    1.5k Posts 470 Posters 3.3m Views 469 Watching
      Gábor
      @stepanov said:
      I can not download the plugin
      I do not see download button
      Do you have AdBlock on? Do you see the advertisements on the site?
      As the site is maintained partly based on the support from advertisers, only those are allowed to download plugins who do not block ads.
        pvidal
        Hi there!
        I have a serveral issue to round a complex edge
        http://www.becam.com.uy/SU/roundCorner_issues_0002.jpg
        when I check whith the solid Inspector plugin, the result is fine
        http://www.becam.com.uy/SU/roundCorner_issues_0001.jpg
        I set the round Corner Plugin and run
        http://www.becam.com.uy/SU/roundCorner_issues_0003.jpg
        and the result is full of surfaces borders and internal faces edges.
        http://www.becam.com.uy/SU/roundCorner_issues_0004.jpg
        can you tellme why?
        Thanks a lot!
          Too small. Try scaling the model up by a factor of 100 or more before running Round Corners.
            pvidal
            Thanks Dave
            But, when I scaling up the model, it is not necessary also scale the offset factor too?
            in this case the problem is not still happening?
            thanks
              Yes. You have to scale the offset by the same factor.
                pvidal
                When I do, the errors in geometry are the same, like if I had not scaled...
                  Then maybe x1000 ?
                    pvidal
                    I just do that!, and still happens.
                    I go upload a .skp file and a picture of the element what I need model.
                    Is a Sheet of steel, what simulate a tile roof.
                    http://www.becam.com.uy/SU/stellShet_TileRoof.jpg
                    a thousand of thanks!!
                    PD: the escale in the skp file is 1000/1
                    SU version: Sketchup Pro 2014
                    • gillesG Offline
                      gilles
                      Don't know how you did this but your model is full of bad geometries, a basic profile push-pull should provide good geometries.
                      Round corner will go crazy trying to round this.
                      Redraw from scratch.
                        pvidal
                        Thanks Gilles!
                        I did the model from two extruded shapes and intersect them, after I generate the shape of the phase shift, like the components in the file I upload before, then I explode all components. (basicly)
                          roland joseph
                          This place is pretty strange some times....
                          [quote][/Really? It's very clearly spelled out in the first post of the thread.[quote]
                          Sure ...clear as mud....They are asking for a "download" button....not a colored product dissertation on one page. The fact is the layout of those pages is a font/color/sizing/css mess.
                          • F Offline
                            forrest
                            I've installed with SketchUcation Plugin Store 2.6.1 in SketchUp 2015, and I have installed LibFredo 6.7c, but it tells me every time I start SketchUp that I need LibFredo 6.3 or greater. Is something missing? RoundCorner never starts.
                              Have you tried installing the newest copy of Round Corner / Lib via the SCF Plugin Store?
                              • Z Offline
                                zanthus
                                Thanks Fredo6
                                  tmophoto
                                  why is it so hard to install and get these plugins to work? why dont you have them available in the extensions warehouse?
                                  are there any other options for rounding corners in sketchup? I have just wasted half a day trying to get this to work
                                    It isn't difficult to get or install Fredo's plugins.
                                    You're right. They aren't available in the Extension Warehouse but they are available through the SketchUcation Plugin Store which is clearly explained in the first post of this thread.
                                    You could also install the Plugin Store toolset, which will automatically install plugins/extensions and give you all sorts of other options.
                                    It shouldn't have taken you half a day to get this plugin to work, but if you don't want to use it, you can use Follow Me.
                                    No plugins required.
                                    • pbacotP Offline
                                      For me the Sketchucation Plugin store and toolset is better than the Extension Warehouse. Well perhaps that's not completely fair--I avoid using the Warehouse, so how can I compare?
                                      Fredo's plugins come in automatically on the push of a button, always work, and the whole SCF Plugin setup is easy to understand. Fredo also provides an update window that tells you, within Sketchup, when his plugins have been updated and the status of versions you currently have. They have a lot of functionality and most require his "FredoLib" library plugin to be up to date, in order to run properly.
                                      • PixeroP Offline
                                        Pixero
                                        I have an idea for the round corner plugin.
                                        To get around the problem with altering a bevel on an object, what if the script would save a original "unbeveled" version of the object on a special hidden layer and if the user wants to change the bevel later on the script would fetch the original object and do a new bevel on it with the new settings.
                                        • Rich O BrienR Online
                                          That's an awesome idea.
                                          • JQLJ Offline
                                            JQL
                                            Yes that is! And fredo already owns most of the code for that on Ghostcomp
                                            www.casca.pt
                                            Visit us on facebook!
                                            • 53
                                            • 54
                                            • 55
                                            • 56
                                            • 57
                                            • 73
                                            • 74
                                            • 55 / 74
