    [Plugin] RichSection V0.5.8 UPDATED march 2015
    395 Posts 85 Posters 184.8k Views 85 Watching
    • 2 Offline
      2Harry
      Sorry pgarmyn, I've been travelling for the past two days and have just now seen your reply to my question.
      I will try to work out what folders it is trying to access and their permission status.
      • 2 Offline
        2Harry
        pggarmyn,
        I ran your ruby code in the console and got this: result = C:/Users/Mark-MSI/Documents/
        Note that this is on a different computer (my laptop for travelling) but I am getting the same errors with this plugin. Previous machine was running Win7, this one Win8.1
        I have not changed any of the default file locations in Sketchup
        Regards
        • 2 Offline
          2Harry
          Sorry pgarmyn,
          I see that you posted a fixed 0.5.5 version. That is the one I installed on this Win8.1 laptop and it seems that I am getting the same type of error as hgdar:
          Error: #<Win32::Registry::Error: The system cannot find the file specified.>
          C:/Program Files/SketchUp/SketchUp 2015/Tools/RubyStdLib/win32/registry.rb:385:in open' C:/Program Files/SketchUp/SketchUp 2015/Tools/RubyStdLib/win32/registry.rb:496:in open'
          c:/users/mark-msi/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/piga_richsection/richsection.rbs:1003:in userFileLocations' c:/users/mark-msi/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/piga_richsection/richsection.rbs:1103:in module:PiGaRSection'
          c:/users/mark-msi/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/piga_richsection/richsection.rbs:113:in <main>' C:/Users/Mark-MSI/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/PiGa_RichSection/RSloader.rb:25:in eval'
          C:/Users/Mark-MSI/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/PiGa_RichSection/RSloader.rb:25:in require' C:/Users/Mark-MSI/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/PiGa_RichSection/RSloader.rb:25:in module:PiGa'
          C:/Users/Mark-MSI/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/PiGa_RichSection/RSloader.rb:3:in <top (required)>' C:/Program Files/SketchUp/SketchUp 2015/Tools/extensions.rb:197:in require'
          C:/Program Files/SketchUp/SketchUp 2015/Tools/extensions.rb:197:in load' C:/Users/Mark-MSI/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/PiGa_RichSection.rb:40:in register_extension'
          C:/Users/Mark-MSI/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/PiGa_RichSection.rb:40:in <module:PiGa>' C:/Users/Mark-MSI/AppData/Roaming/SketchUp/SketchUp 2015/SketchUp/Plugins/PiGa_RichSection.rb:17:in <top (required)>'
          Regards
          • srxS Offline
            srx
            Still, there is no download in plugin store...
            www.saurus.rs
              pgarmyn
              You will have to wait for an update.
              V0.5.4 won't work on SU 2015 if SU 2014 wasn't installed before
              V0.5.4 and V0.5.5 won't work on 2014 and 2015 if the user folder for materials isn't defined (even if you see the default path in 'preferences') or if it isn't writable
              • srxS Offline
                srx
                OK. Thanks.
                www.saurus.rs
                  pgarmyn
                  [Plugin] RichSection V0.5.6 UPDATED dec 2014
                  PLUGINSTORE
                    pgarmyn
                    @rhott311 said:
                    Plugin does not display correct input panels in OS X Yosemite in SU 08, textured section does not appear at all. Previous versions of this plugin did not work either. Are there known panel issues for OS X?
                    Hy rhott311
                    I can not test all combinations of Sketchup versions and Systems.
                    The last version has been tested on OS X (10.9.4), Sketchup 2014 and 2015
                    The input panel works on OS X
                    There was a bug (only on OS X) with the previous versions : Textures displayed only after switching them 'off' and 'on' again
                    (Menu : View/Face_Style/Shaded and View/Face Style/Shaded_with_Textures)
                    Try again here : PLUGINSTORE
                    Thanks for the interest.
