    MSPhysics 1.0.3 (16 October 2017)
    930 Posts 173 Posters 1.4m Views 174 Watching
      Before the next release you can train your Physics' skill in 2D with this incredible Algodoo! β˜€
        @derei said:
        Is this project still under development, or abandoned?
        Anton has been pretty active in this thread up til a couple of weeks ago, so I'd think it's still live and kicking.
          Anton_S
          What Thom said
            Jesus4fun
            I am getting this... Please can someone help me? I have no idea what I did wrong or how to fix it...
            Error Loading File C:/Users/Norm/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/MSPhysics/main.rb
            Error: #<NoMethodError: undefined method require_library' for AMS::Lib:Module> C:/Users/Norm/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/MSPhysics/main.rb:8:in <top (required)>'
            C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:in require' C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:in load'
            C:/Users/Norm/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/MSPhysics.rb:75:in register_extension' C:/Users/Norm/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/MSPhysics.rb:75:in module:MSPhysics'
            C:/Users/Norm/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/MSPhysics.rb:57:in `<top (required)>'
            • O
              Olivier92
              Hi Everyone,
              This plugins looks very promising. Thank you for developping it.
              I tried to install it on my SU 2015 64bits but apparently it will not install.
              I guess it is because of the 64bits version is this correct?
              If so, any change it will work on 64bits SU any time soon?
              Kind regards
                Jesus4fun
                When I just tried to download MSPhysics plugin I am getting 404 error. So That is why I am asking this, Is this extension discontinued? 😞
                  Anton_S
                  MSPhysics is in alpha stage and incomplete. Version 0.1.0 relied on AMS Libary 1.x.y, which is now obsolete. That explains why you got the loading error, and why I removed the download link. Version 1.0.0 is under development and is expected to be released this year.
                    Jesus4fun
                    I can't wait to see it, test it and use it!! β˜€
                    • O
                      Olivier92
                      Hello Anton,
                      "Version 1.0.0 is under development and is expected to be released this year."
                      This is great news.
                      Will this version be usable with Sketchup 64 bits?
                      Kind regards
                      Olivier
                      • T
                        TonedF
                        I cannot download this...the link is dead!!
                          Anton_S
                          @Oliver92 MSPhysics will be compatible with 32 and 64 bit SU versions. Although the first version will be limited to Windows OS due to huge reliance on MSFT Windows API.
                          @TonedF Read a few posts above you.
                          • pcberdwinP
                            pcberdwin
                            Fantastic update! πŸ˜„ The buoyancy plane is interesting.
                            I couldn't figure out how to record, though. I see the check box in settings but then what?
                            • B
                              Bas9999
                              Well i have found earlier versions around on the internet and i am confused with the version numbering because it already passed v1.0.0 @ 2014-09-01..... πŸ˜‰
                              MSPhysics - v0.1.0 (2014-04-26)
                              MSPhysics - v0.2.0 (2014-06-26)
                              MSPhysics - v0.2.0 (2015-04-06) ???
                              MSPhysics - v1.0.0 (2014-09-01)
                                Anton_S
                                The animation tool is a work in progress.
                                My poor planning πŸ˜† Wanted to get it all done on particular date, but got lazy and you know..
                                  Does this present version is working for the 2015?
                                  • P
                                    PituPhysics
                                    I do not work in SU 15, if only "static" groups in the model. =(
                                      Anton_S
                                      What do you mean it doesn't work in 2015? It should work just as fine in all SU versions, including the 64bit. Did you download AMS Library as a requirement for MSPhysics?
                                      • P
                                        PituPhysics
                                        Yes, I downloaded the AMS. I use a 64-bit Windows but the SU 32-bit, because the SP 3.5.
                                        This could be the problem? Install the 64-bit Sketchup? I try this. I hope it will be good. πŸ˜•
                                          Anton_S
                                          Can you tell me what exactly isn't working because it should work on 32/64 bit SU versions just fine. Do you get any errors when you start SU?
                                            Anton_S
                                            Notice, this is 0.2.0 alpha. There are many features that are work in progress and not done yet. The joint tab is one of them.
                                            I'm still skeptical why it didn't work on 32bit. I'll have to see it on my brothers laptop and see what was going on there.
                                            • 46
                                            • 47
                                            • 6 / 47
