Housebuilder
@dave r said:
Brian, it appears you misread what was said. Box and TIG have already given you correct info that should fix what you've done. For the next person who comes along, do the following and it will work just fine.
Download HouseBuilder_extension.zip.
Do not open the ZIP file.
Rename it HouseBuilder_extension.rbz.
In SketchUp, go to Preferences>Extensions.
Click on the Install Extension button.
Navigate to where you saved the file.
Select it, click on Open.
Click on Yes and the OK.Housebuilder will now be installed. On the PC click on OK to close Preferences. On the Mac, just close the Preferences window.
Dave R thanks so much for the directions. You should be writing for the Ruby Library site on how to install for su2014. There explanation is for the aliens. The tool finally worked. Your simple, but direct directions worked perfectly. Even though you dumbed them down what good is it if the people reading can't understand them. Great Job and thanks.
i have tried everything but the right thing to install this housebuilder, i have renamed the zip file and it doesnt show when i use sketchup extension install..... i have tried for two hours and am losing my mind
Did you follow the instructions I wrote? Exactly?
If you have any file - let's call it 'AAA.zip' and you change its file-type extension to be .rbz, then it is named 'AAA.rbz'... and it WILL be found and offered for installation...
BUT if you have file-type extensions hidden under Windows settings, then Windows Explorer displays the file without the file-type extension, as 'AAA', saying its file-type is ZIP separately - so then when you rename it its displayed name becomes 'AAA.rbz', but Windows still sees it as a ZIP file - because its full name is now 'AAA.rbz.zip' !
To see the FULL file name for ALL files change your Windows Explorer setting under Tools > Folder Options > View > Files and Folders... look about 10 items down, and ensure there is NOT a tick in the 'Hide extensions for known file types' check-box: OK to save changes
You will now see the full name displayed for 'AAA.zip', and now you can either add .rbz onto the end, or change the file-type ending to .rbz - so renamed files as 'AAA.zip.rbz' OR 'AAA.rbz' will both work with the SketchUp installer...
I've followed the entertaining install instructions...and I'm sure I completely missed something obvious, but how may I get the correct icons installed on the toolbar?
I have HB working, but have to guess then play memory to use the widow, door, and other features.
I've uninstlled and installed (from all your links and direct download files) both HB and SU2014, 3-4 times each tonight.MacAir SU2014
Looks to me as if the toolbar icon images didn't get installed into the correct location. There should be a folder called HouseBuilder in the Plugins folder and it should have a bunch of PNG files along with a couple of .rb files.
HouseBuilder is in the plugin folder, SU is just not installing the .png images.
The functions are working...I either guess or look elsewhere for the order of the icons. -
But are the png icons in the HouseBuilder folder? Maybe you could make and share screen shots of your Plugins folder and the HouseBuilder folder.
I have been trying to install house builder with no success, Im on a mac with sketch up 8. I downloaded the Housebuilder extension from the link provided and my mac must unzip files for me as I have yet to see a .zip file show up when I download the link. I compressed the folder that was downloaded and changed the .zip to a .rbz file. I added the .rbz file to sketch up by using the preferences - extensions - install extensions method and it says the installation is complete, but I don't see an option to choose the Housebuilder extension.
Well I downloaded the new version - changed the .zip to .rbz - pointed to it in sketchup/preferences/pluggins and it loaded - great!
Only one problem. The metric dimensions used don't in fact reflect Australian timber sizes. In the past I have opened the Housebuilder_sections.txt file and altered the dimensions - e.g. a 4" x 2" is a 100 x 50mm which I have changed to a 90mm x 45mm which is what we use here in Aussieland.
Now the text file is incorporated into the .rbz file so I can't access it. I tried reloading it but it won't do it.
So I uninstalled v.2015 - I deleted the C:/Programs/Sketchup folder that was left (as it had retained the plugins folder) and reinstalled 2015 only to find that Housebuilder is now a permanent pluggin which I can't un-install and which has the 100 x 50mm as standard. I was hoping to reinstall it with the altered sections.text file but I can't do it as housebuilder is now permanently installed despite completely uninstalling 2015.
Uninstalling/reinstalling SketchUp does nothing to change any Plugins you might have installed in your own User AppData Plugins folder...
To find/open that default Plugins folder, use the relevant SketchUcation Tools submenu item [Install its RBZ from the above link if needed...].
The path varies between versions.
Alternatively use this snippet in the Ruby Console:
UI.openURL( "file:///#{Sketchup.find_support_file('Plugins')}" )All you need to do to customize the HouseBuilder tool's lumber sizes is to open the file:
../Plugins/HouseBuilder/housebuilder_sections.txt
and edit it...
OR simply replace it with your own custom version of the file.
For >=v2014 make sure that the file is 'UTF8-withBOM' encoded [use Notepad++ to ensure that, OR use a copy of the original txt file that will already be properly encoded...]
Remember to follow the naming/text rules of the original file for the 23x45|67x89|... separators/joiners etc... -
John, if you go through the trouble of changing that file you might upload your AU Metric example for others to use. Just a thought.
Thanks TIG - you were right - it had installed in User/roaming etc.
solved.
solved.
That was the right location for it, too.
Here you go Kris.
Awesome John, never know when it might come in handy.
Cannot install HB on Mac (OS 10.6.8) in SU8.01.
I have downloaded HB folder on my desktop containing garage_tour.skp (no model in scenes), HouseBuilder.rb and HouseBuilderTool.rbI open SketchUp > Preferences >Extensions and Install extension.
I navigate to the HB folder > open and all contents are GRAYED out preventing installation.I am thinking I should manually install HB and I cannot find any SU plugin folder to place HB into. There is no SU plugin folder in the folder I purchased from SketchUp and I cannot find any SU plugin folder on my Mac.
Any help is greatly appreciated. The HB plugin looks enormously useful.
I guess you haven't read through this thread. The correct installation process has been give multiple times here.
From your description it sounds like you downloaded the ZIP file but it got unzipped automatically by your OS. You really ought to set it so that doesn't happen. It would make things easier.
Install Extension requires that the extension be packaged as a zip file whose file-extension is changed to .rbz. The reason Install Extension didn't work for you is you have no .rbz file to point it at.
Try again.
As for the Plugins folder, in current versions of SketchUp it does exist but it is in a hidden directory. There's no need for you to access it directly if you have files structured correctly and install them properly. Your profile indicates you're still using SketchUp 6. Is that correct?
Thank you Dave for the HouseBuilder_extension.rbz file.
I was wasting time with the rb files and the rbz installed and worked in SU8 after reopening.
HB appear in my Draw menu. -
Most plugins/extensions anymore are .rbz files and can be installed automatically with the Sketchucation Plugin Store (and the Extension Warehouse if you ever decide to update SketchUp to the present) but there are some out there still that will come as ZIP files. It would probably be worth your time to disable auto-unzipping so that zip files remain intact when you download them.
