    [Plugin Library] LibFredo6 - v16.2b - 22 Sep 26
    2.2k Posts 583 Posters 9.1m Views 585 Watching
      To manually install a lone .RB file you can do the following...
      In the Ruby console type: Sketchup.find_support_file('Plugins')
      It returns the path to your Plugins folder.
      Use the path to open that folder, and add a copy of the lone .RB file into that folder...
      On older SketchUp versions you might need to ensure that the folder [and its contents] has FULL read/write permissions... BUT in v2015 that should already be set correctly.
      Restart SketchUp to load the new .RB...
      Alternatively make a ZIP file containing the .RB and use the SketchUcation submenu 'Archive Installer' which works on ZIPs as well as RBZs: no need to restart as it is auto-installed AND loaded.
      OR change the file ending from .ZIP to .RBZ and than use the native Preferences > Extensions > Install... button [or of course the SketchUcation equivalent auto-installer]: again no need to restart.
      • Bob JamesB
        Bob James
        I cannot get LibFredo6 to install without receiving errors when opening SU. I've tried System Preferences/Install Extensions , SU Plugin Store and Extension Warehouse. Extension Warehouse shows a big red install button, but the button is not active!
        Error Loading File Fredo6_!LibFredo6.rb
        Error: #<ArgumentError: invalid byte sequence in UTF-8>
        C:/Users/jamesb/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:702:in match' C:/Users/jamesb/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:702:in block (2 levels) in load_from_config'
        C:/Users/jamesb/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:701:in each' C:/Users/jamesb/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:701:in block in load_from_config'
        C:/Users/jamesb/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:700:in foreach' C:/Users/jamesb/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:700:in load_from_config'
        C:/Users/jamesb/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:1070:in block in load_all_plugins' C:/Users/jamesb/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:1070:in each'
        C:/Users/jamesb/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:1070:in load_all_plugins' C:/Users/jamesb/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/Lib6Core.rb:772:in load_from_config'
        C:/Users/jamesb/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6.rb:188:in startup' C:/Users/jamesb/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6.rb:335:in <module:LibFredo6>'
        C:/Users/jamesb/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6.rb:34:in `<top (required)>'
          @Bob
          Do you have the very latest version of LibFredo installed ?
          Do you only have it loading from one Plugins folder ??
          The file:
          C:/Users/jamesb/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6/LibFredo6.plugin
          ought to be encoded as "UTF-8 without BOM".
          Mine is, but that error report suggests that yours is not πŸ˜•
          Then the regular-expression match in line#702 of the script Lib6Core.rb is failing because of that.
          If you have Notepad++.exe you could open that .plugins file, then change its encoding to the correct type and save it, then restart SketchUp to see if that's it...
          If not then perhaps a file was somehow corrupted...
          I've attached a copies of my LibFredo6.plugins file AND Lib6Core.rb - extract them from the ZIP and replace the old ones - see if that helps after a SketchUp restart...
          LibFredo6[replacements].zip
          • Bob JamesB
            Bob James
            Yes
            I have no additional plugin folders
            Before installing the files you provided, I compared them side by side with those already installed and they appear identical to what I had already installed.
            I saw nothing in LibFredo6.plugin that mentions "UTF-8 without BOM", however the Load Error message says, " invalid byte sequence in UTF-8>" which, obviously, does not add "without BOM". Significant?
            Nevertheless, I put the files you provided into:
            C:\Users\jamesb\AppData\Roaming\SketchUp\SketchUp 2015\SketchUp\Plugins\Fredo6_!LibFredo6
            Upon startup of SU I received the same load errors as before.
            Since Lib6Core does not have line numbers I could not I could not find lines identified in Load Errors.
            C:/Users/jamesb/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6.rb:188:in startup' C:/Users/jamesb/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/Fredo6_!LibFredo6.rb:335:in module:LibFredo6'
            • BoxB
              Bob, just to be sure, you say you have no other plugin folders but you did have a dropbox one and have been setting up a Cloud one. They may well have an errant copy of LibFredo hiding in them.
              Go to the Sketchucation Plugins Manager, the blue button on the toolbar, and check the dropdown menu at the top. Are there any other folder locations showing there?
              • Bob JamesB
                Bob James
                No πŸ˜„
                Well, actually, yes. Spacemouse (3Dconnexion) and Thea Render files are there in C:\ProgramData\SketchUp\SketchUp 2015\SketchUp\Plugins 😎
                  I suspect that some old files somewhere are interfering with things, because they are wrongly encoded.***
                  Can you manually remove the 'loader RB' [ Fredo6_!LibFredo6.rb] and the entire LibFredo subfolder and its contents [ Fredo6_!LibFredo6] from your Plugins folder.
