    [Plugin] RichSection V0.5.8 UPDATED march 2015
    395 Posts 85 Posters 156.8k Views 85 Watching
      pgarmyn
      @TIG
      If you know better my intentions than i do, then i am on the wrong site.
      • srxS Offline
        srx
        Where is this wonderful plugin?
        www.saurus.rs
          @pgarmyn said:
          @TIG
          I did NOT say I knew your intentions.
          You said what your intention was.
          I simply point out that your current convoluted Registry hacking code returns the User's Preferences setting for the Materials folder set up under Files...
          This is NOT always the User's Documents folder [your intention].
          It can be any folder that has been set...
          That folder might not have the FULL permissions your coding requires...
          There are simpler ways of finding the User's Documents folder - if that is what you want...
          If you explained the reasoning behind your 'intention' then perhaps a more fruitful dialog would ensue...
            PluginStore...
            http://sketchucation.com/pluginstore?pln=RichSection
            It was set to 'unpublished' in its PluginStore entry.
            I assume this was an oversight by the author when updating it.
            Previously he had had an issue with the updating to v0.5.5 RBZ, but this was fixed recently...
            I have used my admin powers to 'published' it.
            However, if for some unclear motive, the author wishes to revert its 'published' status, then he needs to reverse my admin changes, and 'unpublish' it...
            • H Offline
              hgdar
              @pgarmyn said:
              @hgdar said:
              Hello,
              Extension seems great but i can't make it working
              It seems to install but when i restart SU, i've got the following errors :...
              I can't launch SU as an administrator. Is it still possible to use plugin?
              I don't understand : your computer returns "C:/Program Files/SketchUp/SketchUp 2015/" as the default user directory.
              What Windsows version are you on ?
              Can you copy these lines in redin the ruby console (copy+past the complete text in red in the input field of the ruby-panel + return button) and send me the result ?
              defaultFileDir = Win32::Registry::HKEY_CURRENT_USER.open "Software\\SketchUp\\Sketchup 2015\\File Locations", Win32::Registry::KEY_READ puts "result = "+defaultFileDir["Materials"].gsub(/\\/,'/')
              On my computer it returns :
              result = C:/Users/MYUSERNAME/Documents/
              For an unknown reason, the returned path seems to be "C:/Program Files/SketchUp/SketchUp 2015/" on your computer, which is not writable. Can you confirm this ?
              Mmmh, i don't kwow what happened and why the materials folder path has been changed. I change it back to default value and it's ok now. thx very much
              • 2 Offline
                2Harry
                Sorry pgarmyn, I've been travelling for the past two days and have just now seen your reply to my question.
                I will try to work out what folders it is trying to access and their permission status.
                • 2 Offline
                  2Harry
                  pggarmyn,
                  I ran your ruby code in the console and got this: result = C:/Users/Mark-MSI/Documents/
                  Note that this is on a different computer (my laptop for travelling) but I am getting the same errors with this plugin. Previous machine was running Win7, this one Win8.1
                  I have not changed any of the default file locations in Sketchup
                  Regards
                  • 2 Offline
                    2Harry
                    Sorry pgarmyn,
                    I see that you posted a fixed 0.5.5 version. That is the one I installed on this Win8.1 laptop and it seems that I am getting the same type of error as hgdar:
                    Error: #<Win32::Registry::Error: The system cannot find the file specified.>
                    C:/Program Files/SketchUp/SketchUp 2015/Tools/RubyStdLib/win32/registry.rb:385:in open' C:/Program Files/SketchUp/SketchUp 2015/Tools/RubyStdLib/win32/registry.rb:496:in open'
                    c:/users/mark-msi/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/piga_richsection/richsection.rbs:1003:in userFileLocations' c:/users/mark-msi/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/piga_richsection/richsection.rbs:1103:in module:PiGaRSection'
                    c:/users/mark-msi/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/piga_richsection/richsection.rbs:113:in <main>' C:/Users/Mark-MSI/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/PiGa_RichSection/RSloader.rb:25:in eval'
                    C:/Users/Mark-MSI/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/PiGa_RichSection/RSloader.rb:25:in require' C:/Users/Mark-MSI/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/PiGa_RichSection/RSloader.rb:25:in module:PiGa'
                    C:/Users/Mark-MSI/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/PiGa_RichSection/RSloader.rb:3:in <top (required)>' C:/Program Files/SketchUp/SketchUp 2015/Tools/extensions.rb:197:in require'
                    C:/Program Files/SketchUp/SketchUp 2015/Tools/extensions.rb:197:in load' C:/Users/Mark-MSI/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/PiGa_RichSection.rb:40:in register_extension'
                    C:/Users/Mark-MSI/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/PiGa_RichSection.rb:40:in <module:PiGa>' C:/Users/Mark-MSI/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/PiGa_RichSection.rb:17:in <top (required)>'
                    Regards
                    • srxS Offline
                      srx
                      Still, there is no download in plugin store...
                      www.saurus.rs
                        pgarmyn
                        You will have to wait for an update.
