    [Plugin] Import ALL from Folder
    77 Posts 20 Posters 72.5k Views 20 Watching
      driven
      @Tig
      I just tested using ruby 1.8.7 and it worked fine
      editand now it works with 1.8.5............how peculiar
        mattao987
        I will try to update my ruby asap.
          driven
          it's just a button click with the new [soon to be released plugin]
          look up the mac ruby thread, I haven't got it handy,
          or PM me
            pmagans
            TIG,
            Do you know of any .stl batch importers? I have found two .stl importers but nothing with the batch capabilities.
              @pmangans
              This tool 'Import ALL from Folder' will batch import STL files - if you have the SketchUp STL import/export tool installed: http://extensions.sketchup.com/en/content/sketchup-stl
              However because of that importer's coding I think it is not hash-able - so it will use the last options set in its dialog - and you must answer 'Yes' when prompted for each STL file in imports as that can't be switched off...
              Get 'Import ALL from Folder' v1.3 here: http://sketchucation.com/pluginstore?pln=import_from_folder
                pmagans
                Thanks TIG that worked
                  bitslapped
                  I love this plugin. I think a nice addition would be an option to import onto a grid so components are easier to manage.
                  Thanks TIG
                    Thanks TIG
                    Try http://sketchucation.com/pluginstore?pln=components_grid
                    This arranges installed components on a user chosen 'grid'...
                    • Y Offline
                      YoungOSG
                      @tig said:
                      @mattao987 said:
                      ...I'd like to add an optionnal STAGE in your script.
                      Once a file is imported, i'd like to create a new layer named by reference to the file name with a suffix.
                      Let's say Wonka_Niv1
                      Then, Group all the freshly imported items on this new layer.
                      Then proceed to the next file...
                      What file type are you importing?
                      SKP and Others need to be treated differently...
                      Obviously none of this 'Layering' stuff will ever work with imported 'Images' !!
                      For non-SKP files:
                      Provided there is at least one object already in the receiving-SKP, then all imported formats [other than a SKP] will already import as a component named after the file - e.g. "Wonka_Niv1.dwg".
                      So after line#84:
                      model.import(file,false)
                      add these lines:
                      unless File.extname(list[0]).downcase==".skp" ins=model.definitions[File.basename(file)].instances[0] ins.layer=model.layers.add(File.basename(file, ".*")) end#if
                      Note: this uses the imported files 'basename' [e.g. "Wonka_Niv1"], to use the full name with say its '.dwg. suffix use ...add(File.basename(file)) instead
                      For SKP imports you will need to edit another part of the code:
                      after line#107:
                      ins=model.active_entities.add_instance(defn,tr)
                      add this:
                      ins.layer=model.layers.add(name)
                      This uses the imported SKP's name, without any '.skp' suffix [e.g. "Wonka_Niv1"] - but if you want to add one, then change ...add(name) to ...add(File.basename(file))
                      This should do what you want... πŸ˜„
                      after i use this plugins to add ade files,i can not see them!
                      i can not understand why.
                      any helps?
                        You said 'ade', I guess you really meant '.DAE' ?
                        They should import OK.
                        Any error messages in the Ruby Console when try it ??
                        • Y Offline
                          YoungOSG
                          Yes! I mean *.dae files.
                          I use your script.and add purge_unsed,export.
                          However i need to handle thousands of files.Sketchup always crashes after export few files.
                          I really don't know how to fix it.
                          any helps?
                          purge_multi_dae2 (2).rb
                            driven
                            I only use mac, but...
                            you could, save each file to 'Trash', close it, then open a new for the next import?
                            SU should then be starting fresh each time and you don't need to erase any entities?
                            just a thought, I use the idea in a script...
                            this is the an extract for Trash on a mac...
                            def revert
                              trash_copy = (File.expand_path("~/.Trash/" + "." + @orig.title + ".skp")).dup.freeze
                              @orig.save(trash_copy)
                              Sketchup.send_action("closeDocument;")
                              Sketchup.send_action("newDocument;")
                              @Young
                              You code is overly complicated.
                              It also has some odd working practices... πŸ˜•
                              I am sure I have answered this same query elsewhere...
                              See the @yuyuwhy posts...
                              Is it you, but with a different user-name ??
                              http://sketchucation.com/forums/viewtopic.php?p=554042#p554042
                              This thread explains how to setup an empty model SKP - the order of purging IS important - yours is wrong !
                              Do that BEFORE importing anything.
                              It also suggests a sensible approach to the subsequent import, purge and export of each DAE in turn.
                              If you enclose those actions within a ' model.start_operation(...)' block, BUT afterward each you ' model.abort_operation' it [NOT the usual ' model.commit_operation' it] then the imported data is simply forgotten, but the export is safe because the DAE file is now outside of the SKP's control... So there is no need to purge between each import/export at all.
                              Recast your code thus...
                              Make the host SKP empty.
                              Process the list of DAE files in turn.
                              Use a model.start_operation(...) block around each iterate step.
                              Remember to use the model.abort_operation to undo the import etc, but leave the export intact.
                              You should end up with an empty SKP and all of the DAE files processed.
                              Incidentally, your code only works in v2015 as the UI folder selector is new in that version's API.
                              • Y Offline
                                YoungOSG
                                def revert
                                > end
                                I tried it.It works fine on my PC,however it crashed on others.
                                  This is splatting for me?
                                  No console message. Just splat!
                                  I try nuke my plugins older to isolate
                                    driven
                                    @rich,
                                    maybe your need to watch the tutorial?
                                      @john
                                      hahahaha
                                      even that didn't help...
                                      I'm trying to import 126 faceme .skp then run components to grid.
                                      I ain't getting past the import all part as yet.
                                      SU2015 64bit Pro in case that helps?
                                        driven
                                        seriously now...
                                        I just tested it and had a splat as well, sent it to trimble...
                                        I'll have a look a the report
                                          na na nana na
                                            driven
                                            @rich line 101 delete puts re-save, restart...
                                            worked for me
                                            • 2 / 4
