    Grumman G-44 Widgeon
    79 Posts 13 Posters 15.5k Views 13 Watching
    • Bryan KB Offline
      (Original post disappeared)
      Grumman G-44 Widgeon. WW2 era amphibious shore patrol and sub hunter. Civilian airframe still in use around the world today.
      This will hopefully not take as long as my previous models since I have actual plans for a change.
        An another task! ๐Ÿ˜Ž
        • Bryan KB Offline
          Hmmm.
          • pbacotP Offline
            Nice choice. These planes have such muscular form.
            Are you going use Artisan?
            • Bryan KB Offline
              Thanks.
              I'm using Curviloft. I'll be using Tools on Surface for the windshield and Joint Push/Pull in some other areas.
              I'm getting more or less the same smoothing and as Artisan. I tried an experiment with Artisan and it didn't really make any significant difference.
              Also, the rear of the plane really is that boxy, but it still needs some tweaking. I'll probably adjust it more over the next few days.
              • KrisidiousK Offline
                Krisidious
                watching...
                By: Kristoff Rand
                • hellnbakH Offline
                  hellnbak
                  An ambitious project, I'll be watching your progress.
                  What do you estimate, two, maybe three days?
                  • Bryan KB Offline
                    Weeks. ๐Ÿ˜†
                      One of the nicer looking floatplanes/seaplanes around and an interesting project. Lots of tweaking on the way I reckon but the start is good, as long as the plans agree between different views when guesswork is the only option to retain sanity.
                      • tademaT Offline
                        tadema
                        Weeks. ๐Ÿ˜† ๐Ÿ˜„
                        Looking good Bryan, my old Mam used to say...what's worth having is worth waiting for.
                        Have you tried TIG's Extrusion tool set, they're great.
                        John
                        • Bryan KB Offline
                          @tadema said:
                          Weeks. ๐Ÿ˜† ๐Ÿ˜„
                          John
                          Oh NOW you tell me. ๐Ÿ˜† (seriously, I WILL have to try those on another project or on this one if needed. They look incredible!)
                          For now, I'm sticking with Curviloft and intersect model when required. ๐Ÿ˜‰
                          I was going to put serious hours into this today, but I'm not feeling too good. Not sick, just not "all here". I am still planning on working on it some, though.
                          • Bryan KB Offline
                            Here's what 7 hours look like. A tail. Yep. That's it. Why? Because things that could go wrong did go wrong. Zoom was unstable. Intersect model didn't work right the first 6 times. Polygons were not closing right. Groups and components kept giving me problems. I really think my PC is getting old.
                            But mostly, zoom was being a pain and making it hard to do detail work. It would often go right past the area I wanted to focus on and then it would zoom out only extremely slowly.
                            But hey, not a bad looking tail, right? If you look close, you can see the pivot pins in the rudder and trim tab.
                            Noticed more problems with the main fuselage. sigh Some major rework right there.
                            Another thing I've learned is the blueprint much be really sharp. The ones I have are fuzzy crap close up, so I'm having to guess a lot where things connect.
                            • Bryan KB Offline
                              Hmm. Only took about and hour and half for the clean up.
                              • hellnbakH Offline
                                hellnbak
                                Looking damned good!
                                I can tell this is going to be one fine model.
                                You inspired me to take a crack at an airplane. Whaddya think?
                                Thinking about adding some weapons, and maybe some wheels with high-speed hubcaps.
                                  Nah just some go faster stripes and it's done.
                                  Bryan, if you get tempted to do another flying boat there is a rather larger type that might make use of sketchup v15 called the Saunders Roe Princess. The largest all metal flying boat ever flown. Not sure exactly how it would match up to the Spruce Goose but it is certainly a big beast. Ten turboprops would make a bit of a racket though so ear defenders might be needed.
                                  • BoxB Offline
                                    I tried out your version Hellnbak, it seems to have some minor design flaws.
                                    • JQLJ Offline
                                      JQL
                                      There's no design flaws there Box! It's just a matter of faith and thrust! Trusth me, you have to give it some thrust!
                                      www.casca.pt
                                      Visit us on facebook!
                                      • BoxB Offline
                                        Bad news I'm afraid JQL, I ran the tests with extra thrust and even in the blueprints it's back to the drawing board.
                                        http://i155.photobucket.com/albums/s296/storeben/SU/Fl Blueprint.gif
                                        • hellnbakH Offline
                                          hellnbak
                                          ๐Ÿคฃ
                                          • JonFarJ Offline
                                            JonFar
                                            no no no no no no no...........
                                            he means REAL WEAPONS! guns!
                                            • 1 / 4
