    Problems with a half-torus
    156 Posts 11 Posters 35.6k Views 11 Watching
      d12dozr
      Superb, Teig! It's neat to watch your progression from the beginning of the thread to now πŸ‘
      http://goo.gl/f7ooYh
      • BoxB
        Indeed is is good to see.
        Have you thought about a keyhole type slide fitting.
        Slide it on and a simple quick release split pin to lock it.
        • TeigT
          Teig
          Or R-pins for more simplicity? Yes, good idea. I've been looking around at plastic snap-clips for ideas but that might be simpler.
          • TeigT
            Teig
            I did that myself at the weekend, looked back to the start of the thread that is, my comical first-attempts put a smile on my face πŸ˜„
            • TeigT
              Teig
              I'm not sure what you had in mind Box, but I've knocked this together as a concept, can anyone see why it wouldn't work?
              Split pin Catch.skp
              I know the split pin isn't long enough but I can't figure out how to stretch it and it's only for demo.
              • TeigT
                Teig
                An hour later and I've managed to attach the clips to my model:
                Solid Inspector2 is reporting them as solid, SolidSolver is saying I need to select one or other. How would I go about combining the three components into one solid?
                Elbow for Catch System.skp
                  Assuming the main part is a solid [group it and see its Entity Info...] you'll need to 'merge' the 'clips'
                  Note:
                  The 'clip' on the right is not in the same relationship to the pipe as the left 'clip'.
                  I assume it should be...
                  Also the back edge of the clips intersect oddly with the pipe-part and their backside radius does not match the pipe's either [see image] - it will mean far more tweaking later on...
                  Fix those and then with the parts in the same context use 'intersect'.
                  You should then be able to use SolidInspector/SolidSolver OR add a SectionPlane to look inside and erase the unwanted faces/edges.
                    d12dozr
                    Even easier than using Intersect with Model would be to make the elbow a solid group, the select all 3 groups, Right Click > Outer Shell to combine them into a solid group.
                      But, isn't that a Pro only Solids feature ?
                      • jeff hammondJ
                        outer shell is in suFree8 and suMake.. it's the only solid tool which is in both free and pro versions.
                        (it's the same thing as Union in suPro.. though for whatever reason, i find it more reliable than union in pro so i use outer shell.. but really, i can't figure out why suPro includes both OuterShell and Union πŸ˜‰ )
                        EDIT
                        well, apparently there is a difference:
                        http://help.sketchup.com/en/article/1004163
                        The result of an outer shell is similar to the result of a union. However, the result of an outer shell can only contain external faces while the result of a union can also contain internal geometry.
                        there's an example image of the difference between the two at that link.. i guess i've never encountered a situation which would require union vs outerShell.
                          Of course you are correct ! πŸ˜’
                          But as you point out 'outer_shell' removes all internal 'holes', so it's dangerous if your group is a say a 'nutshell' form [with a 'wall'] as its inner faces will be removed.
                            d12dozr
                            When they introduced Outer Shell in SU 8, it was for the home 3D printing crowd so they included it in the free versions. It does indeed remove all internal geometry, which is what you usually want for 3D printing. If there is internal geometry not connected to the outside at all, then it usually is not needed for printing anyway.
                            It is one of the features I use the most for making 3D printable models.
                            • TeigT
                              Teig
                              Thanks `again folks πŸ˜„
                              Note:
                              Well it was solid at some point, it just isn't now... πŸ˜• The clips were meant to be in the same relative places but of course I do it the amateurish way: by 'feel' πŸ˜„
                              I set the outer radius of the elbow to the same as the inside of the clip - 27.2mm - but unfortunately they didn't match up 😒
                              I've moved the clips 'in' so there's no gaps between them and the 'body' so I hope that works.
                              I seem to have some very weird anomalies going on at the back of the elbow, also under the 'front'. What are they, why did they suddenly appear when I ran SolidSolverand how the begorra do I get rid of them?
                              My mate's been on the blower, says split pins aren't easy enough, he want snap-clip type things, I'll have to search around t't interweb for ideas.
                                d12dozr
                                @d12dozr said:
                                ...you can use Netfabb Basic to quickly decimate (reduce the # of polygons) an existing model with out having to re-draw the whole thing.
                                Here's how: open model in Netfabb, Right click > Level of Detail > Choose something like 50%.
                                I just learned that this decimation is visual only, and you can't save the decimated model. D'oh!
                                  d12dozr
                                  Looks like the follow me path was too sharp for that size of profile. You can select the elbow geometry > Right click > Intersect selected, then clean up the internal geometry - or make the bend not so sharp, and then you won't get the nasty intersecting geometry.
                                  • BoxB
                                    This is what I meant by a keyhole fitting.
                                    With a good fit you should be able to use a simple twist on twist off with any sort of pin to lock it in place. Since you are printing them the flanges should match up on all of them, just change the bell mouth in the models. The hole fittings could be printed and the T piece of the fitting could be a nice round head bolt screwed into the print material.
                                    • TeigT
                                      Teig
                                      That's a classy idea Box, if I could get them to lock on tightly that could be a beaut of a way of doing it. Back to the laptop to try to do what Marcus is advising and draw your 'keyholes' up. πŸ˜„
                                      • BoxB
                                        If you print the slot part of the hole with a slight taper as you twist it on it will tighten.
                                        And using a threaded bolt will allow you to tighten the fit as necessary. Thin smear of cured silicone on the face as a washer and one hole drilled through for a locking pin.
                                        • TeigT
                                          Teig
                                          Good idea. I spent 30 mins trying to figure out Marcus' words of wisdom and failed so I've started drawing it again. After 2 hours of intensive drawing I've run into the intersect problems again though, SolidSolver has been working on it for the last 10 minutes, I predict failure. I'll go away and try to see how this 'intersect with selection' works. πŸ€“
                                          • 8 / 8
