    [Plugin] Sketchup Ivy
    732 Posts 172 Posters 312.9k Views 172 Watching
    • N Offline
      nalibo007
      please i need help..mine is not appearing under plugins and i have pasted it exactly in the plugins folder. iam currently using sketch up pro 2013.....a help wii be appreciated.
      • massimoM Offline
        massimo Moderator
        I don't have this plugin, but in the first post you can see that it should work fine in SU 8-2015 versions. Please don't past anything. Download the .rbz from the first post of this thread (the big button) instead and install it within SU by going to window-->preferences-->extensions-->install extension.
          You have v2013 of SketchUp...
          You do NOT 'paste' anything into the Plugins folder.
          Use Preferences > Extensions > Install.... button to extract the contents of the RBZ file into the correct Plugins folder - all done automatically.
          Since v8 this is the correct way to install RBZ archived plugins...
          Most plugins come in that format - there is no need to ever open you Plugins folder !
          Manually extracting and pasting files is a sure way of ruining your day...
          ALSO, please be aware that not all plugins appear in the Plugins menu [aka Extensions menu in v2015]
          In this case, the 'LiveIvy' tool appears under the Draw menu, and there is also a Toolbar of the same name too...
            rhott311
            Thanks! Great Work! Can confirm the plugin is working in OSX Yosemite in sketchup 8.
              There's an update...
              http://sketchucation.com/pluginstore?pln=SketchupIvy
              It only affects a few users with older versions of SketchUp etc.
              It should now be glitch free in all versions from v8 to v2015...
              • KrisidiousK Offline
                Krisidious
                Thanks TIG...
                By: Kristoff Rand
                • ChisainaC Offline
                  Chisaina
                  TIG,thank you for the work, but in the 15 SU 64 prะพblem with leaves, they are going one on one in one place. Although before generatsiey crosses marked as before, around the trunk.
                  Change please as possible this bug. Thank U. And Prastio of language, the use of the machine.
                    Thanks for the bug-report. ๐Ÿ˜•
                    It was an easy to find typo, although I can't see how it ever happened !
                    The latest version is available here http://sketchucation.com/pluginstore?pln=SketchupIvy I have checked it and it seems to work OK again...
                    ๐Ÿ˜’
                    • ChisainaC Offline
                      Chisaina
                      TIG, Thanks for the speed
                      • cottyC Offline
                        cotty
                        For me, only the toolbar and not the draw menu entry is working.
                        my SketchUp gallery
                          Another great bug-report...
                          Well spotted !
                          It's now fixed.
                          Here's the update http://sketchucation.com/pluginstore?pln=SketchupIvy
                            maxosmedia
                            Bug. As before.
                            SHIFT+Click: Created only one branch. No leaves
                            Mac OS X 10.9.5, SU 2015
                              @maxosmedia said:
                              Bug. As before.
                              Is this with the very latest version from yesterday ?
                              Have you tried it with the Ruby Console open ?
                              Does it show the magenta branches [Click] ?
                              Does it show the green X markers for the leaves [when Alt+Click MAC] ?
                              On Shift+Click what happens ?
                              Any error messages ?
                              • OxerO Offline
                                Oxer
                                On OS X 10.10.2 & SU2015 if you have Shift locked the plugin doesn't work, see if you have Shift unlocked because for me the plugin works fine.
                                  Good tip Oxer. โ˜€
                                  If you have Shift locked you can't hold it + click to complete the Ivy ?
                                  Works for other MAC users, so please try Oxer's suggestion...
                                    maxosmedia
                                    โ€”Y
                                    โ€”Y
                                    โ€”Y
                                    โ€”Y
                                    โ€” Created only one branch. No leaves
                                    โ€”N
                                    • cottyC Offline
                                      cotty
                                      Well spotted !
                                      It's now fixed.
                                      Fix confirmed. Thank you!
                                      my SketchUp gallery
                                        โ€”Y
                                        โ€”Y
                                        โ€”Y
                                        โ€”Y
                                        -N
                                        Have you followed Oxer's advice about [un]locking-shift_key ?
                                        You can also mess up some key-pressing if some aspects of the MAC's keyboard are mis-set !
                                        Many other MAC users [including me !] have no issues... so it must be solvable... ๐Ÿ˜’
                                          maxosmedia
                                          SU 2014 Sketchup Ivy works fine, SU 2015 โ€” bugs. On the same machine, on the same system, at the same time. keyboard and the keys are not modified
                                            This is very weird. ๐Ÿ˜•
                                            There is no discernible difference between v2014 and v2015 Ruby, and the code is just the same on both !
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 36
                                            • 37
                                            • 19 / 37
