Imported picture doesn't appear into photomatch
hi
I am trying to use a .jpg picture into photomatch.
The problem is that every time, I can see the picture for a fraction of a second and then "pouf" it is gone. On my screen I just see the photomatch's setting window, the axes and just a plain gray background.
But no picture to align my axes.so any suggestion is more than welcome, I thank you all for your efforts.
kind regards
Triopis
Check the settings in Styles>Edit>Modeling.
Thank you Dave for the support.
But these settings are already checked and with the same values.Triopis
Could you share the image?
Please complete your profile with OS and SU version. Thank you.
I meant the image you're trying to use for Match Photo.
And I was asking you to complete your profile with the OS and SU version. It helps others when they are trying to answer your questions.
Hmmmm... It worked for me.
I attached the SKP file. When you open it, is the image there? Can you import a different image as a Match Photo?
