    MSPhysics 1.0.3 (16 October 2017)
    926 Posts 171 Posters 927.5k Views 172 Watching
      Missed this advanced one! Cool! 😎
      • ely862meE Offline
        ely862me
        Wow.. how could I missed this ?
        Elisei (sketchupper)
        Come and See EliseiDesign
          Anton_S
          While rewriting SketchyPhysics I learned very important stuff. I have to make some major changes to this project before its released. Sorry 😒
            Gonthim
            No problem Anton. Was just curious about an update.
            Thanks for all the work. Putting something this complex out in your spare time can't be easy. I'll keep waiting patiently. πŸ˜„
              not realy free, only a free trail.
              You have a free version with 10 seconds animation + limited number of objects!
                Anton_S
                Hey guys,
                Just as as an update, I'm changing from depending on FFI to using a C++ extension. I'm pretty sure it will make the code plenty times cleaner, and improve performance roughly 50 times. I also, figured that using sketchup animation for this won't be a good choice, as during animation changing scenes wouldn't work, but via timers changing scenes would work like a charm.
                • N Offline
                  Nicat93
                  Hi. Just to let you know that I am waiting for this plugin to finally create hidden blade from assassins creed B) Which I have wanted already 3 or 4 years πŸ˜›
                  Thank you for your work.
                    Anton_S
                    Hello Nicat,
                    I don't know how I missed this post. πŸ˜’
                    MSPhysics will be designed to have a very stable and full-documented API. My initial purpose of writing this plugin was to have a better scripting API. When I was a user of SP, I was very unimpressed with all the bugs in script and all the inconsistencies. It literally took away my motivation from creating games or scripted models in SP. However, the legacy of SketchyPhysics made me urgent to write something like it.
                    In SketchyPhysics users came across many problems of not being able to create games, such as not being able to use mouse wheel input and mouse clicks in general. Not to mention that keyboard controls were very unstable because if the SP Control Panel got deactivated the controls would start interacting with SU window, which in turn deactivate SP and activates different tools. This was very annoying. MSPhysics, the Windows version, will have a feature to monitor and block these keyboard controls, mouse clicks, and mouse wheel events. Not only you will know when certain keys are pressed, but also you won't need that 'control panel' dialog taking focus.
                    Even more amazing, for gaming purposes, the Windows version of MSPhysics will have a feature to set SU viewport fullscreen. I.E when simulation starts viewport could be set fullscreen, and when resets, viewport is set back to original placement. This will make gaming in SketchUp a much better experience.
                    I'm glad you're still waiting to write a game. I will try to do my best in making progress to this project.
                    Best regards,
                    Anton
                    • plot-parisP Offline
                      plot-paris
                      Very exciting stuff! 😲 Hope its getting along well...
                      • dereiD Offline
                        derei
                        Is this project still under development, or abandoned?
                          Before the next release you can train your Physics' skill in 2D with this incredible Algodoo! β˜€
                            Anton has been pretty active in this thread up til a couple of weeks ago, so I'd think it's still live and kicking.
                              Anton_S
                              What Thom said
                                Jesus4fun
                                I am getting this... Please can someone help me? I have no idea what I did wrong or how to fix it...
                                Error Loading File C:/Users/Norm/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/MSPhysics/main.rb
                                Error: #<NoMethodError: undefined method require_library' for AMS::Lib:Module> C:/Users/Norm/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/MSPhysics/main.rb:8:in <top (required)>'
                                C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:in require' C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:in load'
                                C:/Users/Norm/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/MSPhysics.rb:75:in register_extension' C:/Users/Norm/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/MSPhysics.rb:75:in module:MSPhysics'
                                C:/Users/Norm/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/MSPhysics.rb:57:in `<top (required)>'
                                • O Offline
                                  Olivier92
                                  Hi Everyone,
                                  This plugins looks very promising. Thank you for developping it.
                                  I tried to install it on my SU 2015 64bits but apparently it will not install.
                                  I guess it is because of the 64bits version is this correct?
                                  If so, any change it will work on 64bits SU any time soon?
                                  Kind regards
                                    Jesus4fun
                                    When I just tried to download MSPhysics plugin I am getting 404 error. So That is why I am asking this, Is this extension discontinued? 😞
                                      Anton_S
                                      MSPhysics is in alpha stage and incomplete. Version 0.1.0 relied on AMS Libary 1.x.y, which is now obsolete. That explains why you got the loading error, and why I removed the download link. Version 1.0.0 is under development and is expected to be released this year.
                                        Jesus4fun
                                        I can't wait to see it, test it and use it!! β˜€
                                        • O Offline
                                          Olivier92
                                          Hello Anton,
                                          "Version 1.0.0 is under development and is expected to be released this year."
                                          This is great news.
                                          Will this version be usable with Sketchup 64 bits?
                                          Kind regards
                                          Olivier
                                            TonedF
                                            I cannot download this...the link is dead!!
                                            • 11
                                            • 46
                                            • 47
                                            • 9 / 47
