    [Plugin][$] Profile Builder 2
    219 Posts 40 Posters 53.8k Views 40 Watching
    • W Offline
      Whaat
      @pbacot said:
      I don't agree on the taxes. Taxes are never advertised in the US. They are different according to the manner of the transaction and where you are. Sales taxes are by state and local government (it can be a different amount in the next town).
      I would ask where is the tax coming from? When I buy something from Colorado, I am charged California sales tax, because that's where I am. If you are in another country I don't know where the tax is generated.
      I think the taxes are determined by the location of the puchaser.
      I agree, these should be displayed before choosing to purchase - this is out of my control however...
        rv1974
        @whaat said:
        @rv1974 said:
        I wish the Author will overcome (in the near future) the biggest limitation:
        only connected edges are accepted as profile path.
        NB: Dudes leaf through the Help pages. This is really thermo-nuclear power plugin!
        Thanks - but how would you propose that it should work to determine the path?
        By pre-selecting the edges.
        Its implemented in 3ds Max for ages:
        One 'top' spline entity can incorporate numerous not connected splines.
        • panixiaP Offline
          panixia
          also could be useful to have a "stepped" mode for profileson sloped path..
          • W Offline
            Whaat
            OK, so you want to be able to select multiple polylines (not connected to each other) prior to building along path? That feature will probably come eventually...
            • pbacotP Offline
              How would the plugin know what edge is first and what to do between disconnected edges? And doesn't PB-1 do this, but separately apply profile to each edge?
                pcmoor
                Thanks Dale,
                First, "Whaat" a great plugin!
                However when using the PB Quantifier, the report shows the shorter measure of a cut sheet, is it possible to show the bounding box measure as a alternative or check?
                  rv1974
                  toggling sweep modifier onff applied upon single spline.
                  • panixiaP Offline
                    panixia
                    toggling sweep modifier on\off applied upon single spline.
                    you could have included a "railing" example too.. πŸ˜„
                      raineysky
                      I'm getting this error while trying to download the trial.
                      • pbacotP Offline
                        Oh. Those are connected. Just multiple connected paths. I guess it could work. PB has directionality. As you know after applying to a path you can switch the direction and orientation in different ways. One way may not apply to all paths selected.
                        Of course we are comparing a $40 SU plugin to 3ds max.
                        • panixiaP Offline
                          panixia
                          that's a good point πŸ˜†
                          actually 3dsmax railing itself doesn't place nowere near to the flexibility of PB on many other aspect.. you should add 200€ railclone to use custom parts and fine-tune every aspect such as PB does (well actually that's way more powerful)
                          • W Offline
                            Whaat
                            @pcmoor said:
                            Thanks Dale,
                            [attachment=0:39kov7e0]<!-- ia0 -->cut sheet measure.JPG<!-- ia0 -->[/attachment:39kov7e0]
                            Hi pcmoor,
                            Did you create that object with Profile Builder? If so, the length should be based on the length of the underlying path. Using the bounding box to calculate length will not work on a Profile Member composed of multiple segments.
                            • W Offline
                              Whaat
                              Hi Raineysky,
                              If you (or anyone else) is getting this message, please contact the SketchUp Extension Warehouse team here:
                              Attention Required! | Cloudflare
                              (help.sketchup.com)
                              Please follow this link for complete instructions on installing purchased extensions:
                              http://help.sketchup.com/en/article/3000059
                              Thanks for reporting this. I am told that the EW team is working to resolve this issue.
                              Dale
                                pcmoor
                                @whaat said:
                                Hi pcmoor,
                                I created the object using PB2, then used the trim to surface tool, when the surface is within the length of the object, this produced a result where the PMPI is the same length as the short point of the cut. However if i place the cutting surface outside the object the "trim to face tool" extends the object and the PMPI is the same as the long point of the cut.
                                so this resolves my issue to create a exact overall cut length. provided I use the extend method
                                  raineysky
                                  Whaat,
                                  I reported it to the link you provided.
                                  Thank You,
                                  Paul
                                  • jujuJ Offline
                                    juju
                                    @juju said:
                                    I think the point is that the price advertised should include taxes.
                                    Paypal not supported? That's unfortunate.
                                    Why not have it available on Smustard.com as well?
                                    yeah well, so I caved, I bought this minutes ago, no taxes on my billing ($37.50 total).
                                    wondering if i can resell Profilebuilder I bought years back through Smustard?
                                    • david_hD Offline
                                      david_h
                                      So. . .how does one upgrade from the trial to the purchase. The pullout doesn't seem to have a license or "purchase" tab. Also, I can't find "Profile Builder 2" in the Ext. WH anymore. can somebody help me on this. Also, there seemed to be some chatter on this thread about purchasing issues. Have those been resolved?
                                      Thx,
                                      David_H
                                      • W Offline
                                        Whaat
                                        Thx,
                                        David_H
                                        Hi David, first un-install the Trial, then follow these instructions:
                                        (help.sketchup.com)
                                        • W Offline
                                          Whaat
                                          This issue should now be fixed thanks the hard-working EW team!
                                          If you have had this error, please try installing again - it should now work.
                                            raineysky
                                            Dale,
                                            I got the same error but this time I went out for a while and when I came back it was installed....Also had trouble finding the plugin, even with search. I sent a message in to let them know. Just had a few minutes to play with PB2 but it looks awesome!
                                            Thank You,
                                            Paul
                                            • 11
                                            • 2 / 11
