    [Plugin] Import ALL from Folder
    77 Posts 20 Posters 74.2k Views 20 Watching
      driven
      @tig said:
      Why?
      I'm not going to look farther into it as I don't understand what you are attempting to do...
      hi Tig,
      I think he's on a mac, as I just tried to run it and got similar errors.
      As I only needed one folder of images I pulled the bits out and line fed Ruby Console, to ascertain what worked, oddly it was failing at every return and worked when they were removed? is it a 1.8.5 ruby issue? I cobbled the bits that worked in a new file and ran it fine, if you want to see it I can PM...
        mattao987
        Sorry for this long absence, ( a long serie of "bugs" in my working life )
        I've just tried the editing of the code with BBEdit cos it was not working on my mac.
        My goal is to achieve a fast import of files exported from VectorWorks through the DWG plug-in.
        I got a very good answer with your script but I hoped to get it one step beyond
        (Please pardon me my bad english)
          driven
          hi mattao987
          fill in your profile so everyone knows your on a mac, we are a minority group here...
          I didn't need much of it, but splitting out the explicit returns made the bits I needed work, I also de-modularised it for a one off run.
          If you go through and gat the basics to fully work, I'd suggest PM'ing TIG your working version of the basic script, then talk about extra's...
          Even the initial error reports may help see what's going wrong on mac.
            driven
            @Tig
            I just tested using ruby 1.8.7 and it worked fine
            editand now it works with 1.8.5............how peculiar
              mattao987
              I will try to update my ruby asap.
                driven
                it's just a button click with the new [soon to be released plugin]
                look up the mac ruby thread, I haven't got it handy,
                or PM me
                  pmagans
                  TIG,
                  Do you know of any .stl batch importers? I have found two .stl importers but nothing with the batch capabilities.
                    @pmangans
                    This tool 'Import ALL from Folder' will batch import STL files - if you have the SketchUp STL import/export tool installed: http://extensions.sketchup.com/en/content/sketchup-stl
                    However because of that importer's coding I think it is not hash-able - so it will use the last options set in its dialog - and you must answer 'Yes' when prompted for each STL file in imports as that can't be switched off...
                    Get 'Import ALL from Folder' v1.3 here: http://sketchucation.com/pluginstore?pln=import_from_folder
                      pmagans
                      Thanks TIG that worked
                        bitslapped
                        I love this plugin. I think a nice addition would be an option to import onto a grid so components are easier to manage.
                        Thanks TIG
                          Thanks TIG
                          Try http://sketchucation.com/pluginstore?pln=components_grid
                          This arranges installed components on a user chosen 'grid'...
                          • Y Offline
                            YoungOSG
                            @tig said:
                            @mattao987 said:
                            ...I'd like to add an optionnal STAGE in your script.
                            Once a file is imported, i'd like to create a new layer named by reference to the file name with a suffix.
                            Let's say Wonka_Niv1
                            Then, Group all the freshly imported items on this new layer.
                            Then proceed to the next file...
                            What file type are you importing?
                            SKP and Others need to be treated differently...
                            Obviously none of this 'Layering' stuff will ever work with imported 'Images' !!
                            For non-SKP files:
                            Provided there is at least one object already in the receiving-SKP, then all imported formats [other than a SKP] will already import as a component named after the file - e.g. "Wonka_Niv1.dwg".
                            So after line#84:
                            model.import(file,false)
                            add these lines:
                            unless File.extname(list[0]).downcase==".skp" ins=model.definitions[File.basename(file)].instances[0] ins.layer=model.layers.add(File.basename(file, ".*")) end#if
                            Note: this uses the imported files 'basename' [e.g. "Wonka_Niv1"], to use the full name with say its '.dwg. suffix use ...add(File.basename(file)) instead
                            For SKP imports you will need to edit another part of the code:
                            after line#107:
                            ins=model.active_entities.add_instance(defn,tr)
                            add this:
                            ins.layer=model.layers.add(name)
                            This uses the imported SKP's name, without any '.skp' suffix [e.g. "Wonka_Niv1"] - but if you want to add one, then change ...add(name) to ...add(File.basename(file))
                            This should do what you want... ๐Ÿ˜„
                            after i use this plugins to add ade files,i can not see them๏ผ
                            i can not understand why.
                            any helps?
                              You said 'ade', I guess you really meant '.DAE' ?
                              They should import OK.
                              Any error messages in the Ruby Console when try it ??
                              • Y Offline
                                YoungOSG
                                Yes! I mean *.dae files.
                                I use your script.and add purge_unsed,export.
                                However i need to handle thousands of files.Sketchup always crashes after export few files.
                                I really don't know how to fix it.
                                any helps?
                                purge_multi_dae2 (2).rb
                                  driven
                                  I only use mac, but...
                                  you could, save each file to 'Trash', close it, then open a new for the next import?
                                  SU should then be starting fresh each time and you don't need to erase any entities?
                                  just a thought, I use the idea in a script...
                                  this is the an extract for Trash on a mac...
                                  def revert
                                    trash_copy = (File.expand_path("~/.Trash/" + "." + @orig.title + ".skp")).dup.freeze
                                    @orig.save(trash_copy)
                                    Sketchup.send_action("closeDocument;")
                                    Sketchup.send_action("newDocument;")
                                    @Young
                                    You code is overly complicated.
                                    It also has some odd working practices... ๐Ÿ˜•
                                    I am sure I have answered this same query elsewhere...
                                    See the @yuyuwhy posts...
                                    Is it you, but with a different user-name ??
                                    http://sketchucation.com/forums/viewtopic.php?p=554042#p554042
                                    This thread explains how to setup an empty model SKP - the order of purging IS important - yours is wrong !
                                    Do that BEFORE importing anything.
                                    It also suggests a sensible approach to the subsequent import, purge and export of each DAE in turn.
                                    If you enclose those actions within a ' model.start_operation(...)' block, BUT afterward each you ' model.abort_operation' it [NOT the usual ' model.commit_operation' it] then the imported data is simply forgotten, but the export is safe because the DAE file is now outside of the SKP's control... So there is no need to purge between each import/export at all.
                                    Recast your code thus...
                                    Make the host SKP empty.
                                    Process the list of DAE files in turn.
                                    Use a model.start_operation(...) block around each iterate step.
                                    Remember to use the model.abort_operation to undo the import etc, but leave the export intact.
                                    You should end up with an empty SKP and all of the DAE files processed.
                                    Incidentally, your code only works in v2015 as the UI folder selector is new in that version's API.
                                    • Y Offline
                                      YoungOSG
                                      def revert
                                      > end
                                      I tried it.It works fine on my PC,however it crashed on others.
                                      • Rich O BrienR Online
                                        This is splatting for me?
                                        No console message. Just splat!
                                        I try nuke my plugins older to isolate
                                          driven
                                          @rich,
                                          maybe your need to watch the tutorial?
                                            @john
                                            hahahaha
                                            even that didn't help...
                                            I'm trying to import 126 faceme .skp then run components to grid.
                                            I ain't getting past the import all part as yet.
                                            SU2015 64bit Pro in case that helps?
                                            • 2 / 4
