    [Plugin] Add Icons [for all SU files on mac]
    47 Posts 8 Posters 13.3k Views 8 Watching
      driven
      @driven said:
      this has been evolving for a long while, but here it is...
      I have now added it to the plugin store...
      [anchor=DOWNLOAD goto=http://sketchucation.com/pluginstore?pln=Add_Icons:2nj0v7ut]DOWNLOAD[/anchor:2nj0v7ut]
      If you have any other versions you should upgrade after a manual 'move to trash' of the older files...
      The manual deletion is required as I changed a lot of the filenames...
      [attachment=0:2nj0v7ut]<!-- ia0 -->batch_icons2.gif<!-- ia0 -->[/attachment:2nj0v7ut]
      please give feedback, so i can put this to bed, before my wife kills me...
      v1.0.2: updated to fix v8 ruby bugs...
      changed the Toggling of windows size to enhance the process...
        http://plugin.sketchucation.com/pluginserv_joomla.php?f=Add_Icons
        [attachment=0:1cyy9qnj]<!-- ia0 -->batch_icons2.gif<!-- ia0 -->[/attachment:1cyy9qnj]
        • gillesG Offline
          gilles
          The symlink is there but no change, error when loading.
          Pm me any version you want to test with SU8. 👍
            driven
            @gilles,
            I got v8 back up and running so the new v1.0.2 in the Plugins Store should now work...
            can you test it to make sure?
            I also have a translation plugin if you want to try it?
              driven
              @gilles said:
              I get this loading SU:
              Error Loading File jcb_Add_Icon.rb
              undefined method `[]' for #<LanguageHandler:0x10ccfca8 @strings={}>
              SU V 8.0.14345
              cheers gilles,
              I recently changed it to use 'langhandler' for translations, but forgot 'langhandler' changed at v14...
              As a test, could you try this from 'Ruby Console'
              EDIT: code is now added to v1.0.2...
              Add Icon should then work...
              • gillesG Offline
                gilles
                @driven said:
                @gilles,
                It does not work.
                inside jcb_Add_Icon.rb I read: add_icons_on_mac.version = '1.0.1'
                  driven
                  @gilles said:
                  ...inside jcb_Add_Icon.rb I read: add_icons_on_mac.version = '1.0.1'
                  oops... I just re-uploaded, and then downloaded the .rbz to check that it is now the 1.0.2 version...
                  sorry about that...
                  • gillesG Offline
                    gilles
                    Sorry,
                    Erreur de chargement du fichier jcb_Add_Icon.rb
                    undefined method `[]' for #<LanguageHandler:0x10bccff4 @strings={}>
                    Don't pull out your hairs. 💚
                      driven
                      @gilles said:
                      Don't pull out your hairs. :mrgreen:
                      I've got quite a lot, and it's working on v8 for me so it's some silly uploading issue...
                      I'll PM my copy
                        greatoe
                        For the latest version 1.0.2, I noticed that a solid white colour is added to the backgound of the icon, and if my SketchUp window is not square, red bars will be added to the top and bottom, or left and right of the icon.
                        The "set window to square" button/function seems not working, I'm on SketchUp 2015 and OS X 10.10.3.
                        I was using an early version of your script, and was pleased with it while it generates icons with transparent background.
                        When I wanted to generate an icon, I use a window management tool (named Window Tidy) to set my SketchUp window to nearly (but not exactly) square to have the best icon result.
                        May I ask for the transparent background back, and get rid of the red bars?
                        The old version I use was running good, but I do like the batch function of adding icons to Layout files and skm file.
                          driven
                          hi
                          I added the 'Red' banding so you can quickly see that a 'better' icon is available by using 'Make Square',
                          I am looking at adding some user preferences that will let you set the band color to any or transparent...
                          but first, get 'Set Square' working is quite critical...
                          It may be a locale issue, do you use 'en-US' for SU or other...
                          if you could run a couple of test's in 'Ruby Console' we can try and work out the issue...
                          use 'Select All' >> Copy >> Paste in 'Rudy Console' >> hit 'Enter/Return'
                              class  Change
                              @plist = (ENV["XPC_SERVICE_NAME"]).split('.')[0..-2].join('.')
