    Component axis problem
    18 Posts 5 Posters 1.8k Views 5 Watching
    • PixeroP Offline
      Pixero
      Does anyone know how to do this?
      • X Offline
        XorUnison
           comp = group.to_component
        ↑ Here you take an existing group and turn it into a component,
        mind you, it still is in the drawing
           entities.add_instance(compdef,trans)
        ↑ Here you add a second component based on the definition of the first one
        If you only want one component you'll either have to delete the first one,
        or don't create the second one and move the first one to the point where you want it
        instance = (compdef.name = "MyComponent")
        ↑ Here you set instance to the string "MyComponent"
        However you can't fetch a component like that by it's name, you need the link to the instance. You don't need this line.
        The moment you create the instance you get the link to the created instance, just catch it like that:
           instance = entities.add_instance(compdef,trans)
        Tip: You can try reading out what you got by putting "puts instance" afterwards, the result should look like this: #Sketchup::ComponentInstance:0xXXXXXXXX
          You already have an instance of the component definition when you make the conversion of group to component.
          The comp refers to its instance.
          The compdef refers to its definition.
          If you want to rotate/move that component's axes do this...
          If necessary...
          Get the transformation of the current instance [ tr]. Use compo.transform!(tr.inverse) to relocate it at the origin.
          Make the transformation needed to make the change[s] to the axes [ tr2].
          Apply that transformation thus: compo.transform!(tr2)
          Immediately apply that transformation to the definition thus:
          compdef.entities.transform_entities(tr2.inverse, compdef.entities.to_a)
          The instance should now appear as it was before, but the axes have changed...
          If approapriate...
          Use compo.transform!(tr) to move the group back where it was when you started...
          • PixeroP Offline
            Pixero
            Thanks for this both of you. I will try this as soon as I get a chance.
            • PixeroP Offline
              Pixero
              Not sure why I'm having such a hard time getting this right but following TIGs guide, the Components BoundingBox/selection box remains unrotated until I open the component to edit. After exiting out of the edit component mode, the selection box is properly rotated, even though I still have some work left to get the component axis where I want it... πŸ˜• Coding can be sooo frustrating...
              • X Offline
                XorUnison
                That's what I thought during my first month or so, but eventually it gets a lot easier as you learn how Sketchup and Ruby work.
                I don't know that phenomenon personally but I think it might be related to the component not being refreshed properly. You could try to redraw it:
                   dcs = $dc_observers.get_latest_class
                   dcs.redraw(entity,progress_bar_visible=false,is_recursive_call=false)
                  Sorry, I rushed out the code snippets...
                  You also need to do a compdef.invalidate_bounds
                  after the changes, inside the model.start_operation...commit block, to make it change visually !
                  http://www.sketchup.com/intl/en/developer/docs/ourdoc/componentdefinition#invalidate_bounds
                  • PixeroP Offline
                    Pixero
                    Now I got the rotation of the boundingbox working as it should.
                    However the transformation of the components axis is still at origo.
                    Rotated correctly but not transformed.
                    I must still be missing something? πŸ˜•
                    tr = comp.transformation
                    rotvector = pt1-pt0
                    originvector = Geom;;Vector3d.new(1,0,0)
                    angle = rotvector.angle_between originvector
                    wfc.transform!(tr.inverse)
                    tr2 = Geom;;Transformation.rotation(ORIGIN, Z_AXIS, angle)
                    comp.transform!(tr2)
                    comp.transform!(tr)
                    • sdmitchS Offline
                      sdmitch
                      > rotvector = pt1-pt0
                      > comp.transform!(tr)
                      Did you ever get this figured out?
