    Diagonal line to make face
    10 Posts 3 Posters 704 Views 3 Watching
      Rudbeckia
      Hello SU
      I have some ramps I have drawn and to close the face of the surface of the ramp, I am having to draw a diagonal line from corner to corner. When I do that the face completely closes at all 4 corners. When I then erase the diagonal the whole face disappears....any ideas on what is happening here?
      • bazB Offline
        baz
        Most likely, your ramp is not planar. If that is necessary to your design, then simply hide the diagonal. Otherwise redraw ensuring that all four lines are exactly parallel to each other.
          Rudbeckia
          Thanks.
          If its not planer, wouldn't the face only close where it is? Meaning if I drew a diagonal only part of the face would close letting me know where the problem is. But the whole face closes....as if there is no problem
          • bazB Offline
            baz
            You have 4 lines right?. Mark them A,B,C,D. With the addition of the diagonal line E, you are making two triangles, each of whose 3 lines are parallel. So AB and E are planar and CD and E are planar. A is not parallel to to C or D. And neither is B parallel to C or D.
            I might be making it too complicated...
            ...Draw two triangles, in plan view, move them together to form a rectangle, delete the diagonal, voila.
              Rudbeckia
              Okay this might be a dumb question but how can AB be parallel to E and CD be parallel to E but AB is not parallel to CD
              • bazB Offline
                baz
                Post the model, might be easier to explain then.
                  Rudbeckia
                  here it is
                  ramp.skp
                    slbaumgartner
                    I don't know what process you followed to draw your ramp, but none of the sloped quadrilaterals are planar! They can not be represented by a single Face.
                    • bazB Offline
                      baz
                      For such a simple looking model it's actually quite complicated! Your landings are planar but none of the ramps are. Because none of your geometry is rectangular.
                      Bottom line with this design is non-planar ramps. And hide the diagonals.
                      Also remember to group each ramp and landing. (Which I have done on your model)
                      ramp_baz.skp
                        Rudbeckia
                        thanks so much for the help!
