    [Plugin] bim-tools 0.13.4(june 22, 2015)
    206 Posts 37 Posters 253.8k Views 37 Watching
    • leolouieL Offline
      leolouie
      Any plans on releasing a version for Sketchup 2014? I miss not be able to use this tool.
      • U Offline
        unclex
        Push for 2014~~~~~~~~~~~~
        • U Offline
          unclex
          a little bug
          make COMP in the any face,then copy the COMP, sometimes crashed the SU2014
          • brewskyB Offline
            brewsky
            @unclex said:
            a little bug
            Thanks for reporting this.
            Do you mean that it crashes(sometimes) when you:
            • create a "thick face"(wall) with my plugin
            • then draw a square(for example) on the face.
            • select the square and it's edges
            • make component, select "glue to any" and "cut opening" and "replace selection"
            • copy the new component within the same face
              I have not yet been able to reproduce the error, can you send me an example file that crashes?
            Sketchup BIM-Tools - http://sketchucation.com/forums/viewtopic.php?p=299107
            • U Offline
              unclex
              a “thin” Face,not even Thicken it
              Others just like you said
              And not crash everytime,just sometime, so no example file.....
              • tt_suT Offline
                tt_su
                When you experience a crash, do you submit the BugSplat?
                Please do so, and fill in some information and let us know so we can look it up.
                • brewskyB Offline
                  brewsky
                  New version 😄
                  Should be a bit faster!
                  still a bit experimental, needs some more testing but seems to work OK
                  I also took the time to update the source on google-code...
                  https://code.google.com/p/bim-tools/source/browse/
                  Please let me know if you find any issues(or ideas for improvement)!
                  Cheers!
                  Jan
                  Experimental version for SU2014
                  • brewskyB Offline
                    brewsky
                    Great to hear that you like using it! 😄
                    I fixed a few basic errors a few months ago but didn't get around to figure out why it's so much slower than on previous versions. All functionality seems to be working though.
                    I've been working on some side-projects "lately", but if people like using it, than it needs a higher place on my list of priorities 😉
                    Maybe you can give it a try and let me know your experiences? any feature requests? bugs?
                    Check out the attachment!
                    [removed in favor of new version]
                      markitekt
                      Great plugin. Lots of potential. How about imperial units?
                      • brewskyB Offline
                        brewsky
                        Thank you! 😄
                        I have been thinking about adding imperial units, but until now has not been very high on my list of priorities. I will look into it.
                        Any more votes for this?
                        • jemagnussenJ Offline
                          jemagnussen
                          Any chance this will work in 2015 Pro...?
                          Best regards
                          Jesper
                          HP ZBook 15, Windows 10 64 bit
                          Intel Core i7-6820HQ @ 2.70GHz
                          32 GB Ram
                          NVIDIA Quadro M2000M
                          • U Offline
                            unclex
                            We Need U, Jesper
                            • brewskyB Offline
                              brewsky
                              Sorry for the late reply 😳
                              The latest version for 2014 seems to work fine on SU2015, but I didn't get around to make it an "official" version yet so it got a bit lost within the thread(posted on 4 aug. 2014).
                              I will try to update the main-post with the latest version tomorrow.
                              • gudio83G Offline
                                gudio83
                                @didier bur said:
                                Just a side note: to install, create a folder "bimtools" in the Plugins folder, and put the html file in it.
                                where is the html file?
                                the plugin create bim-tools, so i have to add bimtools, right?
                                • brewskyB Offline
                                  brewsky
                                  Do you have trouble installing? I think this tip is rather outdated by now.
                                  The easiest way to install is through the Sketchucation Plugin Store (Search on author: "Jan Brouwer"):
                                  http://sketchucation.com/plugin-store-free-download
                                  You can also rename the download from bim-tools-0.12.4.zip to bim-tools-0.12.4.rbz.
                                  Then it can be installed thtough: Window --> Preferences --> Extensions
                                  I will use that filetype as the default for the next version...
                                  • brewskyB Offline
                                    brewsky
                                    New version online! Finally support for imperial units 😄
                                    • U Offline
                                      unclex
                                      0.12.4 work fine
                                      but 13.0 cannot work like 12.4 @su2015x64pro
                                      such as several box could be converted to wall&floor by just one click using 12.4
                                      but 13.0, some faces cannot be converted
                                      • brewskyB Offline
                                        brewsky
                                        @unclex said:
                                        0.12.4 work fine
                                        Can you send me an example model (PM?), then I'll check it out.
                                        In my own tests the new 0.13.0 worked on more faces than 0.12.4, so I'm curious... 😄
                                        Thanks for posting the issue!
                                        • U Offline
                                          unclex
                                          Now I Know What Happened
                                          12.4 can work under customized catalogue, 13.0 not
                                          and 13.0, if you have cleaned bim information, you must run SU again, Using File→New could not worked, isn't ?
                                          BimToolBoxTest.7z
                                          • brewskyB Offline
                                            brewsky
                                            Thanks! You're probably right, I also had some trouble changing between models without restarting SU a couple of weeks ago, I thought I fixed that. I will check it out!
                                            • 11
                                            • 9 / 11
