    Why the ruddy Dongle?
    renderpluginsextensions
    23 Posts 12 Posters 5.9k Views 12 Watching
    • StinkieS
      Stinkie
      @chippwalters said:
      There will always be pirates and ANY software can be cracked. Please, companies, have a bit more respect for your customers and use other, more serviceable means to protect your intellectual property!
      Hear, hear. πŸ‘
      • dkendigD
        dkendig
        Our software licensing was worse than dongles by a long shot. It was great when it worked... sometimes... The dongle should be pretty simple to work with. If you do a typical install (not unchecking anything), it should just work. It's kind of a pain to carry around a usb dongle, so I just plug it into a machine and point my laptop at it. The dongle can be public facing as well, so you don't even have to be on the same network as the machine that has the dongle plugged in (or you can just vpn in if you have a vpn set up). I have heard of some users having a little difficulty, but typically that's due to a faulty install of some sort (not saying this is the customer's fault, installs don't always go according to plan for a variety of reasons), or the license server not running for whatever reason.
        We are aware that it's possible to steal the product, and that we shouldn't punish our customers... but the dongle licensing is SIGNIFICANTLY easier to troubleshoot/fix, it's mobile, and it doesn't require someone at our company to manually process a request to simply REINSTALL the product (on the same computer), like our software licensing did. You should have seen the difference in our support inbox once we switched licensing to dongles. It's extremely obvious that the dongle licensing is less prone to error. I think you guys either missed how awful our old licensing was, or haven't tried setting up a floating license server with the current dongle licensing.
        Devin Kendig
        Developer
        • chippwaltersC
          chippwalters
          So your defense of using a hardware dongle is that your previous software solution was bad? Perhaps you should look how your competitors solve the problem. There are still too many significant problems with hardware dongles, including how to instantly replace lost or damaged ones, for my company to seriously consider it.
          Currently working with Cross-Reality technologies
          • dkendigD
            dkendig
            Defending? No, just pointing out the outcry about difficulty licensing, occurred after we took steps to resolve the issue. Licensing our product is easier, and more reliable than it ever has been. Offline licensing is a cinch now, you don't have to worry about network communication issues in a corporate environment anymore, you can reinstall our product without having to shoot us an email, licensing doesn't suddenly stop working out of the blue due to a software update, etc. Not to mention issues with international customers not being able to reach our license server due to region restrictions, or the shear lag in the communication (not everyone lives in the US). The dongle licensing system is time tested, corporate IT guy approved, and is what we use for every other flavor of V-Ray.
            I'm not saying that having a little piece of hardware that you have to worry about (to some degree at least) isn't a pain at all, but I don't believe it's deserving of so much pushback. You could have hundreds of seats on the one dongle, and serve it out across an entire company, or you can have one seat and carry it in your laptop bag. The only legitimate argument I have heard against dongles, is that if you lose or damage it, you will have some downtime while waiting for a new dongle. As a laptop user myself, I can certainly understand the "struggle" of only having 2 usb ports (which hopefully both work), but aside from the initial frowny face I made when plugging that dongle into the usb hub it now resides in, I haven't even had to think about that little dongle ever since.
            I understand that other software uses other means to protect their intellectual property as well, and sometimes, in some situations, their solutions work really well. The same can be said for our old software based licensing and our current dongle licensing. It all depends on your setup.
            chippwalters: I would be interested in hearing what your significant issues are with dongle licensing, perhaps there are some items on your list that we could address. If you are stuck using an older version of our product, because of your concerns with dongle licensing, you are really missing out, and I would like to fix that asap.
            Devin Kendig
            Developer
            • dkendigD
              dkendig
              Licensing just keeps honest people honest. We are fully aware of this fact. That's why we switched to dongles, it protects our IP and is easier to work with than our previous licensing method.
              Devin Kendig
              Developer
              • chippwaltersC
                chippwalters
                There are so many problems, I just don't know where to start. Let's see, first off I work both at home and at the office. My commute is 45 minutes 1 way into work. If for some reason I forget the dongle, I'm up the creek with out a..dongle.
                Next, I don't have lot's of available ports on my computer, and I really don't want to add a whole mess of wires of a USB hub just for a stupid dongle-- which is a physical reminder the company I've chosen to do business with doesn't trust me.
                Don't get me started on the whole "lose dongle" issue. One time a dongle I was using quit working. I had to send it back to the company and they sent me a new one-- 3 days after it quit working I could get back to work. That wasn't the end of the horror story. The next week I received an email from their lawyer threatening a lawsuit because in their opinion the dongle malfunctioned only because I was trying to 'hack' it. Really??? A month later I received another email telling me they were sorry, but that there was some sort of virus going around which 'corrupted' dongles. Sheesh! That was the very last time I ever paid for a dongle.
                I quit using Lightwave because of hardware dongles (different company than the previous one mentioned) and started back using it when their license protection became software only. I own KeyShot, Lightwave, FormZ, Thea, SU Pro, MoI3d and a host of other powerful and more or less expensive 3D programs than yours and NONE have a dongle.
                I'm betting you guys are out of the dongle business in a year. I can't imagine paying customers will continue to put up with it...especially since there is so much competition in the rendering space. I'll review your offering again when you get rid of the hardware protection.
                • andybotA
                  andybot
                  Don't count on it. Like Devin said - all the other versions of vray are dongle licensed, and have been for much longer than vfs.
                  That does sound like a pain that you have to use the dongle at home and at work, with the commute in between. 😞
                  • chippwaltersC
                    chippwalters
                    @krisidious said:
                    V-Ray was famously pirated... like autocad. it's not you they don't trust. it's the pirates who hack it.
