
            @leolouie said:
            Any plans on releasing a version for Sketchup 2014? I miss not be able to use this tool.
            Great to hear that you like using it! 😄
            I fixed a few basic errors a few months ago but didn't get around to figure out why it's so much slower than on previous versions. All functionality seems to be working though.
            I've been working on some side-projects "lately", but if people like using it, than it needs a higher place on my list of priorities 😉
            Maybe you can give it a try and let me know your experiences? any feature requests? bugs?
            Check out the attachment!
            [removed in favor of new version]
              markitekt
              Great plugin. Lots of potential. How about imperial units?
              • brewskyB
                brewsky
                Thank you! 😄
                I have been thinking about adding imperial units, but until now has not been very high on my list of priorities. I will look into it.
                Any more votes for this?
                • jemagnussenJ
                  jemagnussen
                  Any chance this will work in 2015 Pro...?
                  Best regards
                  Jesper
                  HP ZBook 15, Windows 10 64 bit
                  Intel Core i7-6820HQ @ 2.70GHz
                  32 GB Ram
                  NVIDIA Quadro M2000M
                  • U
                    unclex
                    We Need U, Jesper
                    • brewskyB
                      brewsky
                      Sorry for the late reply 😳
                      The latest version for 2014 seems to work fine on SU2015, but I didn't get around to make it an "official" version yet so it got a bit lost within the thread(posted on 4 aug. 2014).
                      I will try to update the main-post with the latest version tomorrow.
                      • gudio83G
                        gudio83
                        @didier bur said:
                        Just a side note: to install, create a folder "bimtools" in the Plugins folder, and put the html file in it.
                        where is the html file?
                        the plugin create bim-tools, so i have to add bimtools, right?
                        • brewskyB
                          brewsky
                          Do you have trouble installing? I think this tip is rather outdated by now.
                          The easiest way to install is through the Sketchucation Plugin Store (Search on author: "Jan Brouwer"):
                          http://sketchucation.com/plugin-store-free-download
                          You can also rename the download from bim-tools-0.12.4.zip to bim-tools-0.12.4.rbz.
                          Then it can be installed thtough: Window --> Preferences --> Extensions
                          I will use that filetype as the default for the next version...
                          • brewskyB
                            brewsky
                            New version online! Finally support for imperial units 😄
                            • U
                              unclex
                              0.12.4 work fine
                              but 13.0 cannot work like 12.4 @su2015x64pro
                              such as several box could be converted to wall&floor by just one click using 12.4
                              but 13.0, some faces cannot be converted
                              • brewskyB
                                brewsky
                                @unclex said:
                                0.12.4 work fine
                                Can you send me an example model (PM?), then I'll check it out.
                                In my own tests the new 0.13.0 worked on more faces than 0.12.4, so I'm curious... 😄
                                Thanks for posting the issue!
                                • U
                                  unclex
                                  Now I Know What Happened
                                  12.4 can work under customized catalogue, 13.0 not
                                  and 13.0, if you have cleaned bim information, you must run SU again, Using File→New could not worked, isn't ?
                                  BimToolBoxTest.7z
                                  • brewskyB
                                    brewsky
                                    Thanks! You're probably right, I also had some trouble changing between models without restarting SU a couple of weeks ago, I thought I fixed that. I will check it out!
                                    • brewskyB
                                      brewsky
                                      Okay, I completely uprooted the observers that keep track of the active entities, and it seems much more solid now 😄
                                      Can you give it a try before I upload it into the PluginStore?
                                      • brewskyB
                                        brewsky
                                        New version 0.13.2 online!
                                        Feels much more solid due to improved observers 😄
                                        • T
                                          twillm
                                          Is bim-tools compatible with mac version of sketchup 2015.
                                          I attempted to install using sketchucation plugin store v2.6.1
                                          Received error messageError Loading File /Users/trevormeakin/Library/Application Support/SketchUp 2015/SketchUp/Plugins/bim-tools/bim-tools_loader.rb
                                          Error: #<NoMethodError: undefined method strip' for nil:NilClass> /Users/trevormeakin/Library/Application Support/SketchUp 2015/SketchUp/Plugins/bim-tools/lib/clsDefaultValues.rb:40:in block in parse_config'
                                          /Users/trevormeakin/Library/Application Support/SketchUp 2015/SketchUp/Plugins/bim-tools/lib/clsDefaultValues.rb:34:in each_line' /Users/trevormeakin/Library/Application Support/SketchUp 2015/SketchUp/Plugins/bim-tools/lib/clsDefaultValues.rb:34:in parse_config'
                                          /Users/trevormeakin/Library/Application Support/SketchUp 2015/SketchUp/Plugins/bim-tools/lib/clsDefaultValues.rb:23:in initialize' /Users/trevormeakin/Library/Application Support/SketchUp 2015/SketchUp/Plugins/bim-tools/clsBtProject.rb:43:in new'
                                          /Users/trevormeakin/Library/Application Support/SketchUp 2015/SketchUp/Plugins/bim-tools/clsBtProject.rb:43:in initialize' /Users/trevormeakin/Library/Application Support/SketchUp 2015/SketchUp/Plugins/bim-tools/bim-tools_loader.rb:44:in new'
                                          /Users/trevormeakin/Library/Application Support/SketchUp 2015/SketchUp/Plugins/bim-tools/bim-tools_loader.rb:44:in <module:BimTools>' /Users/trevormeakin/Library/Application Support/SketchUp 2015/SketchUp/Plugins/bim-tools/bim-tools_loader.rb:19:in module:Brewsky'
                                          /Users/trevormeakin/Library/Application Support/SketchUp 2015/SketchUp/Plugins/bim-tools/bim-tools_loader.rb:18:in <top (required)>' /Applications/SketchUp 2015/SketchUp.app/Contents/Resources/Content/Tools/extensions.rb:197:in require'
                                          /Applications/SketchUp 2015/SketchUp.app/Contents/Resources/Content/Tools/extensions.rb:197:in load' /Users/trevormeakin/Library/Application Support/SketchUp 2015/SketchUp/Plugins/bim-tools.rb:48:in register_extension'
                                          /Users/trevormeakin/Library/Application Support/SketchUp 2015/SketchUp/Plugins/bim-tools.rb:48:in <module:BimTools>' /Users/trevormeakin/Library/Application Support/SketchUp 2015/SketchUp/Plugins/bim-tools.rb:35:in module:Brewsky'
                                          /Users/trevormeakin/Library/Application Support/SketchUp 2015/SketchUp/Plugins/bim-tools.rb:31:in `<top (required)>'
                                          Any suggestions would be most welcome
                                          • brewskyB
                                            brewsky
                                            Thanks for posting this issue!
                                            I believe it used to work on Mac, but have never been able to test it myself.
                                            I will try to borrow a Mac and check it out 😉
                                            The error is related to reading the config file, did you by any chance modify that file?
                                            • 11
                                            • 9 / 11
