    Preview of Components in Component list
    9 Posts 4 Posters 743 Views 4 Watching
      ania1sun
      %(#4040FF)[Hi there πŸ˜„
      Could you please advise how to get nice preview in Component catalogue.
      I enclose printscreen of nice gas hob Component as it is in the project and the preview of the same gas hob upside down in Components catalogue .]
      gas hob
      the preview in component list
      • gillesG Offline
        gilles
        Blue axis of the component must be upside down.
          Place an instance.
          Select it.
          Use the Context-Menu to 'Change Axes'.
          Set the red/green axes so the blue axis is in the right direction.
          Now place another instance.
          It should be the right way round.
          Do a save_as on the component...
          Overwrite the external SKP that is currently wrongly oriented, with this fixed one.
            ania1sun
            @tig said:
            Place an instance.
            Select it.
            The blue axis is up so correct. I attache the skp. Component. Still cannot figure it out
              Works alright for me from the outset.
              Here's my version [v8] which previews properly AND inserts correctly...
              It is not the best set up SKP.
              HOB GAS FOSTER 5 BURNERS szer.870.skp
                With it placed correctly, explode the parent component and make a new component of it.
                That needs a lot of other help, though. There are quite a number of reversed faces that should be corrected and the component's file size could be quite a bit smaller if it was built correctly.
                  ania1sun
                  %(#0040FF)[Thanx Tiger πŸ˜„
                  Could you advice any tutorial that shows how to set up similarly complicated Component in a proper way ?]
                    ania1sun
                    Ht there, I still cannot figure out the way how to have nice new created Component preview in Components folder.
                    I attache present preview of Component and printscreen how I would like the preview to look like.
                    its hardly to tell from the preview above how the component looks like
                    Id like the preview to look like that
                    • gillesG Offline
                      gilles
                      Set the view like you want then create the comp.
                      Or explode, purge unused, set the view like you want then create the comp.
                      clik the image