                  If you have a redundant copy of the old LibTraductor.rb in your Plugins folder, then also remove that [it now comes installed within the main Lib subfolder].
                  All other Fredo-plugins files and subfolders should be left alone...
                  Next, reinstall the latest version of 'LibFredo' from the PluginStore AutoInstall button - to ensure you have the full set of the current files [and nothing more!].
                  Restart SketchUp to complete all of the changes.
                  ***The encoding 'UTF-8 without BOM' refers to how the file itself is encoded, there is nothing in the typed code's text itself.
                  You can view/change a file's encoding using Notepad++exe, that app also lets you show line numbers too etc...
                  Older Ruby versions were forgiving of an RB file's encoding, but the newest Ruby2 chokes on incorrectly encoded scripts - hence I suspect the 'UTF-8' error messages...
                  • Bob JamesB
                    Bob James
                    Did as instructed and got the same error message so I reinstalled all of your plugins.
                    This is the list of all Fredo6 plugins I have installed.
                    @tig said:
                    **If you have a redundant copy of the old LibTraductor.rb in your Plugins folder, then also remove that [it now comes installed within the main Lib subfolder].
                    Note that LibTraductor.rb was reinstalled as a separate ruby as well as within Fredo6_!LibFredo6 as Lib6Traductor
                    2014-12-21 Fredo6_!LibFredo6
                    2014-12-21 Fredo6_!LibFredo6.rb
                    2014-12-21 LibTraductor.rb
                    2014-12-19 Fredo6_JointPushPull
                    2014-12-19 Fredo6_JointPushPull.rb
                    2014-12-15 Fredo6_Curviloft.rb
                    2014-12-15 Fredo6_Curvizard.rb
                    2014-12-15 Fredo6_FredoScale.rb
                    2014-12-15 Fredo6_FredoTools.rb
                    2014-12-15 Fredo6_RoundCorner.rb
                    2014-12-15 Fredo6_ToolsOnSurface.rb
                    2014-12-15 Fredo6_VisuHole.rb
                    2014-12-15 Fredo6Trace.txt
                    2014-12-15 FredoTraceRoundCorner.txt
                    2014-12-14 CURVILOFT_Dir_12
                    2014-12-14 CURVIZARD_Dir_11
                    2014-12-14 FREDOSCALE_Dir_22
                    2014-12-14 FREDOTOOLS_Dir_12
                    2014-12-14 LIBFREDO6_Dir_48
                    2014-12-14 LibFredo6.rb
                    2014-11-17 Fredo6_FredoTools
                    2014-11-04 Fredo6_Curviloft
                    2014-11-04 Fredo6_FredoScale
                    2014-11-04 Fredo6_VisuHole
                    2014-11-04 Fredo6_RoundCorner
                    2014-11-04 Fredo6_ToolsOnSurface\
                    I still get this error set:
                    • fredo6F
                      Bob,
                      Just remove the old versions
                      It is actually the old LibFredo6.rb which is creating the problem
                        Thanks Fredo.
                        At last we see what the old error-inducing file was...
                        πŸ˜’
                        • Bob JamesB
                          Bob James
                          @tig said:
                          Thanks Fredo.
                          πŸ˜’
                          Nice, if it were true 😞
                          I deleted the six files fredo6identified, but still get the following errors:
                          These are all of the loaded plugins/extensions that have "fredo6" either in the title or within the file:
                          This is an Excel spreadsheet showing all of the loaded plugins/extensions except for Thea and 3dconexxion which are in C:/ProgramData/SketchUp/SketchUp 2015/SketchUp/Plugins folder.
                          2015 Plugins.xls
                            Nil desperandum !
                            We will get there. πŸ˜•
                            The first thing I see that's not right is that you have a copy of the 'Fredo6_!LibFredo6' folder INSIDE the 'Fredo6_Curviloft' folder.
                            It is not needed, it's not as shipped and should be removed.
                            Although I can't see how that might be affecting things !
                            The only 'Fredo6_!LibFredo6' folder should be in the Plugins folder.
                            After the removal of the wrong copy can you restart to see if anything is better... πŸ˜•
                            You also appear to have several OLD versions folders and files that are not needed and might cause issues... [all of Fredo's latest compatible stuff tends to now start with 'Fredo' - exceptions being '!AdditionalPluginFolders.rb' ?]
