πŸ€‘ SketchPlus 1.3 | 44 Tools for $15 until June 20th Buy Now
[Plugin] Faster OBj Export
14 Posts 9 Posters 3.3k Views 9 Watching
    Jim
    Export .obj? Give this a try and let me know how it works.
    It's available through the PluginStore.
    SketchUp Plugins | PluginStore | SketchUcation
    SketchUp Plugin and Extension Store by SketchUcation provides free downloads of hundreds of SketchUp extensions and plugins
    (sketchucation.com)
    This exporter groups the .obj by material.
    Textures are not supported, but colors are.
    Groups/Instances are not considered.
    Works on selection, or entire model.
      Jim
      Update v1.1 with small tweaks hardly worth mentioning.
      80,000 verts in 10 seconds is not terrible.
      Here's a screenshot because who doesn't love screenshots, amiright? (Model)
        driven
        on my mac Pro export, single sided took much longer than that...
        SketchUp Entities processed:
        20 Groups
        487 Instances
        86215 Faces
        4 Materials
        OBJ Entities exported:
        92096 Faces
        4 Materials
        do you want the file to compare with yours?
          Jim
          Versions 1.2 - Swatting bugs and swapping axes; YZ axes, that is.
            Ridie1389
            Exceptional exporter! I can actually import models into Zbrush from SketchUp without them being almot completely unusable. Thank you!
              Jim
              Hehe, cool! I'm happy you found it useful. Thanks for the feedback.
                What about the triangulation of faces into ZBrush, does easy possible to quadrangularize the file exported inside ZB or subdivide?
                  Stinkie
                  Mmm, looks good. Thanks! πŸ˜„
                  • E Offline
                    Eyesights
                    To which folder shall i paste this plugin?
                      jedibri66
                      installed, but however nothing happens when i export. just goes back to the model.
                        paguthrie
                        Finally an exporter that works!
                        Would it be possible to add texture coordinate exporting? Then it would be perfect.
                        Thanks, peter
                          did you try Fluid OBJ Importer?
                            paguthrie
                            and does it export as well as import?
                              Ahhh. i read import.
                              you want export to obj with textures.
                              Then i would recommend ThomThom QuadFace tools. It has a great OBJ exporter with textures.
