    [Plugin] bim-tools 0.13.4(june 22, 2015)
    206 Posts 37 Posters 247.1k Views 37 Watching
    • U Offline
      unclex
      a little bug
      make COMP in the any face,then copy the COMP, sometimes crashed the SU2014
      • brewskyB Offline
        brewsky
        @unclex said:
        a little bug
        Thanks for reporting this.
        Do you mean that it crashes(sometimes) when you:
        • create a "thick face"(wall) with my plugin
        • then draw a square(for example) on the face.
        • select the square and it's edges
        • make component, select "glue to any" and "cut opening" and "replace selection"
        • copy the new component within the same face
          I have not yet been able to reproduce the error, can you send me an example file that crashes?
        Sketchup BIM-Tools - http://sketchucation.com/forums/viewtopic.php?p=299107
        • U Offline
          unclex
          a “thin” Face,not even Thicken it
          Others just like you said
          And not crash everytime,just sometime, so no example file.....
          • tt_suT Offline
            tt_su
            When you experience a crash, do you submit the BugSplat?
            Please do so, and fill in some information and let us know so we can look it up.
            • brewskyB Offline
              brewsky
              New version 😄
              Should be a bit faster!
              still a bit experimental, needs some more testing but seems to work OK
              I also took the time to update the source on google-code...
              https://code.google.com/p/bim-tools/source/browse/
              Please let me know if you find any issues(or ideas for improvement)!
              Cheers!
              Jan
              Experimental version for SU2014
              • brewskyB Offline
                brewsky
                @leolouie said:
                Any plans on releasing a version for Sketchup 2014? I miss not be able to use this tool.
                Great to hear that you like using it! 😄
                I fixed a few basic errors a few months ago but didn't get around to figure out why it's so much slower than on previous versions. All functionality seems to be working though.
                I've been working on some side-projects "lately", but if people like using it, than it needs a higher place on my list of priorities 😉
                Maybe you can give it a try and let me know your experiences? any feature requests? bugs?
                Check out the attachment!
                [removed in favor of new version]
                  markitekt
                  Great plugin. Lots of potential. How about imperial units?
                  • brewskyB Offline
                    brewsky
                    Thank you! 😄
                    I have been thinking about adding imperial units, but until now has not been very high on my list of priorities. I will look into it.
                    Any more votes for this?
                    • jemagnussenJ Offline
                      jemagnussen
                      Any chance this will work in 2015 Pro...?
                      Best regards
                      Jesper
                      HP ZBook 15, Windows 10 64 bit
                      Intel Core i7-6820HQ @ 2.70GHz
                      32 GB Ram
                      NVIDIA Quadro M2000M
                      • U Offline
                        unclex
                        We Need U, Jesper
                        • brewskyB Offline
                          brewsky
                          Sorry for the late reply 😳
                          The latest version for 2014 seems to work fine on SU2015, but I didn't get around to make it an "official" version yet so it got a bit lost within the thread(posted on 4 aug. 2014).
                          I will try to update the main-post with the latest version tomorrow.
                          • gudio83G Offline
                            gudio83
                            @didier bur said:
                            Just a side note: to install, create a folder "bimtools" in the Plugins folder, and put the html file in it.
                            where is the html file?
                            the plugin create bim-tools, so i have to add bimtools, right?
                            • brewskyB Offline
                              brewsky
                              Do you have trouble installing? I think this tip is rather outdated by now.
                              The easiest way to install is through the Sketchucation Plugin Store (Search on author: "Jan Brouwer"):
                              http://sketchucation.com/plugin-store-free-download
                              You can also rename the download from bim-tools-0.12.4.zip to bim-tools-0.12.4.rbz.
                              Then it can be installed thtough: Window --> Preferences --> Extensions
                              I will use that filetype as the default for the next version...
                              • brewskyB Offline
                                brewsky
                                New version online! Finally support for imperial units 😄
                                • U Offline
                                  unclex
                                  0.12.4 work fine
                                  but 13.0 cannot work like 12.4 @su2015x64pro
                                  such as several box could be converted to wall&floor by just one click using 12.4
                                  but 13.0, some faces cannot be converted
                                  • brewskyB Offline
                                    brewsky
                                    @unclex said:
                                    0.12.4 work fine
                                    Can you send me an example model (PM?), then I'll check it out.
                                    In my own tests the new 0.13.0 worked on more faces than 0.12.4, so I'm curious... 😄
                                    Thanks for posting the issue!
                                    • U Offline
                                      unclex
                                      Now I Know What Happened
                                      12.4 can work under customized catalogue, 13.0 not
                                      and 13.0, if you have cleaned bim information, you must run SU again, Using File→New could not worked, isn't ?
                                      BimToolBoxTest.7z
                                      • brewskyB Offline
                                        brewsky
                                        Thanks! You're probably right, I also had some trouble changing between models without restarting SU a couple of weeks ago, I thought I fixed that. I will check it out!
                                        • brewskyB Offline
                                          brewsky
                                          Okay, I completely uprooted the observers that keep track of the active entities, and it seems much more solid now 😄
                                          Can you give it a try before I upload it into the PluginStore?
                                          • brewskyB Offline
                                            brewsky
                                            New version 0.13.2 online!
                                            Feels much more solid due to improved observers 😄
                                            • 11
                                            • 9 / 11
