    [Plugin] Save Copy As Previous Version
    60 Posts 22 Posters 72.1k Views 22 Watching
      Jim
      @sstuchfield said:
      Hi Jim,
      I can't seem to find a download link to this plugin anywhere... Is it still available?
      Sandy
      I took it down to work on it, but looks like I never got it re-posted.
      @unclex said:
      could it always save as one version, such as 13 or 8 @2014?
      like a switch, could be fixed
      My current version uses a sub-menu to list all available back versions - so you could set a shortcut key to your preferred version. I may also add an option to set the default version.
      I will update in the next few days.
      • JQLJ
        JQL
        Really useful!
        www.casca.pt
        Visit us on facebook!
          Jim
          I think the name "Save As Previous" does not accurately convey my original purpose of this plugin. Rather than "Save", I think "Export As Version" would be more accurate. Exporting implies the desire to keep the original file unchanged while creating a new file at the selected SU version. Perhaps the new file would have a version hint in in the file name.
          So the workflow is:
          1. Editing a model named "Jones_Residence" in the most recent version of SketchUp.
          2. Ready to send changes to person or application that can only use SU version 8 files.
          3. Activate shortcut to "Export model as Version 8."
          4. A new model is exported as "Jones_Residence_su8" in the same folder as original. Original model is unmodified both in SketchUp and on disc.
          5. Send v8 file.
          6. Repeat.
          Sound about right?
          • kenK
            ken
            Jim
            Is there anyway to add the date, or a version #, such as, ??????_SU8_03_12_14 or ??????SU8_V_01?
            That would prevent writing over the file.
            Ken
              Jim
              Yes, I will make the format customizable.
                sstuchfield
                Hi Jim,
                Do you have an estimate of when you will be able to repost it?
                Cheers,
                Sandy
                  Jim
                  Thanks for the reminder. With SU being a hobby for me and not something i do for a living, I tend to spend time on things that interest me at the moment. I will get this plugin updated this weekend.
                    sstuchfield
                    Awesome, Thanks
                      Jim
                      Updated, see first post.
                        stagelight
                        Great plugin !! Thank you.
                          dirtypr
                          This is wonderful!! thanks!
                            rv1974
                            Would it be possible to make the 'silent' version of this script:
                            1. no confirmation windows
                            2. no additions to the file name
                            3. background autosave as prev. version
                              This script would help to solve the problem of crashing windows explorer (v.2015) and open skp files in other applications (Xnview renders skp thumbnails (up to v.2013) and 3ds Max\Lumion open only older skp versions).
                            Thanks.
                              stagelight
                              Maybe this is new for 2015? But this code, will save as version 7, no confirmation needed. Just run in the ruby console...
                              model = Sketchup.active_model
                              status = model.save("", Sketchup::Model::VERSION_7)
                                That's new to SU2014.
                                http://www.sketchup.com/intl/en/developer/docs/ourdoc/model#save
                                  Jim
                                  Oh that's interesting. It only works if the model has already been saved. I may have made things more difficult than they are.
                                  So what you want is to be able to choose a version to use as the default one time, then just use a shortcut or menu item to save the model?
                                    driven
                                    status = model.save((File.expand_path("~/Desktop/test_v7")), Sketchup;;Model;;VERSION_7)
                                    if you give it a valid path it works with unsaved models...
                                    In my mac version I grab the incoming path from the header and spit that back out on save...
                                    but to do so automatically as per the request, needs an Observer, and I loathe all of them...
                                    • U
                                      unsuns
                                      Hello Everyone !
                                      Today, I finally decided to start using Sketchup 2016 instead of Sketchup 8, and I discovered this WONDERFUL plugin.
                                      However, it's not working with SU 2016.
                                      Thank you for updating it, we'll be really grateful !
                                      Cheers !
                                        Jim
                                        I'll take a look.
                                          Jim
                                          @unsuns said:
                                          Hello Everyone !
                                          It is working for me - what is not working for you?
                                          • U
                                            unsuns
                                            @jim said:
                                            @unsuns said:
                                            Hello Everyone !
                                            When I use it, the plugin changes the file's version number back to 8.0.1 and I can open it correctly in Sketchup 8.
                                            However, I use Lumion, and he cannot read the file until I save it manually as version 8.
                                            Moreover, when I use the plugin, it seems to change only the version number, and not re-saving the file completely, which takes much more time when I test that manually on heavy files.
                                            • 2 / 3
