    Finally gone back(i mean forward) to a PC!
    127 Posts 29 Posters 30.0k Views 29 Watching
    • pbacotP
      The "problematic" issue for Mac involving CAD was probably Autodesk decided not to support Mac OS in the past. I've used PC and AutoCAD some in training, but I have used Mac since 88 for CAD. There's no problem. AutoCAD is now back on Mac to some extent, but I never wanted to use it for my work in the first place.
      • neetsN
        neets
        @numerobis said:
        http://www.maxwellrender.com/benchwell πŸ˜‰
        a 4970K should be around 10 min and ~BM450
        But you have to read the list very carfully today and compare the results and infos, because it is messed up with many bad entries without specs and info. Results of clearly overclocked machines without any info about the real clock rates - the GHz number in the Processor column only shows the stock speed.
        Thanks for this; I remember checking the Benchwell list previously but, like you've said, I was concerned about the authenticity of the specs! Oli's result might be more accurate.
        Interested to know more about me and my 3D Visualisation work? Then you want to click right here: http://anitabrowndesignstudio.com/
        • neetsN
          neets
          You're right, it did involve AutoCAD a lot and that was one of my requirements because I needed to use AutoCAD for my design studies. I appreciate that a number of issues may have been resolved but when I did my research, a lot of the feedback was that Windows was generally more straightforward when using (external) CAD/design software.
          • N
            numerobis
            @neets said:
            I'm just interested in your render times full stop! Can you do a test using Maxwell Render, to give me a better idea?
            But you have to read the list very carefully today and compare the results and infos, because it is messed up with many bad entries without specs and info. Results of clearly overclocked machines without any info about the real clock rates - the GHz number in the Processor column only shows the stock speed.
            • olisheaO
              olishea
              I don't even have or use Maxwell sorry! It's a good bit of kit though.
              oli
              • neetsN
                neets
                Ach! Darn! 😞
                • jeff hammondJ
                  @neets said:
                  Ach! Darn! 😞
                  hey neets.. i think the trick with maxwell is to set it up where you're not watching it render πŸ˜‰
                  on nearly a completely off topic tangent.. rumor has it, apple is making a self driving car.
                  • neetsN
                    neets
                    I'm guessing this is a very unsubtle remark about the time it can take for Maxwell to render??! Doesn't bother me in the slightest - the results speak for themselves πŸ˜„
                    • jeff hammondJ
                      i use indigo.. same deal
                      • jujuJ
                        juju
                        indigo FTW
                        ( I can't wait for v4.0 )
                        • olisheaO
                          olishea
                          Did a quick comparison test.
                          Obviously my new PC is faster than my old imac....but just for giggles, here is the difference in Thea Render.
                          I can't use my old Mac GPU for Thea rendering, can't be bothered finding out why, it's incompatible.
                          Mac render time CPU: 140 seconds
                          PC render time CPU: 23 seconds (7 times quicker)
                          PC render time GPU: 14 seconds (10 times quicker)
                          PC render time CPU + GPU : 10 seconds (14 times quicker)
                          @Kristoff and Stefan: Temperature maxed out at 74 Degrees Celsius when rendering a longer scene. Thermal Status: OK πŸ˜„
                          oli
                          • 7 / 7
