    Texture mapping?
    31 Posts 6 Posters 2.6k Views 6 Watching
    • panixiaP
      panixia
      @pbacot said:
      Making it all quadmesh will probably be the way to get control of the scale.
      i'ts exactly what i did quick and dirty in the example model i uploaded you can isolate loops for fine tuning the scaling.. it was just an example.. the main problem whith the original model is topology..
      • pbacotP
        Thanks, I'll take a look at it.
        • pmolsonP
          pmolson
          Thanks all for your conversation...I am away from work...physically and emotionally right now, but I will try to digest all this first thing in the morning.
          p
          • panixiaP
            panixia
            here is one version with grouped loops to isolate some critical mapping zones..
            the tiling may be better if the topology would be rebuilt to roughly match the desired brick pattern..
            ideally i suppose for better results (whithout considering to move to anexternal mapping app) you should map a strip of tiles at once..
            roof refined.skp
            • pmolsonP
              pmolson
              Ok, I have had a chance to read through all this and I must say.....huh? You guys are over my head. That was to be expected. What I will do is try to recreate what you have done on my own by first defining much of the terminology used and reverse engineer.
              Panixia, that last model you uploaded is exactly what I am trying to do. Thank you! I do not know yet how you achieved it, but you have given me a real life example to work with. Would you be so kind as to private message me to let me know if it is ok if I send you a message?
              Here is the fixed roof that Panixia did in place on my Model. Pretty convincing I think.
              Thanks again to all.
              Paul
              • panixiaP
                panixia
                you can message me if you want or ask here.. i'm happy to help when i have some spare time..
                however i achieved this by making some basic cuts to your mesh to get some rough quad mesh to start with, then refined the subdivision using quadface tools (triangulating also helps to make the texturing work better) and grouped some regions, again quadface loops helped a lot in selecting the faces. finally textured each group with more convenient method in thru paint.. natural mapping for the main straight parts and quad mapping for the curved slices.. just played a bit to orizontally scale them convincingly so the texture don't stretch too much.. this is pretty basic you can achieve better results than this spending more time in it, but maybe if it's intended for mid/long distance use and you don't need close-up views i think it'ok.. hope this can help!
                • panixiaP
                  panixia
                  nice house anyway.. you will render it?
                  • pbacotP
                    That looks really nice now!. I would like to learn more if the discussion continues here. What I could not do (even starting from scratch) is make a roof like that receive quadmesh mapping correctly altogether. I had to use ThruPaint "natural" mode on the sides and quadmesh on the center to get anything like panixia shows. The steep conical section needs to to not only be quad-ready (No more than 4 sides) but be divided horizontally--even though there were no horizontal roof breaks.
                    • ntxdaveN
                      ntxdave
                      OK - would you mind trying this in English so people like me can understand/learn? As examples:
                      Since I do not work with meshes, what is a quad mesh?
                      What is a quadface tool?
                      Is this normal grouping and again what is a quadface tool?
                      What do you mean by quad mapping?
                      As I said, I do not normally work with a mesh and some of this is total Greek to me and I would like to learn.
                      Press F1...thank me later
                      • panixiaP
                        panixia
                        this is not possible as far as i can tell.. i think even if you subdivide the straight part more, somehow the influence of the sloped last ring would distort the mapping..
                        infact this is exactly what i did.. a mix of natural mapping and quad mapping.. maybe my terrible enghlis did't help to understand properly.. πŸ˜„
                        • pmolsonP
                          pmolson
                          ntxdave, I am in much the same boat in not knowing much of the lingo as well as not having learned the plug ins.
                          I hesitated to even ask this mapping question for years because I figured it would open a large can of learning on my part.
                          I don't think it is really fair of us to ask these guys to explain all the methods and define all the terminology for us. kind of like asking an auto mechanic how do i fix my car myself and then saying..whats an engine?
                          I plan to listen to their conversation, investigate what they are saying, try myself, and then ask specific questions.
                          That is not to say that if a step by step tutorial resulted from this conversation that I would not use it. πŸ˜„
                          • panixiaP
                            panixia
                            I apologize for my poor english, but maybe english is your native language, not mine, so it's hard for me explain in english.. moreover i'm not paied to teach you.. so you can be more polite.. just ideas..
                            a quad mesh is a mesh composed only by quad sided poligons not triangles or n-gons.
                            quadface tools is a brilliant thomthom's plugin wich is really useful because let you take advantage of non-planar quads (native sketchup doesn't support conventional quad-modeling tools wich are commonly found in other 3dmodelers like 3dsmax, c4d, blender, and so on)
                            quad mapping is one of the metods found in thru pauint and other tools to apply a texture .. basically the idea is that the texture is distorted and bended to follow the flow of the quad loops..
                            both quadfacetools and thrupaint come with a lot of documentation and examples and you can read furthermore on google.. moreover the basic principles of decent quad modelings are the very same for any software wich supports quads, so you can easily find intersting tutorials done with blender or 3dsmax etc.. the basic principles are all there..
                            • pbacotP
                              Thanks Panixia!
                              I think people say "in english" to mock their own inability with technical terms, compared to the teacher, not meaning to be impolite.
                              • ntxdaveN
                                ntxdave
                                @pbacot said:
                                Thanks Panixia!
                                100% Correct I was not criticizing your "English". He is correct, I just did not understand the technical aspects of what you were saying. While not 100% correct, your grammar was not the problem.......... I just did not understand technically what you were saying. Still not 100% sure but your explanation is moving me in the right direction. β˜€
                                I have been using SketchUp for a little over a year now but this type of stuff has not been needed for what I do. I have not used any other 3d modeling tools nor do I have an engineering background. I usually ask questions on this forum just to try to learn and understand the tools/environment. I will go off and do some more studying............ πŸ˜„
                                • panixiaP
                                  panixia
                                  no problem at all.. just to better introduce you to the quad based approach, keep in mind that the basic concept is to build every mesh out of quad (actually they can just be two triangles with the shared edge marked as a "diagonal" for non-planar quads), thus those quads form (at least in simple quad based mesh like this) a sort of grid whit "row and columns" so it's easier to "navigate" the mesh you may easiliy select loops of edges or quadfaces and grow/shrink selections, also you can control the density of quad and all of this can be used to predict how a texture will be distorted if mapped with "quad" criterium. also a quad based approachh is more suitable for subdivision modeling and rendering with displacement.. when the loops of quads inersect themselves and flow one innto anoter or forms corners you have what it's called a "pole" and usually those poles are used to controll the pinch and the flow of organic meshes.. but that's another whole different level..
                                  • pmolsonP
                                    pmolson
                                    Unfortunately, no I will not render. This particular client likes the sketchy feel and I make them into little movies like this.
                                    • panixiaP
                                      panixia
                                      nice vid! and nice house..
                                      • ntxdaveN
                                        ntxdave
                                        +1
                                        Many things in your video that I need to learn (like how to do the terrain with a model like this). πŸ‘ πŸ‘
                                        • 2 / 2