                              def self.vpw
                                Sketchup.active_model.active_view.vpwidth
                              def self.vph
                                Sketchup.active_model.active_view.vpheight
                              def self.win_read
                                %x(defaults  read  #{@plist}      "NSWindow Frame SketchUpDoc")
                              def self.frame_read
                                %x(defaults  read  #{@plist}     "Sketchup.MainFrameSize")
                              def self.win_write(arry)
                                %x(defaults  write  #{@plist}      "NSWindow Frame SketchUpDoc" #{arry})
                              def self.frame_write(hash)
                               %x(defaults  write  #{@plist}     "Sketchup.MainFrameSize" -string "#{hash}")
                              def self.su_window
                                win_read.chomp!.split(' ').map{|e| e.to_i}
                              def self.main_frame
                                frame_read.chomp!.gsub(/[\{\}]/, '').split(', ').map{|e| e.to_i}
                              SUD = win_read.dup.chomp!   if not defined? SUD
                              SMF = frame_read.dup.chomp! if not defined? SMF
                              @@revert = false if not defined? SUD
                          type = %x(defaults read com.apple.print.PrintingPrefs DefaultPaperID).chomp!
                          p Sketchup.get_locale
                          p @plist
                          p SUD
                          p SMF
                          p [vpw, vph]
                          p type
                          nil
                          this should return your machines version of this...
                          "en-US" "com.sketchup.SketchUp.2015" "189 651 977 526 0 0 1920 1177 " "{{37, 608}, {977, 569}}" [977, 473] "iso-a4"
                          and hopefully show me what's going wrong...
                          if you can paste that info back here, that a start...
                          I'm working on batch mode at the moment as there are issues with versions other than v2015...
                            greatoe
                            hi john,
                            here's the result:
                            "en-US"
                            "73 40 1810 1137 0 0 1920 1177 "
                            "{{73, 4}, {1810, 1173}}"
                            [3620, 2124]
                            nil
                            ps. I'm on a 15" retina display macbook pro.
                              driven
                              cheers,
                              I think I see the issue, SU shows the 'retina' values but system shows 'traditional' sizes...
                              in yours this two double...
                              [3620, 2124]
                              on mine it stays the same...
                              [977, 473]
                              I need to add a check for retina, and will post a test file...
                                driven
                                what does this return on retina...
                                UI;;WebDialog;;new.screen_scale_factor
                                  greatoe
                                  UI::WebDialog::new.screen_scale_factor
                                  2.0
                                    driven
                                    @greatoe said:
                                    2.0
                                    excellent...
                                    I'll add that inn
                                      driven
                                      if you paste the code block below first, then JcB::SetWindowSize::Change.set_2_square
                                      does it 'go' square?
                                      then up arrow in 'Ruby Console' >> return
                                      does it revert?
                                      =begin
                                      Copyright 2015, john@drivenupthewall.co.uk
                                      All Rights Reserved - for now...
                                      =end
                                      module JcB
                                        module SetWindowSize
                                          class  Change
                                          @scale = UI;;WebDialog;;new.screen_scale_factor.to_f
                                          def self.vpw
                                            Sketchup.active_model.active_view.vpwidth / @scale
                                          def self.vph
                                            Sketchup.active_model.active_view.vpheight / @scale
                                          def self.win_read
                                          def self.frame_read
                                          def self.su_window
                                          def self.main_frame
                                            def self.default_paper
                                             ##'shipped' ratios with a few international paper sizes...
