    Label from Component Attributes
    Scheduled Pinned Locked Moved Dynamic Components
    6 Posts 4 Posters 1.9k Views 4 Watching
    • bmikeB Offline
      bmike
      Is there a way to build a text label (custom attribute) from component attributes?
      I'd like to create a component that had a 'TimberSize' label as a custom attribute.
      This attribute would be 'LenX'x'LenY' - it would report back 8x10 or 7.5x9.5 or 2x4.
      Note that I don't care if the 'x' is another character.
      I could then make use of the LayOut leader tool to speed up my labeling of timber / framing components.
      • bmikeB Offline
        bmike
        OK, so I can get this to work if I use the CONCATENTATE fucnction - but if I edit the component and push pull it does not update the field unless I force a component Redraw from the menu.
        Any other way to do this?
        • ithilI Offline
          ithil
          Hi Bmike! Try this script.
          Maybe this is what you are looking for.
          http://stroyka.in/viewtopic.php?f=4%26amp;t=2402%26amp;start=15#p38132
          Ithil_SizeToName.rar
          run: Plugins >> Ithil Tools >> Size To Name
          skp2015: Extensions >> Ithil Tools >> Size To Name
          • JQLJ Offline
            JQL
            Hi Ithil,
            This seems a very useful script. You should post a new Topic under Extensions/Plugins thread and submit it to Sketchucation Plugin Store. It's difficult for me to understand the Google translated Russian page but it seems you have a few hidden gems there.
            Wouldn't you want to share them here too?
            www.casca.pt
            Visit us on facebook!
            • bmikeB Offline
              bmike
              Thanks for the link to the script. What is a RAR file?
              • TIGT Online
                A RAR file is a compressed file like a ZIP.
                You can uncompress it with many un-compression apps.
                Perhaps your regular ZIP/unZIP tool can cope with it ?
                Otherwise get an app that can...