                      maxosmedia
                      Sketchup Launch:
                      RS: ERROR RichSection: REINSTALL THE PLUGIN : could not find file :
                      RS: /Users/uusername/Library/Application Support/SketchUp 2015/SketchUp/Plugins/PiGa_RichSection/resources/RS-create-icon.png
                      Console:
                      Error: #<TypeError: no implicit conversion of nil into String>
                      /users/uusername/library/application support/sketchup 2015/sketchup/plugins/piga_richsection/richsection.rbs:4866:in small_icon=' /users/uusername/library/application support/sketchup 2015/sketchup/plugins/piga_richsection/richsection.rbs:4866:in module:PiGaRSection'
                      /users/uusername/library/application support/sketchup 2015/sketchup/plugins/piga_richsection/richsection.rbs:114:in <main>' /Users/uusername/Library/Application Support/SketchUp 2015/SketchUp/Plugins/PiGa_RichSection/RSloader.rb:25:in eval'
                      /Users/uusername/Library/Application Support/SketchUp 2015/SketchUp/Plugins/PiGa_RichSection/RSloader.rb:25:in require' /Users/uusername/Library/Application Support/SketchUp 2015/SketchUp/Plugins/PiGa_RichSection/RSloader.rb:25:in module:PiGa'
                      /Users/uusername/Library/Application Support/SketchUp 2015/SketchUp/Plugins/PiGa_RichSection/RSloader.rb:3:in <top (required)>' /Applications/SketchUp 2015/SketchUp.app/Contents/Resources/Content/Tools/extensions.rb:197:in require'
                      /Applications/SketchUp 2015/SketchUp.app/Contents/Resources/Content/Tools/extensions.rb:197:in load' /Users/uusername/Library/Application Support/SketchUp 2015/SketchUp/Plugins/PiGa_RichSection.rb:40:in register_extension'
                      /Users/uusername/Library/Application Support/SketchUp 2015/SketchUp/Plugins/PiGa_RichSection.rb:40:in <module:PiGa>' /Users/uusername/Library/Application Support/SketchUp 2015/SketchUp/Plugins/PiGa_RichSection.rb:17:in <top (required)>'
                        pgarmyn
                        @maxosmedia and OTHERS
                        Install again, missing files have been added ! SORRY 😳
                          maxosmedia
                          Sketchup frozen on hit "Update RichSection" button. No section results.
                          The plugin does not work now 😞
                          (Mac OS X 10.9.5 SU2015Pro (15.2.686)
                          • 2 Offline
                            2Harry
                            Installed V0.5.6 in Sketchup2015 Pro on Win8.1.
                            Works great now. Will be experimenting over the next few days.
                            Thank you for your focused efforts to get it running for everyone.
                            Regards
                              Sl-m
                              Hi There,
                              Seems like a very powerful plugin, Well done and thanks for sharing!
                              I have a question though:
                              I'm using pro SKetchup pro 2015.
                              When i have already created cut plans and select one of them, right click and "make realsection", nothing happens. I pressed "show real section" but doesn't make any difference.
                              What M'I doing wrong ?
                              Thank you
                              Sl!m
                                pgarmyn
                                Hi There,
                                Thank you
                                Sl!m
                                Realsection is another plugin. Mine is RichSection.
                                  Sl-m
                                  @pgarmyn said:
                                  Hi There,
                                  Thank you
                                  Sl!m
                                  Wow so sorry I got confused and completely missed that!
                                  I would rather erase my thread as it is not useful for other users.
                                  Merry Christmas!
                                  Sl!m
                                  • srxS Offline
                                    srx
                                    I tried it and can now say that this is very useable and useful plugin. Thank you!
                                    www.saurus.rs
                                      Sl-m
                                      Hi there,
                                      Everything was working very well... Until yesterday when I played with the settings.
                                      After that the RichSection wouldn't cut through, just show the section line.
                                      I even loose the ability to activate the original Sketchup section tool and had to restart Sketchup.
                                      Any idea what's wrong ?
                                      http://www.postimg.org/image/itedoashd/
                                      Using sketchup 2015, windows7 ultimate 64.
                                      Thank you
                                      Sl!m
                                        pgarmyn
                                        Yes I had the same experiance. Sketchup stops cutting elements, and only showing the section lines, until restarting SU.
                                        I only had it with SU2015 on win 8.1. I suppose it is linked to that SU version (?)
                                          pgarmyn
                                          (deleted) answer sended twice
                                            simsmt
                                            This plugin is not working for me. I have Win7 SketchUp 2014 Pro. It will not create scenes but I can use exiting scenes to use the hatch but then it leaves the line when going to another scene.
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 20
                                            • 17 / 20