                                             ratios = { 1.0=>'Square', 1.294=>'US Letter', 1.333=>'US Architectural',\
        1.414=>'A Series (ISO 216)', 1.647=>'US Legal'}
                                             if type.include? 'Letter'
                                               ratio = 1.294
                                             elsif type.include? 'Arch'
                                               ratio = 1.333
                                             elsif type.include? 'iso'
                                               ratio = 1.414
                                             elsif type.include? 'Legal'
                                               ratio = 1.647
                                             else
                                                prompts = [($add_icon_strngs["Select your Paper Type"])]
                                                defaults = []
                                                ratios.map{|k,v| defaults << v }
                                                choose = defaults.join(',').gsub(',', '|')
                                                input = UI.inputbox(prompts, [defaults[0]],[choose],  ($add_icon_strngs[" You have no 'default' Printer set "]))
                                                 if input.include? 'Letter'
                                                   ratio = 1.294
                                                 elsif input.include? 'Arch'
                                                   ratio = 1.333
                                                 elsif input.include? 'iso'
                                                   ratio = 1.414
                                                 elsif input.include? 'Legal'
                                                   ratio = 1.647
                                                 else
                                                   ratio = 1
                                             @ratio = ratio
                                            def self.process_window
                                              su_window
                                              sul = su_window[0] # left top corner
                                              suo = su_window[1] # left bottom corner
                                              suw = su_window[2] # width
                                              suh = su_window[3] #
                                              mcl = su_window[4] #
                                              mco = su_window[5] #
                                              mcw = su_window[6] #
                                              mch = su_window[7] #
                                              new_doc = "#{sul} #{suo} #{@new_width} #{suh} #{mcl} #{mco} #{mcw} #{mch}"
                                              main_frame
                                              mfa = main_frame[0]
                                              mfb = main_frame[1]
                                              mfc = main_frame[2] # width
                                              mfd = main_frame[3]
                                              new_mf = "\{\{#{mfa}, #{mfb}\}, \{#{@new_width}, #{mfd}\}\}"
                                              mod_path = Sketchup.active_model.path
                                              Sketchup.active_model.select_tool(nil)
                                              Sketchup.active_model.close_active
                                              Sketchup.send_action('closeDocument;')
                                                if not @@revert
                                                  frame_write(new_mf)
                                                  win_write(new_doc)
                                                  @@revert = true
                                                else
                                                  win_revert
                                             mod_path != '' ? Sketchup.open_file(mod_path) ; Sketchup.send_action('newDocument;')
                                            def self.win_revert
                                                  frame_write(SMF)
                                                  win_write(SUD)
                                                  @@revert = false
                                            def self.set_2_print
                                              default_paper
                                              @new_width = (vph * @ratio)
                                              @@revert = (vpw.between?( @new_width - 3, @new_width + 3 ))
                                              process_window
                                            def self.set_2_square
                                              @new_width = vph
                                              process_window
                                            class AddIconWindowObserver < Sketchup;;AppObserver
                                              def onQuit
                                                revert = JcB;;SetWindowSize;;Change.class_variable_get(;@@revert) || false
                                                SetWindowSize;;Change.frame_write(SMF) if revert
                                                SetWindowSize;;Change.win_write(SUD)   if revert
                                               # Attach the observer
                                               Sketchup.add_observer(AddIconWindowObserver.new)
                                          end # change
                                        end # module
                                      #  JcB;;SetWindowSize;;Change.set_2_square
                                        greatoe
                                        1. up arrow >> return again
                                          the new blank SketchUp window go square;
                                        the new blank SketchUp window revert its size, but goes to a new position on screen;
                                        I kept doing this, results are same: the new blank SketchUp window do go square and revert, but the position on screen is changing.
                                          greatoe
                                          1. I draw something in the new blank SketchUp window, save the file.
                                            the "square - revert with different position" circle goes on.
                                          2. I close SketchUp, open it again (with and without an existing file), I do 1) and 2), the result is same as 3).
                                            greatoe
                                            1. I pasted the code, hit return
                                              ruby console return "True";
                                            2. JcB::SetWindowSize::Change.set_2_square, return
                                              and SketchUp ask me if I want to save my current work;
                                            3. I click "yes"
                                              ruby console return the following:
                                              Error: #<NoMethodError: undefined method attribute_dictionary' for nil:NilClass> /Users/zz/Library/Application Support/SketchUp 2015/SketchUp/Plugins/jbb_layers_panel/rb/observers.rb:189:in onContentsModified'
                                            if I click "no"
                                            ruby console return:
                                            Error: #<TypeError: reference to deleted Attribute>
                                            /Users/zz/Library/Application Support/SketchUp 2015/SketchUp/Plugins/jbb_layers_panel/rb/observers.rb:203:in each' /Users/zz/Library/Application Support/SketchUp 2015/SketchUp/Plugins/jbb_layers_panel/rb/observers.rb:203:in block in onContentsModified'
                                            SketchUp:1:in `call'
                                            then the window of my current work is closed, while SketchUp is still running;
                                            then I click the SketchUp icon on the Dock, a blank/new SketchUp window pops up, which is square.
                                            1. I press up arrow in ruby console then return
                                              the new SketchUp window revert to previous size, but a little different with its position on screen.
                                            • 1 / 3
