    [Plugin] Faster OBj Export
    14 Posts 9 Posters 3.6k Views 9 Watching
      Jim
      Export .obj? Give this a try and let me know how it works.
      It's available through the PluginStore.
      http://sketchucation.com/pluginstore?pln=faster_obj_exporter
      This exporter groups the .obj by material.
      Textures are not supported, but colors are.
      Groups/Instances are not considered.
      Works on selection, or entire model.
        Jim
        Update v1.1 with small tweaks hardly worth mentioning.
        80,000 verts in 10 seconds is not terrible.
        Here's a screenshot because who doesn't love screenshots, amiright? (Model)
          driven
          on my mac Pro export, single sided took much longer than that...
          SketchUp Entities processed:
          20 Groups
          487 Instances
          86215 Faces
          4 Materials
          OBJ Entities exported:
          92096 Faces
          4 Materials
          do you want the file to compare with yours?
            Jim
            Versions 1.2 - Swatting bugs and swapping axes; YZ axes, that is.
              Ridie1389
              Exceptional exporter! I can actually import models into Zbrush from SketchUp without them being almot completely unusable. Thank you!
                Jim
                Hehe, cool! I'm happy you found it useful. Thanks for the feedback.
                  What about the triangulation of faces into ZBrush, does easy possible to quadrangularize the file exported inside ZB or subdivide?
                  • StinkieS Offline
                    Stinkie
                    Mmm, looks good. Thanks! πŸ˜„
                    • E Offline
                      Eyesights
                      To which folder shall i paste this plugin?
                        jedibri66
                        installed, but however nothing happens when i export. just goes back to the model.
                          paguthrie
                          Finally an exporter that works!
                          Would it be possible to add texture coordinate exporting? Then it would be perfect.
                          Thanks, peter
                          • Rich O BrienR Online
                            did you try Fluid OBJ Importer?
                              paguthrie
                              and does it export as well as import?
                                Ahhh. i read import.
                                you want export to obj with textures.
                                Then i would recommend ThomThom QuadFace tools. It has a great OBJ exporter with textures.
