    MSPhysics 1.0.3 (16 October 2017)
    928 Posts 171 Posters 1.3m Views 172 Watching
    • plot-parisP Offline
      plot-paris
      Very exciting stuff! 😲 Hope its getting along well...
      • dereiD Offline
        derei
        Is this project still under development, or abandoned?
        DESIGNER AND ARTIST DEREI.UK
          Before the next release you can train your Physics' skill in 2D with this incredible Algodoo! β˜€
            Anton has been pretty active in this thread up til a couple of weeks ago, so I'd think it's still live and kicking.
              Anton_S
              What Thom said
                Jesus4fun
                I am getting this... Please can someone help me? I have no idea what I did wrong or how to fix it...
                Error Loading File C:/Users/Norm/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/MSPhysics/main.rb
                Error: #<NoMethodError: undefined method require_library' for AMS::Lib:Module> C:/Users/Norm/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/MSPhysics/main.rb:8:in <top (required)>'
                C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:in require' C:/Program Files (x86)/SketchUp/SketchUp 2014/Tools/extensions.rb:197:in load'
                C:/Users/Norm/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/MSPhysics.rb:75:in register_extension' C:/Users/Norm/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/MSPhysics.rb:75:in module:MSPhysics'
                C:/Users/Norm/AppData/Roaming/SketchUp/SketchUp 2014/SketchUp/Plugins/MSPhysics.rb:57:in `<top (required)>'
                • O Offline
                  Olivier92
                  Hi Everyone,
                  This plugins looks very promising. Thank you for developping it.
                  I tried to install it on my SU 2015 64bits but apparently it will not install.
                  I guess it is because of the 64bits version is this correct?
                  If so, any change it will work on 64bits SU any time soon?
                  Kind regards
                    Jesus4fun
                    When I just tried to download MSPhysics plugin I am getting 404 error. So That is why I am asking this, Is this extension discontinued? 😞
                      Anton_S
                      MSPhysics is in alpha stage and incomplete. Version 0.1.0 relied on AMS Libary 1.x.y, which is now obsolete. That explains why you got the loading error, and why I removed the download link. Version 1.0.0 is under development and is expected to be released this year.
                        Jesus4fun
                        I can't wait to see it, test it and use it!! β˜€
                        • O Offline
                          Olivier92
                          Hello Anton,
                          "Version 1.0.0 is under development and is expected to be released this year."
                          This is great news.
                          Will this version be usable with Sketchup 64 bits?
                          Kind regards
                          Olivier
                            TonedF
                            I cannot download this...the link is dead!!
                              Anton_S
                              @Oliver92 MSPhysics will be compatible with 32 and 64 bit SU versions. Although the first version will be limited to Windows OS due to huge reliance on MSFT Windows API.
                              @TonedF Read a few posts above you.
                              • pcberdwinP Offline
                                pcberdwin
                                Fantastic update! πŸ˜„ The buoyancy plane is interesting.
                                I couldn't figure out how to record, though. I see the check box in settings but then what?
                                  Bas9999
                                  Well i have found earlier versions around on the internet and i am confused with the version numbering because it already passed v1.0.0 @ 2014-09-01..... πŸ˜‰
                                  MSPhysics - v0.1.0 (2014-04-26)
                                  MSPhysics - v0.2.0 (2014-06-26)
                                  MSPhysics - v0.2.0 (2015-04-06) ???
                                  MSPhysics - v1.0.0 (2014-09-01)
                                    Anton_S
                                    The animation tool is a work in progress.
                                    My poor planning πŸ˜† Wanted to get it all done on particular date, but got lazy and you know..
                                      Does this present version is working for the 2015?
                                        PituPhysics
                                        I do not work in SU 15, if only "static" groups in the model. =(
                                          Anton_S
                                          What do you mean it doesn't work in 2015? It should work just as fine in all SU versions, including the 64bit. Did you download AMS Library as a requirement for MSPhysics?
                                            PituPhysics
                                            Yes, I downloaded the AMS. I use a 64-bit Windows but the SU 32-bit, because the SP 3.5.
                                            This could be the problem? Install the 64-bit Sketchup? I try this. I hope it will be good. πŸ˜•
                                            • 46
                                            • 47
                                            • 6 / 47
