    [SOLVED] display errors in plugins Sketchup make 2015
    22 Posts 3 Posters 3.2k Views 3 Watching
      driven
      @deaneau said:
      ...it is not a plugin problem...
      so, do you see the same [missing css] with any other plugin?
      for example Extensions Warehouse, 3d Warehouse, SCF...
      if these show their css, then this is most likely a LightUp css path issue...
        Thinks... 😮
        Completely off the wall...
        What is returned with this typed/pasted in the Ruby Console ?
        Sketchup.find_support_file('Plugins')
        I am thinking there might be an accent in your Windows User-name...
        That might cause issues ??
        • deaneauD Offline
          deaneau
          @ TIG
          C:/Users/d/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins
          here an other plugin withe same problem
            OK.
            So now I think it's something in your IE11 Internet Options settings ?
            Preventing a custom "css" file from being used ?
            If you access sketchucation.com with IE is the appearance compromised ?
            Any other ideas, anyone ?
              driven
              I just had a look on mac using Web Inspector, and LightUp uses a 'relative' link to the css file...
              it is beside the html [no sub folder] so the fact that the html loads implies IE is blocking relative links...
              can you 'view source' on the webDialog on a PC?
              • deaneauD Offline
                deaneau
                yes and if i open the html from the plugins the display will be good
                here an example in sketchup and in IE
                • deaneauD Offline
                  deaneau
                  yes i can view html in the plugin dialog
                    driven
                    in the header section it should show the path to the css, and possibly the reason for not loading?
                    if you copy paste the header [into a code block] from one of the failing ones it might give some clues...
                    does 'show source' display the errors? [it does on a mac]
                    • deaneauD Offline
                      deaneau
                      here the html code of the header
                      <head>
                      <meta charset="UTF-8">
                      <link type="text/css" rel="StyleSheet" href="profileBuilder.css"/>
                      <script type="text/javascript" src="js/wz_jsgraphics.js"></script>
                      <link type="text/css" rel="StyleSheet" href="js/jquery-ui.css"/>
                      <script type="text/javascript" src="js/jquery-1.11.1.min.js"></script>
                      <script type="text/javascript" src="js/jquery-ui.js"></script>
                      <script type="text/javascript" src="js/pb.js"></script>
                      <title>ProfileBuilder</title>
                      <style>
                      #placementPoint {width;100%;margin-top;0px;}
                      #profilerow {padding;0px;margin;0px;}
                      #Canvas {}
                      #lockAspect {border;1px solid transparent;}
                      #lockAspect;hover {border;1px solid gray;}
                      .overflow {height; 200px;}
                      #primaryPropertiesTable {width;100%;padding-top;0px;padding-left;0px;margin-top;0px;margin-left;2px;vertical-align;middle;}
                      td > img {padding-right;2px;vertical-align;middle;}
                      </style>
                      </head>
                        Shot in the dark...
                        Try swapping the order of some lines in the html file's header:
                        **<link type="text/css" rel="StyleSheet" href="profileBuilder.css"/>** <script type="text/javascript" src="js/wz_jsgraphics.js"></script> <link type="text/css" rel="StyleSheet" href="js/jquery-ui.css"/>
                        becomes
                        <script type="text/javascript" src="js/wz_jsgraphics.js"></script> <link type="text/css" rel="StyleSheet" href="js/jquery-ui.css"/> **<link type="text/css" rel="StyleSheet" href="profileBuilder.css"/>**
                        Perhaps the jquery css is overwriting some of the pb css ??
                        • deaneauD Offline
                          deaneau
                          hi TIG this doesn´t work.. this must be a an error outside of sketchup.
                          i have reinstall sketchup and the plugins..no changes 😕
                            driven
                            It looks like the IE settings used by SU, are blocking relative links...
                            did you test if the SCF tools work in SU?
                            also, you could try adding meta data above the <link type="text/css" rel="StyleSheet" href="profileBuilder.css"/>
                                        <meta http-equiv="content-type" content="charset=UTF-8" />
                                        <meta http-equiv="MSThemeCompatible" content="Yes" />
                                        <meta http-equiv="X-UA-Compatible" content="IE=edge,chrome=1">
                            • deaneauD Offline
                              deaneau
                              could you send me a link?
                                driven
                                the one from here...
                                http://sketchucation.com/pluginstore?pln=SketchUcationTools
                                • deaneauD Offline
                                  deaneau
                                  i have solve this Problem with a Windows refresh
                                  Eneroth Railroad is a good example.
                                  the first button (track with a plus) look like without CSS