                      Here is what I came up with.
                      mod = Sketchup.active_model
                      ent = mod.active_entities
                      sel = mod.selection
                      grp = ent.first; #<--For test purposes
                      cmp = grp.to_component
                      cd = cmp.definition; cde = cd.entities; ct = cmp.transformation
                      cmp.transform! ct.inverse
                      org = cmp.bounds.corner(0)
                      #rotvector = pt1-pt0
                      #originvector = Geom;;Vector3d.new(1,0,0)
                      #angle = rotvector.angle_between originvector
                      #angle = -angle * (rotvector.y<=>0)
                      angle = -30.degrees #<--For test purposes
                      tr0 = Geom;;Transformation.rotation(org,Z_AXIS,angle)
                      cde.transform_entities(tr0,cde.to_a)
                      bb = Geom;;BoundingBox.new()
                      cde.each{|e| bb.add e.bounds}
                      org = bb.center
                      tr1 = Geom;;Transformation.new(org)
                      cde.transform_entities(tr1.inverse,cde.to_a)
                      cmp.transformation = cmp.transformation * tr1
                      cmp.transform! ct * tr0.inverse
                      cd.invalidate_bounds
                      http://sdmitch.blogspot.com/
                      • PixeroP Offline
                        Pixero
                        Yes I figured it out. Thanks anyway.
                        • PixeroP Offline
                          Pixero
                          I have found a bug in my script that causes errors when drawn at certain angles.
                          When less than 90 degrees the angle needs to be negative and that works well with this fix but when it is 90 degrees or -90 degrees I cant seem to find a way of getting it correct without overwriting the values. Any clues how to do this?
                          def set_origin(compdef, compinst, pt0, pt1, pt3)
                          	tr1 = compinst.transformation
                          	rotvector = pt1-pt0
                          	org = pt3
                          	if angle < 90.degrees
                          		angle2 = -angle
                          	elsif angle > 90.degrees
                          		angle2 = angle
                          	end #if
                                  # This part don't trigger when it's not exactly 90 degrees.
                                  # If its just below or above but not enought to be caught in the <90 or >90.
                                  # 90.00000000000007 doesn't trigger it. (1.570796326794898 in radians)
                          	if angle == 90.degrees
                          		angle2 = -90.degrees
                          		puts "I'm 90"
                          	elsif angle == -90.degrees
                          		angle2 = 90.degrees
                          		puts "I'm -90"
                          	compinst.transform! tr1.inverse
                          	tr2 = Geom;;Transformation.rotation(org, Z_AXIS, angle2)
                          	tr3 = Geom;;Transformation.new(org)
                          	compdef.entities.transform_entities(tr2, compdef.entities.to_a)
                          	compdef.entities.transform_entities(tr3.inverse, compdef.entities.to_a)
                          	compinst.transformation = compinst.transformation * tr3
                          	compinst.transform! tr1 * tr2.inverse
                          end #def
                          • sdmitchS Offline
                            sdmitch
                            Replace 90.degrees with Math::PI/2.
                            • PixeroP Offline
                              Pixero
                              Thanks, I tried that but the result is the same.
                              Is there a way of clamping very small values since 90.00000000000003 degrees seem to be enough not to work?
                              	if angle == Math;;PI/2
                              	elsif angle == -(Math;;PI/2)
                              		angle2 = 90.degrees
                                slbaumgartner
                                This issue is unavoidable with finite precision math on the computer. You have to choose a threshold of significance and then test for agreement within that tolerance, e.g.
                                if (angle.degrees - 90.0).abs < threshold
                                Of course, then you will become subject to all the same complaints as SketchUp gets for its internal 0.001 inch tolerance for consolidating Vertices - which is due to exactly the same situation!
                                • sdmitchS Offline
                                  sdmitch
                                  I don't think the angle between vectors is ever going to be negative. Since you are measuring the angle from the x axis, you will need to use the y value of the rotvector to determine if the angle is negative or positive.
                                  angle *= -(rotvector.y<=>0)
                                  In a Sketchup rotation transformation, a positive angle is a counter clockwise rotation.
                                  • PixeroP Offline
                                    Pixero
                                    I think I finally solved it by checking which of the pt0.y and pt1.y is larger and treat it different accordingly. Seems to work now.
                                    Thanks for you input.
                                    • PixeroP Offline
                                      Pixero
                                      I just thought I'd post this snippet in case it will help someone with a similar problem.
                                      	rotvector = pt1-pt0
                                      	org = pt3
                                      		angle2 = -angle
                                      		angle2 = angle
                                      	end #if
                                      	if pt0.y > pt1.y && angle == Math;;PI/2 #Check if it's drawn at 90 degrees but in opposite direction
                                      		angle2 = 90.degrees
                                      end #def
