    [Plugin] bim-tools 0.13.4(june 22, 2015)
    206 Posts 37 Posters 263.6k Views 37 Watching
    • brewskyB
      brewsky
      @ludnid said:
      Removing the recent installations found bim tools to be the culprit 😄. Does anyone have the same problem?
      I have changed a few things in an attempt to prevent the crashes you experienced.
      I have added a new button that enables/disables all observers(which I believe to be the problem).
      I hope you can try this new version(0.12.2) to see if it's fixed, especially when you put it in "manual-mode"(top-left button=red).
      And thanks for reporting the problem!
      Sketchup BIM-Tools - http://sketchucation.com/forums/viewtopic.php?p=299107
      • brewskyB
        brewsky
        @ivreich said:
        I've tried many times to create self-cutting components, but it never ever works.
        The most simple example to see it work is to draw a big square face(this is the "wall") and inside draw a small square(the "window").
        Then select the window-face including it's edges, then right-click --> make component. Now all the options for a cutting component are set automatically(because the face is actually already "cutting").
        If you remove the window-face(keep the outer edges, they will cut the hole!), now if you close the component you should have a hole in the wall!
        • I
          ikun
          Thanks for your work!! It's awesome!
          • JQLJ
            JQL
            Brewaky,
            It's been a while since I test your plugin. It has improved a lot! The interface is looking good and uncluttered and seems practical. However the plugin does not seem to fit to real use yet.
            Are you still aiming at that or have you stopped developing it?
            The things I find difficult to handle are the following:
            • The plugin is great in defining thickness for any kind of geometry I throw at it. This for itself would be a great addition to Sketchup if only the remove BIM Properties button would do that. The problem is that, when I remove those properties, somethings still remain there and mess with the model later. Sometimes it creates a bugsplat, sometimes it shows new geometry. Would it be possible to remove everything and keep only the groups the plugin created?
            • Sometimes when changing wall thickness Sketchup simply crashes;
            • When one applies different materials to the inner and outer faces, they disappear if you insert a window or redefine thickness;
            • When inserting a window it correctly creates the opening with thickness. However if one wants to define a different opening inside and outside, the best way to do that would be by inserting the opening in the inner wall in a process similar as the one shown in the next link:
            404 Not Found
            (sketchucation.com)
            The problem is, if you insert any kind of component on the inner wall, it will soon disappear in the workflow and lead to a bugsplat in the long run.
            If you want I can submit you some models for examples of what I am trying to tell you about.
            Keep up the good work!
            www.casca.pt
            Visit us on facebook!
            • brewskyB
              brewsky
              Yeah, I'm still working on it! 😄 Thanks for taking the time to point these things out.
              I got a bit sidetracked for the last... couple of months I guess. 😕 I have been working on a very cool new feature, but I can't get it to work the way I want yet.
              I will do some tests on the remove BIM properties button. I didn't notice it's leaving properties behind, and it should not be hard to fix this.
              I have been thinking about this myself too, it would be a useful option to "just" generate geometry. If you(or someone else) have a good suggestion on how to add this to the interface without making it too cluttered or complicated I will add this. I could for example make a pop-up that makes you choose what properties to remove, but I am reluctant to add too many steps to the process.
              I'm aware of this and this is probably the biggest problem at this moment. It makes the plugin difficult to use. I added the option to disable automatic updating of geometry(mostly to prevent it from interfering with other plugins). When this is disabled I get no crashes, If you do, please let me know!
              The downside is then you have to update every object manually, and I think the most fun thing of the plugin is that it automatically updates the geometry after modifying the source-faces.
              The observers I have used for this still seem to cause bugsplats, although much less frequently as they did at first. I will have to work around these observers but that may make editing less "smooth".
              I will have to test this, I will come back to you on this one.
                http://sketchucation.com/resources/tutorials/36-intermediate/321-window-cut-hole-thick-wall
              I think the new feature I have been working on would be great to solve this, but this will take some more time because I intend to pick up the problems you have pointed out first.
              I let you know if I have trouble re-creating the errors!
              Is there anyone out there using this plugin for creating IFC-files? That's what I have been mostly using it for lately, I can create shapes with it that are not easy in our CAD/BIM-software...
