    Increasing Sandbox precision
    7 Posts 5 Posters 930 Views 5 Watching
    • eidam655E Offline
      eidam655
      hi guys,
      i have a set of terrain contours, all set up in their correct heights... the problem is, in some places the contours' resolution is not consistent, so i'm getting weird shapes:
      http://i.imgur.com/LwQnYzX.png
      my question is: what tools could I use to subdivide the curve segments so that my terrain is a bit more defined?
      many thanks for any answers.
      I'm using SketchUp 2017, V-Ray 3.4
      • srxS Offline
        srx
        FREDO's TopoShaper plugin! ๐Ÿ˜„
        www.saurus.rs
        • eidam655E Offline
          eidam655
          i have tried that one, but i'm still getting roughly only 5mx5m terrain resolution, which is still too coarse and it's visible in the steep terrain ๐Ÿ˜•
          • oceanembersO Offline
            oceanembers
            curvizard has a tool called "smooth contours". It basically just smooths your curves. If that ends up being too high res, you can also run simplify contours to get the edge count down before you generate the terrain.
            • PixeroP Offline
              Pixero
              With Toposhaper, after you've clicked calculate terrain, you can set the "resolution" under Grid.
              • eidam655E Offline
                eidam655
                i know, and it's still too coarse ๐Ÿ˜„
                http://i.imgur.com/qq5eaZ4.png
                i guess i'll have to make 4 or 9 chunks out of the contours manually, and then run Toposhaper on those chunks.
                • pbacotP Offline
                  That's a stumper because I don't think it will be easy to do in sections and put together aftewards. Instant Terrain by Valiarchitect might give a finer grid but I don't know if it can show more accurate detail.
                  I couldn't say without seeing the file, but you do realize that contours are only approximations themselves. They don't represent reality and your model doesn't either. For example, parts that (I suspect) are absolutely flat in your model are not coming out perfectly flat in the results, but is it still reasonably close and usable for your modeling?
                  I've suggested to Fredo that the grid be set by dimension and always orientated to the x-y axis. Then one could do smaller portions and join them more easily, with the grid lining up. I have no idea if that is a reasonable request. ๐Ÿ˜•
