    Problems with a half-torus
    156 Posts 11 Posters 18.7k Views 11 Watching
    • TeigT Offline
      Teig
      @dave r said:
      What you show in your screen shot is that the Follow Me path makes a turn where you don't want it. It would probably be easiest if you draw the half torus slightly away from the rest of the geometry and combine them after. Make sure you are only using a circle for the Follow Me path. If you aren't doing so, preselect the path, get Follow Me and click on the face of the profile.
      [attachment=0:2g9ixz64]<!-- ia0 -->Screenshot - 12_27_2014 , 5_56_01 AM.png<!-- ia0 -->[/attachment:2g9ixz64]
      You know I tried that a hundred times (only a mild exaggeration ๐Ÿ˜„ ) I guessed it might be something interacting and making the Follow Me turn on a strange tanget.
      Thanks Dave, whatever magic you worked from the other side of the world has solved it ๐Ÿ˜‰ and I now have my component:
      http://i1006.photobucket.com/albums/af190/Nursi555/GoodSubStack_zps6f7bb6c9.jpg
      Very happy, only another 4 or 5 versions of my component to design before I go off to the shed ๐Ÿ˜„
      • TeigT Offline
        Teig
        @tig said:
        Extra tips:
        Model so the faces' fronts are 'outwards' - context-menu 'reverse'...
        Depending on the Style settings the front color is generally 'off-white' and the back color 'bluish' - your faces look like 'backs'...
        Model at a 'reasonable size' - geometry [edges and facets] <= ~1/1000" cannot be created [because SketchUp's tolerance thinks that the two almost coincident points forming the ends of an edgs are coincident and they don't get made so the related geometry fails to be created]: if your object is likely to make that issue, then you'll get holes with followme, intersect and similar tools - to avoid it Scale up x100, create geometry and then Scale down again - the tiny geometry can exist after the shrinking - but it cannot be created initially...
        Thanks TIG, What is a "reasonable size"? My component is 80mm across, is that too small for SU?
          Very good. I wish I could make these things look harder to do than they are so those who've been struggling for hours wouldn't feel like they'd wasted a bunch of time. ๐Ÿ˜„ Last Saturday, late in the afternoon, I showed a fellow how to do something he'd been struggling with since about 6 that morning. He hadn't even gotten dressed at the point I spoke to him. It took less than 30 seconds to draw what he wanted. I couldn't figure out how to make it go slower. ๐Ÿ˜†
          It looks like you've got something weird going on with your torus. Maybe an extra circle drawn slightly off axis. It may not cause problems for your application but it isn't very clean the way it is.
            If you didn't wind up with any holes after running Follow Me, it isn't too small. Until you get used really familiar with SketchUp's handling of tiny edges and faces, the best thing is to try it and see what happens. You can always use Undo and then scale up to try again. With time you'll be able to anticipate that and be proactive.
            When I am drawing small items and expect holes, I make a component of all the involved geometry--Follow Me path and profile, for example--and make a copy which I scale up. Then I edit the scaled up copy and run Follow Me or make intersections or whatever. When I'm finished, I exit the component, delete the big one and return to the original one which is sitting where I left it.
            • TeigT Offline
              Teig
              I was putting some measurements on and the 'Spinning Beachball of Death' appeared, my component has disappeared from my computer ๐Ÿ˜ฒ I have sent an error report.
                I wonder why that happened.
                • TeigT Offline
                  Teig
                  Well it's back and better than ever ๐Ÿ˜„ And when it cropped up in conversation yesterday my friend told me his brother has a 3D printer, so he can print it - perfect. Just need to figure out how to make the stl file converter plugin work now. ๐Ÿ˜•
                  It came to me, you just attach the .skp file... ๐Ÿ˜ณ If anyone wants to run an eye over it for errors at the 3D printing stage I'd be much obliged
                  Sub Stack8.skp
                  • TeigT Offline
                    Teig
                    @tig said:
                    Extra tips:
                    I have reversed the face of the bell if that's what you mean TIG:
                    http://i1006.photobucket.com/albums/af190/Nursi555/A Mini/SubStack8bellreversed_zps6652d59a.jpg
                    • cottyC Offline
                      cotty
                      It's not a solid (no thickness , internal faces, ...) so you will not be able to print it with a 3d printer.
                      my SketchUp gallery
                        d12dozr
                        I had a quick look...your model needs to be "Solid" to be 3D printable. Right now, you have a bunch of single-face walls with no thickness that will not print. You have to actually create the desired wall thickness for it to print properly.
                        See this link and my attachment for more details: http://www.dummies.com/how-to/content/understanding-solid-objects-in-google-sketchup-8.html
                        http://goo.gl/f7ooYh
                        • TeigT Offline
                          Teig
                          I see what you mean. Sort of. Until you pointed it out I thought the area under the bellmouth was solid: how can I make it solid? I just know the push/pull of Follow tool will be a nightmare...
                          I don't/ can't see what the internal face is that I need to delete?
                            d12dozr
                            Teig, the bottom of the bell was likely not formed when performing the follow me operation at too small of a scale.
                            Does the center have a hole like a donut? Assuming so, here's how I'd make the overall shape:
                            Click to view full size
                            After you run the follow me tool, you're left with a solid that you can add the bottom holes to.
                              Aaaah, you have saved as 2015! ๐Ÿ˜ฎ
                              So owners of other versions can't reload your file! ๐Ÿ˜ข
                              It's so easy to save as V6 for a more large audience! ๐Ÿ˜„
                              • TeigT Offline
                                Teig
                                Gotcha! I think! Draw the profile at the very start. I've been trying for three hours now to put an arc under the bellmouth! ๐Ÿ˜’
                                • TeigT Offline
                                  Teig
                                  Oops! ๐Ÿ˜ณ I'll try again with an older version.
                                    Pilou,it's long past time for you to catch up to the rest of the world. ๐Ÿ˜‰
                                    • pbacotP Offline
                                      Pilou, doesn't your computer run 2015? Before I even start using some versions, I get a copy of the latest just so I can open files from others (and also to try it out some). I then back-save a file myself if I really want to play with it, using my current plugin and setup.
                                        d12dozr
                                        You could use JointPushPull plugin to thicken a curved surface, but starting with a new profile is much cleaner and probably faster.
                                        • TeigT Offline
                                          Teig
                                          I eventually got it sorted (hope), thanks to you folks. It really does look like the perfect bellmouth now - I couldn't sleep last night I was so excited ๐Ÿ˜„
                                          I'm at work now; I'll put the (v6) .skp up later.
                                            d12dozr
                                            Nice! ๐Ÿ˜
                                            • 1 / 8