                        V0.5.4 won't work on SU 2015 if SU 2014 wasn't installed before
                        V0.5.4 and V0.5.5 won't work on 2014 and 2015 if the user folder for materials isn't defined (even if you see the default path in 'preferences') or if it isn't writable
                        • srxS Offline
                          srx
                          OK. Thanks.
                          www.saurus.rs
                            pgarmyn
                            [Plugin] RichSection V0.5.6 UPDATED dec 2014
                            PLUGINSTORE
                              pgarmyn
                              @rhott311 said:
                              Plugin does not display correct input panels in OS X Yosemite in SU 08, textured section does not appear at all. Previous versions of this plugin did not work either. Are there known panel issues for OS X?
                              Hy rhott311
                              I can not test all combinations of Sketchup versions and Systems.
                              The last version has been tested on OS X (10.9.4), Sketchup 2014 and 2015
                              The input panel works on OS X
                              There was a bug (only on OS X) with the previous versions : Textures displayed only after switching them 'off' and 'on' again
                              (Menu : View/Face_Style/Shaded and View/Face Style/Shaded_with_Textures)
                              Try again here : PLUGINSTORE
                              Thanks for the interest.
                                maxosmedia
                                Sketchup Launch:
                                RS: ERROR RichSection: REINSTALL THE PLUGIN : could not find file :
                                RS: /Users/uusername/Library/Application Support/SketchUp 2015/SketchUp/Plugins/PiGa_RichSection/resources/RS-create-icon.png
                                Console:
                                Error: #<TypeError: no implicit conversion of nil into String>
                                /users/uusername/library/application support/sketchup 2015/sketchup/plugins/piga_richsection/richsection.rbs:4866:in small_icon=' /users/uusername/library/application support/sketchup 2015/sketchup/plugins/piga_richsection/richsection.rbs:4866:in module:PiGaRSection'
                                /users/uusername/library/application support/sketchup 2015/sketchup/plugins/piga_richsection/richsection.rbs:114:in <main>' /Users/uusername/Library/Application Support/SketchUp 2015/SketchUp/Plugins/PiGa_RichSection/RSloader.rb:25:in eval'
                                /Users/uusername/Library/Application Support/SketchUp 2015/SketchUp/Plugins/PiGa_RichSection/RSloader.rb:25:in require' /Users/uusername/Library/Application Support/SketchUp 2015/SketchUp/Plugins/PiGa_RichSection/RSloader.rb:25:in module:PiGa'
                                /Users/uusername/Library/Application Support/SketchUp 2015/SketchUp/Plugins/PiGa_RichSection/RSloader.rb:3:in <top (required)>' /Applications/SketchUp 2015/SketchUp.app/Contents/Resources/Content/Tools/extensions.rb:197:in require'
                                /Applications/SketchUp 2015/SketchUp.app/Contents/Resources/Content/Tools/extensions.rb:197:in load' /Users/uusername/Library/Application Support/SketchUp 2015/SketchUp/Plugins/PiGa_RichSection.rb:40:in register_extension'
                                /Users/uusername/Library/Application Support/SketchUp 2015/SketchUp/Plugins/PiGa_RichSection.rb:40:in <module:PiGa>' /Users/uusername/Library/Application Support/SketchUp 2015/SketchUp/Plugins/PiGa_RichSection.rb:17:in <top (required)>'
                                  pgarmyn
                                  @maxosmedia and OTHERS
                                  Install again, missing files have been added ! SORRY 😳
                                    maxosmedia
                                    Sketchup frozen on hit "Update RichSection" button. No section results.
                                    The plugin does not work now 😞
                                    (Mac OS X 10.9.5 SU2015Pro (15.2.686)
                                    • 2 Offline
                                      2Harry
                                      Installed V0.5.6 in Sketchup2015 Pro on Win8.1.
                                      Works great now. Will be experimenting over the next few days.
                                      Thank you for your focused efforts to get it running for everyone.
                                      Regards
                                        Sl-m
                                        Hi There,
                                        Seems like a very powerful plugin, Well done and thanks for sharing!
                                        I have a question though:
                                        I'm using pro SKetchup pro 2015.
                                        When i have already created cut plans and select one of them, right click and "make realsection", nothing happens. I pressed "show real section" but doesn't make any difference.
                                        What M'I doing wrong ?
                                        Thank you
                                        Sl!m
                                          pgarmyn
                                          Hi There,
                                          Thank you
                                          Sl!m
                                          Realsection is another plugin. Mine is RichSection.
                                            Sl-m
                                            @pgarmyn said:
                                            Hi There,
                                            Thank you
                                            Sl!m
                                            Wow so sorry I got confused and completely missed that!
                                            I would rather erase my thread as it is not useful for other users.
                                            Merry Christmas!
                                            Sl!m
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 15 / 20
