    [SOLVED] display errors in plugins Sketchup make 2015
    22 Posts 3 Posters 3.3k Views 3 Watching
    • deaneauD
      deaneau
      yes , i have open all html files in the IE and all looks ok.
        ... Contact Adam 😕
        • deaneauD
          deaneau
          TIG this seams it is not a plugin problem..in 2014 i have the same problem. in the first time i have had installed this plugin i havn´t display problems.
            driven
            @deaneau said:
            ...it is not a plugin problem...
            so, do you see the same [missing css] with any other plugin?
            for example Extensions Warehouse, 3d Warehouse, SCF...
            if these show their css, then this is most likely a LightUp css path issue...
              Thinks... 😮
              Completely off the wall...
              What is returned with this typed/pasted in the Ruby Console ?
              Sketchup.find_support_file('Plugins')
              I am thinking there might be an accent in your Windows User-name...
              That might cause issues ??
              • deaneauD
                deaneau
                @ TIG
                C:/Users/d/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins
                here an other plugin withe same problem
                  OK.
                  So now I think it's something in your IE11 Internet Options settings ?
                  Preventing a custom "css" file from being used ?
                  If you access sketchucation.com with IE is the appearance compromised ?
                  Any other ideas, anyone ?
                    driven
                    I just had a look on mac using Web Inspector, and LightUp uses a 'relative' link to the css file...
                    it is beside the html [no sub folder] so the fact that the html loads implies IE is blocking relative links...
                    can you 'view source' on the webDialog on a PC?
                    • deaneauD
                      deaneau
                      yes and if i open the html from the plugins the display will be good
                      here an example in sketchup and in IE
                      • deaneauD
                        deaneau
                        yes i can view html in the plugin dialog
                          driven
                          in the header section it should show the path to the css, and possibly the reason for not loading?
                          if you copy paste the header [into a code block] from one of the failing ones it might give some clues...
                          does 'show source' display the errors? [it does on a mac]
                          • deaneauD
                            deaneau
                            here the html code of the header
                            <head>
                            <meta charset="UTF-8">
                            <link type="text/css" rel="StyleSheet" href="profileBuilder.css"/>
                            <script type="text/javascript" src="js/wz_jsgraphics.js"></script>
                            <link type="text/css" rel="StyleSheet" href="js/jquery-ui.css"/>
                            <script type="text/javascript" src="js/jquery-1.11.1.min.js"></script>
                            <script type="text/javascript" src="js/jquery-ui.js"></script>
                            <script type="text/javascript" src="js/pb.js"></script>
                            <title>ProfileBuilder</title>
                            <style>
                            #placementPoint {width;100%;margin-top;0px;}
                            #profilerow {padding;0px;margin;0px;}
                            #Canvas {}
                            #lockAspect {border;1px solid transparent;}
                            #lockAspect;hover {border;1px solid gray;}
                            .overflow {height; 200px;}
                            #primaryPropertiesTable {width;100%;padding-top;0px;padding-left;0px;margin-top;0px;margin-left;2px;vertical-align;middle;}
                            td > img {padding-right;2px;vertical-align;middle;}
                            </style>
                            </head>
                              Shot in the dark...
                              Try swapping the order of some lines in the html file's header:
                              **<link type="text/css" rel="StyleSheet" href="profileBuilder.css"/>** <script type="text/javascript" src="js/wz_jsgraphics.js"></script> <link type="text/css" rel="StyleSheet" href="js/jquery-ui.css"/>
                              becomes
                              <script type="text/javascript" src="js/wz_jsgraphics.js"></script> <link type="text/css" rel="StyleSheet" href="js/jquery-ui.css"/> **<link type="text/css" rel="StyleSheet" href="profileBuilder.css"/>**
                              Perhaps the jquery css is overwriting some of the pb css ??
                              • deaneauD
                                deaneau
                                hi TIG this doesn´t work.. this must be a an error outside of sketchup.
                                i have reinstall sketchup and the plugins..no changes 😕
                                  driven
                                  It looks like the IE settings used by SU, are blocking relative links...
                                  did you test if the SCF tools work in SU?
                                  also, you could try adding meta data above the <link type="text/css" rel="StyleSheet" href="profileBuilder.css"/>
                                              <meta http-equiv="content-type" content="charset=UTF-8" />
                                              <meta http-equiv="MSThemeCompatible" content="Yes" />
                                              <meta http-equiv="X-UA-Compatible" content="IE=edge,chrome=1">
                                  • deaneauD
                                    deaneau
                                    could you send me a link?
                                      driven
                                      the one from here...
                                      http://sketchucation.com/pluginstore?pln=SketchUcationTools
                                      • deaneauD
                                        deaneau
                                        i have solve this Problem with a Windows refresh
                                        Eneroth Railroad is a good example.
                                        the first button (track with a plus) look like without CSS
