    Finally gone back(i mean forward) to a PC!
    127 Posts 29 Posters 19.2k Views 29 Watching
    • neetsN Offline
      neets
      @jeff hammond said:
      @neets said:
      Why are we resurrecting this Mac v PC argument again?!
      I'm not sure if there are still issues in that area for Mac.
      isn't that what you just did? πŸ˜•
      Yea, alright. Fair point. Well then, feel free to respond πŸ˜‰
      Interested to know more about me and my 3D Visualisation work? Then you want to click right here: http://anitabrowndesignstudio.com/
      • pbacotP Offline
        The "problematic" issue for Mac involving CAD was probably Autodesk decided not to support Mac OS in the past. I've used PC and AutoCAD some in training, but I have used Mac since 88 for CAD. There's no problem. AutoCAD is now back on Mac to some extent, but I never wanted to use it for my work in the first place.
        • neetsN Offline
          neets
          @numerobis said:
          http://www.maxwellrender.com/benchwell πŸ˜‰
          a 4970K should be around 10 min and ~BM450
          But you have to read the list very carfully today and compare the results and infos, because it is messed up with many bad entries without specs and info. Results of clearly overclocked machines without any info about the real clock rates - the GHz number in the Processor column only shows the stock speed.
          Thanks for this; I remember checking the Benchwell list previously but, like you've said, I was concerned about the authenticity of the specs! Oli's result might be more accurate.
          • neetsN Offline
            neets
            You're right, it did involve AutoCAD a lot and that was one of my requirements because I needed to use AutoCAD for my design studies. I appreciate that a number of issues may have been resolved but when I did my research, a lot of the feedback was that Windows was generally more straightforward when using (external) CAD/design software.
            • N Offline
              numerobis
              @neets said:
              I'm just interested in your render times full stop! Can you do a test using Maxwell Render, to give me a better idea?
              But you have to read the list very carefully today and compare the results and infos, because it is messed up with many bad entries without specs and info. Results of clearly overclocked machines without any info about the real clock rates - the GHz number in the Processor column only shows the stock speed.
              • olisheaO Offline
                olishea
                I don't even have or use Maxwell sorry! It's a good bit of kit though.
                oli
                • neetsN Offline
                  neets
                  Ach! Darn! 😞
                  • jeff hammondJ Offline
                    @neets said:
                    Ach! Darn! 😞
                    hey neets.. i think the trick with maxwell is to set it up where you're not watching it render πŸ˜‰
                    on nearly a completely off topic tangent.. rumor has it, apple is making a self driving car.
                    • neetsN Offline
                      neets
                      I'm guessing this is a very unsubtle remark about the time it can take for Maxwell to render??! Doesn't bother me in the slightest - the results speak for themselves πŸ˜„
                        i use indigo.. same deal
                        • jujuJ Offline
                          juju
                          indigo FTW
                          ( I can't wait for v4.0 )
                          • olisheaO Offline
                            olishea
                            Did a quick comparison test.
                            Obviously my new PC is faster than my old imac....but just for giggles, here is the difference in Thea Render.
                            I can't use my old Mac GPU for Thea rendering, can't be bothered finding out why, it's incompatible.
                            Mac render time CPU: 140 seconds
                            PC render time CPU: 23 seconds (7 times quicker)
                            PC render time GPU: 14 seconds (10 times quicker)
                            PC render time CPU + GPU : 10 seconds (14 times quicker)
                            @Kristoff and Stefan: Temperature maxed out at 74 Degrees Celsius when rendering a longer scene. Thermal Status: OK πŸ˜„
                            oli
                            • 7 / 7
