    [Plugin] bim-tools 0.13.4(june 22, 2015)
    206 Posts 37 Posters 255.0k Views 37 Watching
    • JQLJ Offline
      JQL
      Sorry Brewsky, I haven't had time to test your plugin further, as I promised, but I'm going to do that ASAP.
      www.casca.pt
      Visit us on facebook!
      • leolouieL Offline
        leolouie
        Any plans on releasing a version for Sketchup 2014? I miss not be able to use this tool.
        • U Offline
          unclex
          Push for 2014~~~~~~~~~~~~
          • U Offline
            unclex
            a little bug
            make COMP in the any face,then copy the COMP, sometimes crashed the SU2014
            • brewskyB Offline
              brewsky
              @unclex said:
              a little bug
              Thanks for reporting this.
              Do you mean that it crashes(sometimes) when you:
              • create a "thick face"(wall) with my plugin
              • then draw a square(for example) on the face.
              • select the square and it's edges
              • make component, select "glue to any" and "cut opening" and "replace selection"
              • copy the new component within the same face
                I have not yet been able to reproduce the error, can you send me an example file that crashes?
              Sketchup BIM-Tools - http://sketchucation.com/forums/viewtopic.php?p=299107
              • U Offline
                unclex
                a “thin” Face,not even Thicken it
                Others just like you said
                And not crash everytime,just sometime, so no example file.....
                • tt_suT Offline
                  tt_su
                  When you experience a crash, do you submit the BugSplat?
                  Please do so, and fill in some information and let us know so we can look it up.
                  • brewskyB Offline
                    brewsky
                    New version 😄
                    Should be a bit faster!
                    still a bit experimental, needs some more testing but seems to work OK
                    I also took the time to update the source on google-code...
                    https://code.google.com/p/bim-tools/source/browse/
                    Please let me know if you find any issues(or ideas for improvement)!
                    Cheers!
                    Jan
                    Experimental version for SU2014
                    • brewskyB Offline
                      brewsky
                      Great to hear that you like using it! 😄
                      I fixed a few basic errors a few months ago but didn't get around to figure out why it's so much slower than on previous versions. All functionality seems to be working though.
                      I've been working on some side-projects "lately", but if people like using it, than it needs a higher place on my list of priorities 😉
                      Maybe you can give it a try and let me know your experiences? any feature requests? bugs?
                      Check out the attachment!
                      [removed in favor of new version]
                        markitekt
                        Great plugin. Lots of potential. How about imperial units?
                        • brewskyB Offline
                          brewsky
                          Thank you! 😄
                          I have been thinking about adding imperial units, but until now has not been very high on my list of priorities. I will look into it.
                          Any more votes for this?
                          • jemagnussenJ Offline
                            jemagnussen
                            Any chance this will work in 2015 Pro...?
                            Best regards
                            Jesper
                            HP ZBook 15, Windows 10 64 bit
                            Intel Core i7-6820HQ @ 2.70GHz
                            32 GB Ram
                            NVIDIA Quadro M2000M
                            • U Offline
                              unclex
                              We Need U, Jesper
                              • brewskyB Offline
                                brewsky
                                Sorry for the late reply 😳
                                The latest version for 2014 seems to work fine on SU2015, but I didn't get around to make it an "official" version yet so it got a bit lost within the thread(posted on 4 aug. 2014).
                                I will try to update the main-post with the latest version tomorrow.
                                • gudio83G Offline
                                  gudio83
                                  @didier bur said:
                                  Just a side note: to install, create a folder "bimtools" in the Plugins folder, and put the html file in it.
                                  where is the html file?
                                  the plugin create bim-tools, so i have to add bimtools, right?
                                  • brewskyB Offline
                                    brewsky
                                    Do you have trouble installing? I think this tip is rather outdated by now.
                                    The easiest way to install is through the Sketchucation Plugin Store (Search on author: "Jan Brouwer"):
                                    http://sketchucation.com/plugin-store-free-download
                                    You can also rename the download from bim-tools-0.12.4.zip to bim-tools-0.12.4.rbz.
                                    Then it can be installed thtough: Window --> Preferences --> Extensions
                                    I will use that filetype as the default for the next version...
                                    • brewskyB Offline
                                      brewsky
                                      New version online! Finally support for imperial units 😄
                                      • U Offline
                                        unclex
                                        0.12.4 work fine
                                        but 13.0 cannot work like 12.4 @su2015x64pro
                                        such as several box could be converted to wall&floor by just one click using 12.4
                                        but 13.0, some faces cannot be converted
                                        • brewskyB Offline
                                          brewsky
                                          @unclex said:
                                          0.12.4 work fine
                                          Can you send me an example model (PM?), then I'll check it out.
                                          In my own tests the new 0.13.0 worked on more faces than 0.12.4, so I'm curious... 😄
                                          Thanks for posting the issue!
                                          • U Offline
                                            unclex
                                            Now I Know What Happened
                                            12.4 can work under customized catalogue, 13.0 not
                                            and 13.0, if you have cleaned bim information, you must run SU again, Using File→New could not worked, isn't ?
                                            BimToolBoxTest.7z
                                            • 11
                                            • 9 / 11
