    [Plugin] Faster OBj Export
    14 Posts 9 Posters 4.2k Views 9 Watching
      Ridie1389
      Exceptional exporter! I can actually import models into Zbrush from SketchUp without them being almot completely unusable. Thank you!
        Jim
        Hehe, cool! I'm happy you found it useful. Thanks for the feedback.
          What about the triangulation of faces into ZBrush, does easy possible to quadrangularize the file exported inside ZB or subdivide?
          • StinkieS Offline
            Stinkie
            Mmm, looks good. Thanks! πŸ˜„
            • E Offline
              Eyesights
              To which folder shall i paste this plugin?
                jedibri66
                installed, but however nothing happens when i export. just goes back to the model.
                  paguthrie
                  Finally an exporter that works!
                  Would it be possible to add texture coordinate exporting? Then it would be perfect.
                  Thanks, peter
                    did you try Fluid OBJ Importer?
                      paguthrie
                      and does it export as well as import?
                        Ahhh. i read import.
                        you want export to obj with textures.
                        Then i would recommend ThomThom QuadFace tools. It has a great OBJ exporter with textures.
