    Finally gone back(i mean forward) to a PC!
    127 Posts 29 Posters 18.6k Views 29 Watching
    • neetsN Offline
      neets
      Why are we resurrecting this Mac v PC argument again?! Guys, let it go! There are valid reasons to choose either (although I'm Windows All. Day. Long). When I was making a decision 4 yrs ago as to which one I would choose, I did a bit of research and found out that Mac computers were problematic when it came to design/CAD software. It was a no-brainer for me to opt for a PC. I just didn't want that risk. Could be different these days though. I'm not sure if there are still issues in that area for Mac.
      Oli, don't feel under pressure to try and illustrate ridiculous rendering times in comparison to your previous machine. I'm not interested in a comparison of that nature. I'm just interested in your render times full stop! Can you do a test using Maxwell Render, to give me a better idea? πŸŽ‰
      Anita
      Interested to know more about me and my 3D Visualisation work? Then you want to click right here: http://anitabrowndesignstudio.com/
      • jeff hammondJ Offline
        isn't that what you just did? πŸ˜•
        • neetsN Offline
          neets
          Yea, alright. Fair point. Well then, feel free to respond πŸ˜‰
          • pbacotP Offline
            The "problematic" issue for Mac involving CAD was probably Autodesk decided not to support Mac OS in the past. I've used PC and AutoCAD some in training, but I have used Mac since 88 for CAD. There's no problem. AutoCAD is now back on Mac to some extent, but I never wanted to use it for my work in the first place.
            • neetsN Offline
              neets
              @numerobis said:
              http://www.maxwellrender.com/benchwell πŸ˜‰
              a 4970K should be around 10 min and ~BM450
              But you have to read the list very carfully today and compare the results and infos, because it is messed up with many bad entries without specs and info. Results of clearly overclocked machines without any info about the real clock rates - the GHz number in the Processor column only shows the stock speed.
              Thanks for this; I remember checking the Benchwell list previously but, like you've said, I was concerned about the authenticity of the specs! Oli's result might be more accurate.
              • neetsN Offline
                neets
                You're right, it did involve AutoCAD a lot and that was one of my requirements because I needed to use AutoCAD for my design studies. I appreciate that a number of issues may have been resolved but when I did my research, a lot of the feedback was that Windows was generally more straightforward when using (external) CAD/design software.
                • N Offline
                  numerobis
                  But you have to read the list very carefully today and compare the results and infos, because it is messed up with many bad entries without specs and info. Results of clearly overclocked machines without any info about the real clock rates - the GHz number in the Processor column only shows the stock speed.
                  • olisheaO Offline
                    olishea
                    I don't even have or use Maxwell sorry! It's a good bit of kit though.
                    oli
                    • neetsN Offline
                      neets
                      Ach! Darn! 😞
                        @neets said:
                        Ach! Darn! 😞
                        hey neets.. i think the trick with maxwell is to set it up where you're not watching it render πŸ˜‰
                        on nearly a completely off topic tangent.. rumor has it, apple is making a self driving car.
                        • neetsN Offline
                          neets
                          I'm guessing this is a very unsubtle remark about the time it can take for Maxwell to render??! Doesn't bother me in the slightest - the results speak for themselves πŸ˜„
                            i use indigo.. same deal
                            • jujuJ Offline
                              juju
                              indigo FTW
                              ( I can't wait for v4.0 )
                              • olisheaO Offline
                                olishea
                                Did a quick comparison test.
                                Obviously my new PC is faster than my old imac....but just for giggles, here is the difference in Thea Render.
                                I can't use my old Mac GPU for Thea rendering, can't be bothered finding out why, it's incompatible.
                                Mac render time CPU: 140 seconds
                                PC render time CPU: 23 seconds (7 times quicker)
                                PC render time GPU: 14 seconds (10 times quicker)
                                PC render time CPU + GPU : 10 seconds (14 times quicker)
                                @Kristoff and Stefan: Temperature maxed out at 74 Degrees Celsius when rendering a longer scene. Thermal Status: OK πŸ˜„
                                oli
                                • 7 / 7