                            LibTraductor.rb
                            JPP_Dir_20
                            ROUNDCORNER_Dir_23
                            TOPOSHAPER_Dir_10
                            TOS_Dir_18
                            Perhaps 'DEFPARAM_Dir' - Fredo to advise ??
                            You also have some files named:
                            cd_power_extension_m.rb
                            cd_power_m.rb
                            cd_power_n.rb
                            etc
                            Are they the toolbar ones causing issues with adding 'rogue files' [can't see those files though] ??
                            NOT sure about 'BZ_Dir_17' or 'DOCUMENTATION_Dir' - Fredo should advise...
                            Also, what are the 'round_corners.rb', 'loader.rb', 'autoloader.rb' and 'AUTOLOADER_Dir' ?
                            These don't sound right ??
                            You do have dozens of Plugins enabled and loading, so one of those might be throwing Fredo's Lib off unfairly...
                            If we are still having issues can I suggest you use the SketchUcation Plugins Manager, make a Set of the current setup [blue button], the Select all of the Enabled/Loaded plugins, except for the 'Fredo' ones, and then use the red button to Disable them. Save that set as another name...
                            Now restart SketchUp.
                            If we still get the issue with Fredo's Lib then we know it's not from an interaction with the others.
                            BUT if we don't have problems you can start loading back the Disabled ones a few at a time, until you break it - then you have a suspect/culprit...
                            • fredo6F
                              Bob,
                              Why don't you simply remove all my plugins files and folders, and then reinstall from the Plugin Store, checking at each step that this is OK.
                              • Bob JamesB
                                Bob James
                                @fredo6 said:
                                Bob,
                                ALL of your plugins are freshly installed using SketchUcation Plugin Store
                                  @bob james said:
                                  @fredo6 said:
                                  Bob,
                                  @Bob
                                  OK, try my suggestion first to tidy up, and then to have only Fredo's stuff loading [Plugins Manager] - if there's no issue something else is to blame and we are a step nearer catching the little varmint[s]...
                                  You do have far more than the average number of Plugins loading, so it is quite possible something is producing weird results, so it's possible that Fredo's latest Lib is the collateral damage, and quite 'innocent'......
                                  • Bob JamesB
                                    Bob James
                                    @tig said:
                                    Nil desperandum !
                                    πŸ˜†
                                    After the removal of the wrong copy can you restart to see if anything is better... πŸ˜• .
                                    I noticed that and removed it, It had no effect.
                                    I removed all Fredo plugins and did a fresh install using SketchUcation Plugin Store so what's there came from those installations.
                                      Please re-read my post...
                                      I suggested that you Disable 'everything that is not "Fredo"' - temporarily, using the Plugins Managers Sets to make it easy...
                                      And restarted SketchUp to see if the error remains.
                                      Disabling the Fredo stuff might prevent that error appearing - but something that still loads might still then cause the error when the Lib is re-enabled - so we are not a step forward...
                                      IF you still get the Fredo Lib errors with only the Fredo stuff loading then it is to blame...
                                      BUT if not something else which you currently have Disabled is actually the culprit...
                                      Since you have nothing odd about your windows-user-name or your Windows setup, you should not have these errors, IF all of your installed plugins are compatible with 'UTF-8...'
                                      Please try my steps to see what is the culprit - I think it's NOT Fredo's Lib, but something that is interacting with it unexpectedly...
                                      I wait to be proved wrong πŸ˜’
                                      • Bob JamesB
                                        Bob James
                                        I did those things before you sent that message πŸ˜„
                                        I'm working on your suggestions now.
                                        • Bob JamesB
                                          Bob James
                                          :heart_eyes:
                                          I'm happy to announce to TIG and Fredo that all is well ❗
                                          I deleted:
                                          • LibTraductor.rb
                                            JPP_Dir_20
                                            ROUNDCORNER_Dir_23
                                            TOPOSHAPER_Dir_10
                                            TOS_Dir_18
                                            cd_power_m.rb
                                            cd_power_n.rb
                                            Although I don't know which one was the bad guy because I deleted all of them at once. I didn't use SketchUcation Plugins Manager because I've never used it before and didn't want to mess things up by doing it incorrectly.
                                          'BZ_Dir_17' is Bezierspline
                                          'DOCUMENTATION_Dir' is empty
                                          I'm sure you both are relieved as much as I that this is resolved.
                                          Thank you both for your extra effort and patience. πŸ‘
                                          • fredo6F
                                            But then, do you still have problems?
                                            • 45
                                            • 46
                                            • 47
                                            • 48
                                            • 49
                                            • 112
                                            • 113
                                            • 47 / 113