                    A Google search for "cracked vray" gives "About 364,000 results." My guess is there's a version out there which is cracked.
                    dkendig was correct about one thing: "Licensing just keeps honest people honest."
                    Then he also said,
                    @dkendig said:
                    ...but the dongle licensing is SIGNIFICANTLY easier to troubleshoot/fix, it's mobile, and it doesn't require someone at our company to manually process a request to simply REINSTALL the product (on the same computer), like our software licensing did. You should have seen the difference in our support inbox once we switched licensing to dongles.
                    I thought this argument on how much easier it is for Vray's support was a specious one. As a customer, I'm particularly concerned a company is wiling to trade off hardship for their customer (dongle) to make things easier for themselves. I can't imagine it's too difficult for a company support staff to manage licensing. Somehow, someway, other companies seem to be able to conquer this task without too much of a hurdle.
                    IMO as a software developer who has designed copy protection systems, I'm of the following opinions:
                    1. No copy protection is perfect.
                    2. Someone WILL crack your software, somewhere at sometime.
                    3. True pirates will NEVER pay for software. So you lose not a single sale to those guys.
                    4. The real goal is make it difficult for HONEST people to use unlicensed software. Licensing with nothing more than a serial number without limits on the number of licenses DOES NOT do this. It needs to be more difficult than just passing a serial number around.
                    5. OTOH, the license shouldn't be too restrictive that a penalty is paid each and every time one uses the software. Hardware dongles IMO fail this test.
                    FWIW, there are many folks who have elegantly solved this problem, Luxion KeyShot is one of them. I can license it on two computers, any more and it won't work and I have to contact tech support. Over the holidays, I retired an old machine and purchased a new one. I also had a deadline on a project and forgot about the 2 computer limit. When KeyShot wouldn't license (in the middle of the night), I sent an email to support and had a new license number the next hour. Can't ask for quicker turnaround than that!
                    Another strategy I have seen involves embedding the buyers email address in the software license. This way if someone gives it out, they are giving their email address along with it. Not perfect, but it will deter many 'honest' users from consciously 'giving away' the software.
                    Sure, you can expend tons of development and support resources, including forcing your users to buy a dongle and forever tether them to you physically. But for me, I'd rather see the time you guys spend trying to force an antiquated copy protection scheme to rather be spent on making the render engine faster or more robust. Just my 2 cents.
                    • andybotA
                      andybot
                      Did you look into the option Devin mentioned about using VPN from your office to host a license server you can grab from your home? Seems like that could solve the physical issue.
                      • chippwaltersC
                        chippwalters
                        Hi Andy, thanks for your concern. I do not own a dongle or a copy of V-Ray. I was looking into purchasing a copy for some work I'm doing as my research showed it to be a good solution, but the very existence of a dongle was a deal killer for me.
                        And, FWIW, hanging the hardware dongle on a physical machine in another location seems quite the hassle. VPN's can be so clumsy and slow. Seems to me it would be better if V-Ray just hung everyone's hardware dongle on their servers and then there would never be a hardware issue! πŸ˜„
                        • dkendigD
                          dkendig
                          We are always working on improving the experience. I can agree that VPN's aren't fantastic, if you're sending all traffic through them. Otherwise though, it's not a big hassle if you have a half decent IT guy around the office. I'm not suggesting you set up a VPN solely to run a V-Ray license server though, that's absurd. I merely mentioned it because it's extremely common in situations where you have employees that work from home.
                          If you are in a situation where you occasionally work from home (and need to be able to render), are unable to carry a dongle with you to and from the office, are unable to utilize a vpn to communicate with a central license server, are unable to expose a license server publicly, and unable to have a dongle for home and another for the office, then I would say the only option for your unique situation is a software based license, like the one we recently moved away from.
                          A google search isn't needed to know that our product is often pirated. We kick pirates off of this site quite frequently. I tip my hat to the competitors that were able to find a software based solution that worked for them. Being able to give a user instant access to the product, and the ability to instantly fix licensing issues is a great superpower to have.
                          ... interesting way to interpret what I said... Are you suggesting it's better to have a licensing system that requires users to call or email us to the point where we need to employ a small fleet of support staff? Our support email volume plummeted by at least 30% after switching to dongles... because they're easy, they're reliable, and require very little interaction with us. You can drop us a line if you want, but our goal was to make it so you wouldn't need to. If you're trying to link our dongle licensing, and the availability of pirated versions of our product, I'm afraid you're barking up the wrong tree there, we haven't noticed any spikes in piracy (we're watching 😲 ).
                          Devin Kendig
                          Developer
                            josephskibba
                            Hello -
                            I was wondering if I could "reprogram" a mini usb (flash drive) and use it as the Vray dongle?
                            I'm on a laptop and it would be super nice to utilize something smaller. Working from home, at the office or in a client's office it's terribly inconvenient to always be locating, plugging in the dongle and then starting up the license software. What if other software packages required a dongle? I love Vray, but this is extremely annoying.
                            Thanks in advance,
                            Joe
                            • TedVitale_CGT
                              TedVitale_CG
                              @josephskibba said:
                              Hello -
                              Thanks in advance,
                              Joe
                              Sorry Joe, In the future we will move away from the Dongle but for 2.0 you're stuck with it. However, you can set it up as an on-line licensing system and host it from a home computer or work machine. Email us at support@chaosgroup.com and write in the header Attn: Ted Vitale and I can get you somebody who can walk you through the process if thats something you would like to pursue.
                              Ted Vitale
                              Owner | Creative Director
                              http://www.voxl.vision