              I have also been working on a connection with THE BIM server 😄 (http://bimserver.org), I was wondering if anyone is interested in that...
              • brewskyB
                brewsky
                What about(for now) putting the profiled wall "caps" into the cutting window component? I know it does not(yet) hide the lines where the profile meets the wall, but that's something I could easily fix.
                Check out the attached image and demo file(I roughly borrowed the window shape from ThomThom, because it nicely illustrates a complex profile).
                window.pngwindow.skp
                I'm unable to reproduce this one, and also have not yet been able to crash SketchUp, but I will try some more(and bigger) models.
                Yes, I do like to see these models! Might make reproducing the errors easier.
                I did notice another bug.
                Sometimes when I create a new model without closing SketchUp first, newly created walls are not seen by the plugin(and so cannot be modified from the plugin).
                I will figure out where this comes from...
                • JQLJ
                  JQL
                  Sorry Brewsky, I haven't had time to test your plugin further, as I promised, but I'm going to do that ASAP.
                  www.casca.pt
                  • leolouieL
                    leolouie
                    Any plans on releasing a version for Sketchup 2014? I miss not be able to use this tool.
                    • U
                      unclex
                      Push for 2014~~~~~~~~~~~~
                      • U
                        unclex
                        a little bug
                        make COMP in the any face,then copy the COMP, sometimes crashed the SU2014
                        • brewskyB
                          brewsky
                          @unclex said:
                          a little bug
                          Thanks for reporting this.
                          Do you mean that it crashes(sometimes) when you:
                          • create a "thick face"(wall) with my plugin
                          • then draw a square(for example) on the face.
                          • select the square and it's edges
                          • make component, select "glue to any" and "cut opening" and "replace selection"
                          • copy the new component within the same face
                            I have not yet been able to reproduce the error, can you send me an example file that crashes?
                          • U
                            unclex
                            a “thin” Face,not even Thicken it
                            Others just like you said
                            And not crash everytime,just sometime, so no example file.....
                            • tt_suT
                              tt_su
                              When you experience a crash, do you submit the BugSplat?
                              Please do so, and fill in some information and let us know so we can look it up.
                              • brewskyB
                                brewsky
                                New version 😄
                                Should be a bit faster!
                                still a bit experimental, needs some more testing but seems to work OK
                                I also took the time to update the source on google-code...
                                https://code.google.com/p/bim-tools/source/browse/
                                Please let me know if you find any issues(or ideas for improvement)!
                                Cheers!
                                Jan
                                Experimental version for SU2014
                                • brewskyB
                                  brewsky
                                  Great to hear that you like using it! 😄
                                  I fixed a few basic errors a few months ago but didn't get around to figure out why it's so much slower than on previous versions. All functionality seems to be working though.
                                  I've been working on some side-projects "lately", but if people like using it, than it needs a higher place on my list of priorities 😉
                                  Maybe you can give it a try and let me know your experiences? any feature requests? bugs?
                                  Check out the attachment!
                                  [removed in favor of new version]
                                    markitekt
                                    Great plugin. Lots of potential. How about imperial units?
                                    • brewskyB
                                      brewsky
                                      Thank you! 😄
                                      I have been thinking about adding imperial units, but until now has not been very high on my list of priorities. I will look into it.
                                      Any more votes for this?
                                      • jemagnussenJ
                                        jemagnussen
                                        Any chance this will work in 2015 Pro...?
                                        Best regards
                                        Jesper
                                        HP ZBook 15, Windows 10 64 bit
                                        Intel Core i7-6820HQ @ 2.70GHz
                                        32 GB Ram
                                        NVIDIA Quadro M2000M
                                        • U
                                          unclex
                                          We Need U, Jesper
                                          • brewskyB
                                            brewsky
                                            Sorry for the late reply 😳
                                            The latest version for 2014 seems to work fine on SU2015, but I didn't get around to make it an "official" version yet so it got a bit lost within the thread(posted on 4 aug. 2014).
                                            I will try to update the main-post with the latest version tomorrow.
                                            • 11
                                            • 9 / 11
