    DWG Import Missing Layers - AutoCad Dynamic Components
    18 Posts 6 Posters 8.0k Views 6 Watching
    • ninomaydaN Offline
      ninomayda
      @tig said:
      This DWG is not a big file.
      It should import OK.
      There is no layer numbers limit that I know of.
      Certainly I use some SKPs with far more layers than your example.
      I downloaded the DWG, audited it [1 fix], purged it [several unused things removed], saved and then imported into SketchUp.
      It was fine - the layers named 'Appliance' and 'Stair' are there in the SKP with the expect geometry on them, as is everything else.
      Note that there are no layers named 'Appliances' or 'Stairs' in the DWG.
      What SketchUp version are you using ?
      Have you tried 'repairing' its installation ??
      I'm on 2015. Sorry about the "plurals". You're correct, layers in question are 'Appliance' and 'Stair'.
      Perhaps my Limitation lies in not using AutoDesk/Acad. Gave it up years ago. Currently using DraftSight (free). Guess I better learn how to do the Audit/Purge on DS.
      Thanks for the effort. Good to know it's me not SKP.
      Happy New Year!
      • TIGT Online
        If 'DraftSight' mimics AutoCAD's interface then at the command line typing 'audit' and answering 'yes' to fix issue: then 'purge', and selecting 'purge all nested' [no prompting] should do it ?
        There is also 'recover' if a DWG is too corrupted to open...
        'DraftSight' has a 'File Utilities' menu to 'error-check', 'clean' and 'recover' drawings...
        Just run them from there ?
        It uses different names but does the same thing...
        See page 147 of this PDF guide...
        http://denisekitchencad.weebly.com/uploads/5/0/0/2/5002372/draftsight_training.pdf
          ninomayda
          Thanks a Bunch TIG. I'm familiar with the DS-Trainning Manual and page #147 in particular. Tried it to no avail. Now I'm loosing the "Furniture" Layer. Done Audit, Purge, Recover and Clean.
          Thanks a LOT for the time vested. Let's not worry about this any more. Evidently it's not an SKP limitation.
          What bugs me is that I cannot trust a customer sent DWG without first manipulating it outside SKP before Import.
          Regards
          Nino
          • BoxB Offline
            I know nothing in this scenario, but as an outsider when I import the file I get 6o something layers all fully populated without fiddling with your customers bits.
              JGA
              I saved the file back to 2010 DWG format & imported it into SKUP 2014 without a problem.
              Note the Washer+ block on the Appliance layer is dynamic, so may be a problem. Using "+" in a block name may also cause issues.
              Regards,
              JGA
                ninomayda
                Thanks for investing the time on this. Sure, Layers "appear" to import on the dialogue window, but did you get the Fridge/Freezer Blocks in the kitchen? How about all the stair treads?
                Nino
                  ninomayda
                  PLUS Sign on a Block ! That sheds a whole lot of light on a potential culprit. Interesting.
                  Not finding any value on CAD software over SKP for the last 10-years, sorry to say I've not kept up with DynCompos on AutoDesk. Any feelers out there to pursue importing the DWG and seeing if you get the Fridge and the Freezer imported onto the kitchen?
                  Thanks for the lead. I might be rusty on DWG. Plus Signs on DC's or Block Names themselves is still a liability within SKP importing operations nonetheless.
                  Nino
                    KrisM
                    I could not get the fridge blocks to import. If you look at the window after the import has finished the dwg import, it says 141 anonymous blocks were not imported. These blocks include the fridge block. Sketchup doesn't like this block which has some attributes to flip it in Autocad. I exploded and redefined the fridge block in Autocad and then it imported fine into SU. My experience is that I rarely get a 100% perfect dwg import into SU unless I do some exploding , purging and cleanup in Autocad first. You may have to accept the fact that you're going to need to draw some elements yourself in SU if you're not able to do the cleanup in Autocad first.
                    • TIGT Online
                      So in the DWG...
                      Select All.
                      Explode All.
                      Audit [Fix==Yes].
                      Purge All [including Nested objects].
                      Import into SKP...
                      πŸ˜„
                        KrisM
                        My procedure -
                        Select All.
                        Explode All.
                        Explode All.
                        Explode All.
                        Audit [Fix==Yes].
                        Import into SKP...
                          KrisM
                          Just ran my procedure and all the linework comes into SU. However, once in SketchUp, one of the problems with the dwg import presents itself. This is not a complicated plan yet it generates 226,000 edges in the SU model. This is why I take out all the extraneous objects, hatching etc in Autocad before importing. It's never a straightforward import.
                            ninomayda
                            @tig said:
                            So in the DWG...
                            Select All.
                            Explode All.
                            Audit [Fix==Yes].
                            Import into SKP...
                            πŸ˜„
                            Yup, that would be the "big hammer" approach. Trouble is file balloons to 11MB and I loose control to turn unnecessary Layers on/off.
                            • pbacotP Offline
                              I often explode all but keep the layers. I might group by layer so very few groups (blocks). Every block (at least in my CAD export) ends up a component in SU and I hate them cluttering the component window. It's mostly for layout, I import as little of the drawing as possible.
                                ninomayda
                                As usual, You All Gentlemen are indeed Correct. Challenge is that, upon "explode", entities fall off their respective Layers onto the Default (Current) Layer. Only option is to individually explode each of the multiple layers on their respective original layers.
                                Regards
                                Nino
                                  JGA
                                  You could try saving to an older DWG file format, such as 2004 which didn't have dynamic capabilities.
                                  ACAD has a RENAME command to have a quick check & re-title block names.
                                  Regards,
                                  JGA
                                  • TIGT Online
                                    Yes, the Save_As in the CAD app could go back, even to r2000, the DWG's geometry/layers etc imported into SketchUp will be unaffected by that... but newer things like DC's, which could break it, are not supported in those earlier DWG formats, so they are avoided...
