    [Plugin] FredoTools - v4.5c - 24 Jun 24
    463 Posts 123 Posters 698.3k Views 121 Watching
    • fredo6F Offline
      @mousa_sa said:
      Fredo, I installed this update, but SketchUp still crash when I launch the Thrupaint.
      Which version of Sketchup? Your profile says SU2016.
      • Mousa_SAM Offline
        Mousa_SA
        That occur on SketchUp 2018 and SketchUp 2017, I didn't test it on 2016.
        • fredo6F Offline
          I know there is this random bugsplat, but I am unable to reproduce it in my own environment.
          If you have it, could you send a report to Sketchup in the bugsplat window, note the bugsplat record number and post or send this crash number to me.
          • Mousa_SAM Offline
            Mousa_SA
            I thought this update has a fix for these random bugsplat. The Bugsplat record number is #37782
            I have sent the bugsplat report to you as a PM.
            • fredo6F Offline
              NEW RELEASE: FredoTools v3.2c - 12 Mar 18
              FredoTools 3.2c fixes a major bug in the calculation of volume in SolidVolume
              See FredoTools plugin home page for Download.
              See also main post of this thread for User Discussion.
                rv1974
                Fredo, in this particular model reverse\ orient tool fails to exit with savedresult. could you take a look? Thanks!
                kkk.rar
                • fredo6F Offline
                  I tried on your model but AutoOrientFaces does the job and performs correctly the reversing.
                  The issue with your model is that each of the 12 subgroups have a quite large number of faces. In particular the two wheels which have 3,218 faces. The whole model would probably need a rework, because the number of faces seems oversized for a rather boxy shape.
                  I would probably need to optimize the algorithm. The white screen is just when processing the two wheels.
                  • JQLJ Offline
                    JQL
                    Hi Fredo,
                    I've noticed that your tools don't follow the convention for selecting a surface with a single click.
                    The selection method is assuming two or more faces connected by a hidden edge to be a surface, while sketchup convention assumes a surface to be at least two faces connected by a soft edge.
                    Is this by design?
                    Thanks,
                    JoĂŁo
                    www.casca.pt
                    Visit us on facebook!
                    • fredo6F Offline
                      @jql said:
                      Hi Fredo,
                      Is this by design?
                      Thanks,
                      JoĂŁo
                      In general I assume that if you don't see the edge on the screen, the bounding faces are part of the same click-selection. When Geometry Hidden is turned on, then faces behave as separate.
                      This may not be what the user wants in some occasions; this is why I also have explicit options with palette buttons.
                      Which tool of FredoTools are you referring to ?
                      • JQLJ Offline
                        JQL
                        I'm referring to every tool I guess. I was convinced it had to do with a global selection method defined by LibFredo.
                        I often require the use of surfaces and treat them as such in Sketchup. But for JPP, reverse/orient faces, or thrupaint, I often had problems and didn't understand why. So I started selectin the surfaces first, with regular sketchup selection tool. So I only recently found out what was happening...
                        www.casca.pt
                        • fredo6F Offline
                          Is this now as you expect?
                          • Rich O BrienR Online
                            Fredo,
                            Is it possible to add Cast Shadows On/Off to the Face Triangulator tool?
                            • JQLJ Offline
                              JQL
                              Not quite. What I would expect is that only with soft edges, two or more faces would be considered surfaces, as in sketchup.
                              www.casca.pt
                              • fredo6F Offline
                                Never noticed for the Hidden?
                                Can be done, but this impacts everyone that is used to or prefer the current behavior. Indeed, the strng argument is that this is how Sketchup does the selection.
                                • JQLJ Offline
                                  JQL
                                  Well... That's a tough one. Make it coherent with Sketchup or keep it as it is for every user sake?
                                  What if people do what I did and don't use the option as they don't quite understand it?
                                  Or what if, following the hidden preferences you have, you would have an option of surface selection method?
                                  www.casca.pt
                                    PAragao
                                    Hi all,
                                    I think this tool will be my savior since I keep finding mismatches on the edges of my sketch. However, when I try to tell it to fix the edges it gives the error "Cannot create unit vector from zero length vector"
                                    Anyone has an idea how to solve this?
                                    Thanks.
                                    Date: 08-Apr-18 14:45:11
                                    An error occurred in Edge Inspector
                                    Error during Inspection
                                    body_fredotools__edgeinspector.rbe: 3286 -- axes
                                    body_fredotools__edgeinspector.rbe: 3286 -- zero_edge_disolve_edge
                                    body_fredotools__edgeinspector.rbe: 3269 -- block in zero_edge_absorb_final
                                    body_fredotools__edgeinspector.rbe: 3249 -- each
                                    body_fredotools__edgeinspector.rbe: 3249 -- zero_edge_absorb_final
                                    body_fredotools__edgeinspector.rbe: 3379 -- block in zero_edge_resolve
                                    body_fredotools__edgeinspector.rbe: 3367 -- each
                                    body_fredotools__edgeinspector.rbe: 3367 -- each_with_index
                                    body_fredotools__edgeinspector.rbe: 3367 -- zero_edge_resolve
                                    body_fredotools__edgeinspector.rbe: 2706 -- call
                                    body_fredotools__edgeinspector.rbe: 2706 -- block in execute_fixing
                                    body_fredotools__edgeinspector.rbe: 2703 -- each
                                    body_fredotools__edgeinspector.rbe: 2703 -- each_with_index
                                    body_fredotools__edgeinspector.rbe: 2703 -- execute_fixing
                                    body_fredotools__edgeinspector.rbe: 1713 -- robot_fixing_execute_single
                                    body_fredotools__edgeinspector.rbe: 1703 -- robot_fixing_exec
                                    body_fredotools__edgeinspector.rbe: 1686 -- robot_fixing
                                    body_fredotools__edgeinspector.rbe: 1573 -- block in resolver_fixing
                                    lib6operation.rbe: 332 -- call
                                    lib6operation.rbe: 332 -- step_geometry
                                    lib6operation.rbe: 374 -- start_execution
                                    body_fredotools__edgeinspector.rbe: 1573 -- resolver_fixing
                                    body_fredotools__edgeinspector.rbe: 1924 -- block in palette_floating
                                    body_lib6palette.rbe: 3754 -- call
                                    body_lib6palette.rbe: 3754 -- execute_button
                                    body_lib6palette.rbe: 3559 -- onLButtonUp
                                    lib6palette.rbe: 91 -- onLButtonUp
                                    body_fredotools__edgeinspector.rbe: 786 -- onLButtonUp
                                    • fredo6F Offline
                                      @paragao said:
                                      Hi all,
                                      This looks like a bug (I fixed it). It does mean that you seem to have zero-length edges in your model.
                                      By the way, if you are lucky to have 'ill-edged' models, I am interested for testing EdgeInspector.
                                      • fredo6F Offline
                                        NEW RELEASE: FredoTools v3.2d - 09 Apr 18
                                        FredoTools 3.2d is about bug fixing in EdgeInspector.
                                        • JQLJ Offline
                                          JQL
                                          What exactly are we supposed to find in these models?
                                          www.casca.pt
                                          • fredo6F Offline
                                            @jql said:
                                            Tiny edges, needle eyes, etc....
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 23
                                            • 24
                                            • 15 / 24
