    [Plugin] Save Copy As Previous Version
    60 Posts 22 Posters 72.1k Views 22 Watching
      sstuchfield
      Hi Jim,
      Do you have an estimate of when you will be able to repost it?
      Cheers,
      Sandy
        Jim
        Thanks for the reminder. With SU being a hobby for me and not something i do for a living, I tend to spend time on things that interest me at the moment. I will get this plugin updated this weekend.
          sstuchfield
          Awesome, Thanks
            Jim
            Updated, see first post.
              stagelight
              Great plugin !! Thank you.
                dirtypr
                This is wonderful!! thanks!
                  rv1974
                  Would it be possible to make the 'silent' version of this script:
                  1. no confirmation windows
                  2. no additions to the file name
                  3. background autosave as prev. version
                    This script would help to solve the problem of crashing windows explorer (v.2015) and open skp files in other applications (Xnview renders skp thumbnails (up to v.2013) and 3ds Max\Lumion open only older skp versions).
                  Thanks.
                    stagelight
                    Maybe this is new for 2015? But this code, will save as version 7, no confirmation needed. Just run in the ruby console...
                    model = Sketchup.active_model
                    status = model.save("", Sketchup::Model::VERSION_7)
                      That's new to SU2014.
                      http://www.sketchup.com/intl/en/developer/docs/ourdoc/model#save
                        Jim
                        Oh that's interesting. It only works if the model has already been saved. I may have made things more difficult than they are.
                        So what you want is to be able to choose a version to use as the default one time, then just use a shortcut or menu item to save the model?
                          driven
                          status = model.save((File.expand_path("~/Desktop/test_v7")), Sketchup;;Model;;VERSION_7)
                          if you give it a valid path it works with unsaved models...
                          In my mac version I grab the incoming path from the header and spit that back out on save...
                          but to do so automatically as per the request, needs an Observer, and I loathe all of them...
                          • U
                            unsuns
                            Hello Everyone !
                            Today, I finally decided to start using Sketchup 2016 instead of Sketchup 8, and I discovered this WONDERFUL plugin.
                            However, it's not working with SU 2016.
                            Thank you for updating it, we'll be really grateful !
                            Cheers !
                              Jim
                              I'll take a look.
                                Jim
                                @unsuns said:
                                Hello Everyone !
                                It is working for me - what is not working for you?
                                • U
                                  unsuns
                                  @jim said:
                                  @unsuns said:
                                  Hello Everyone !
                                  When I use it, the plugin changes the file's version number back to 8.0.1 and I can open it correctly in Sketchup 8.
                                  However, I use Lumion, and he cannot read the file until I save it manually as version 8.
                                  Moreover, when I use the plugin, it seems to change only the version number, and not re-saving the file completely, which takes much more time when I test that manually on heavy files.
                                  • U
                                    unsuns
                                    Did you check the issue and found a solution for that problem ?
                                      driven
                                      I suspect your Lumion plugin needs you to re-save so it can 'tag' all your materials.
                                      if the plugin isn't in v16 it would not have done that for you...
                                      does Lumion have a v16 version?
                                      • U
                                        unsuns
                                        The latest Lumion version is 6.0, and shows the same issue. The SKP file must be saved as v8.
                                        When I save it from Sketchup 2016 manually, it works perfectly.
                                        However, I thought that this plugin would make me save some time, using a simple shortcut.
                                        I'd be really glad if this finally works ! πŸ˜„
                                        Edit : Lumion reads the sketchup file directly.
                                        • U
                                          unsuns
                                          I did a few more tests and I figured out what the problem is :
                                          I used to try to overwrite the active file from v2016 to save it as v8 through the plugin-> Same name (Format : %model).
                                          However, when I added some other character (Format: %model_V8), meaning that it saves as another file, this works perfectly, and Lumion reads the file flawlessly.
                                          So, the real issue is : Can we FORCE the plugin to overwrite the current and active SKP v16 file in order to make it v8 ?
                                          Thank you.
                                          EDIT : Indeed, I just had to change the "Sketchup.active_model.save_copy" to "Sketchup.active_model.save". Now it works PERFECTLY !
                                          PROBLEM SOLVED ! THANKSSS ! πŸ˜„
                                            stagelight
                                            I just posted this. Maybe this will useful..
                                            404 Not Found
                                            (sketchucation.com)
                                            • 2 / 3
