    Twisted Dovetail
    35 Posts 11 Posters 5.9k Views 11 Watching
    • S ShepherdS Offline
      S Shepherd
      Konnichiwa,
      I don't have fancy piece of furniture, just an odd little dovetail joint. Probably more trouble to layout on wood than it's worth.
      Shep
      • KrisidiousK Offline
        Krisidious
        What I wonder is how it could actually be used in real life... Doesn't seem possible.
        By: Kristoff Rand
          davidheim1
          Very interesting. Might make a good corner joint for a box.
          Best,
          dh
            pcmoor
            True....Its not possible to join them
            • jeff hammondJ Offline
              maybe if it's printed that way? πŸ˜‰
                S Shepherd
                Oh ye of little faith. Just google it
                Shep
                  Cool.
                  There are similar looking joints that can be assembled.
                  Scott beat me to it.
                    Krisidious
                    I did and most of what I saw looked faked... Others were built in a way that they could be angled together first. I'd love to see video of it being done.
                    By: Kristoff Rand
                      Kris, twisted dovetails like Scott's can and are made in real wood. Whether or not they look faked, they can be cut to work.
                      From Fine Woodworking Magazine #61
                        i guess if the pins&tails line up at some point (in the middle somewhere) then it can slide together? if the angles are right?
                          S Shepherd
                          See if this helps. The first image I posted is the starting position.
                            oops, i missed that bit.. was thinking the coincident point would have to be in the middle somewhere. the animation clears it up though.
                            πŸ‘
                              Krisidious
                              Nice animation Shep...
                              This is one of the ones that looked faked.
                              http://www.richardjonesfurniture.com/Tables-Chairs/boire-coffee-table/boire-table-3-600.jpg
                              By: Kristoff Rand
                                Krisidious
                                So the twist has to be identical on the inside front as it is on the backside top for it to work?
                                By: Kristoff Rand
                                  What makes it look fake?
                                    because it looks like there's not a way to assemble/dissemble it.. that's what the joint is for anyway, right?
                                    like-- "hey bud, why don't you try to figure that one out hehheh"..
                                    or is it inherently stronger than a traditional dovetail?
                                      S Shepherd
                                      One thing that's different about this is the miter on the end pair. I think it's done like this.
                                        Krisidious
                                        The seam along the dovetails...
                                        By: Kristoff Rand
                                          That's not a seam. It's a marking gauge line for the baseline. You'll sometimes see it on hand cut non-twisted dovetails too. It's part of the marking out for the joint. The baseline is often cut deep because it forms a guide for the chisel when cleaning out the waste.
                                          http://www.philadelphiafurnitureworkshop.com/category/show/images/Dovetails_000.JPG
                                            slbaumgartner
                                            The mental hurdle in this joint as nicely illustrated in Scott's video is that the joint slides together along a 45 degree sloped line, not straight in as we are accustomed to. That fools the mind and eye into thinking it can't go together at all!
                                            Steve
