    Imported jpeg turns out white when rendering
    renderpluginsextensions
    15 Posts 7 Posters 2.4k Views 7 Watching
      LARV
      I exported an illustrator file to jpeg and imported it into Sketchup. It looks ok on the artboard (pic 1), but when rendering the image is white (pic 2).
      Can someone explain what I´m doing wrong?
      I have the SU Default visop set.
      • omiKronO Offline
        omiKron
        Try to import the jpeg in the diffuse layer of your material again. I get the same thing on some trees inside a scene where it doesn't import automatically the png image for the leaves and I get a brown squared leaf. See if works.
        • V Offline
          valerostudio
          If you imported as IMAGE, try exploding it before rendering.
            LARV
            How do I import in the diffuse layer? That was above my head. I only know the standard import function.
              LARV
              Thanks, but that made no differece.
                LARV
                I just tried importing a previously rendered vray jpeg as image and it worked fine. Frustrating problem this.
                  LARV
                  I´m sorry about the "spamming" in this post but I´m really trying to learn this.
                  I now tried unmarking the sunlight and adding a sphere light as light source. The image is starting to show. I believe the sun in the previous render is too bright for the image. It struck me that, if this is true, if I could make the image not absorb the sunlight it might turn out OK. Or even better if I could control how much light the image should absorb.
                  Is that possible?
                  • andybotA Offline
                    andybot
                    if the background of your image is pure white - it's probably just getting overbright and the antialiasing is washing out the lines. You can try adjusting the image in photoshop to be a slightly gray background instead of white. Vray (and most rendering engines) don't deal well with pure white.
                    • dkendigD Offline
                      dkendig
                      PROTIP: If you ever find that you need to charge a client a few extra hours because they've been naughty, be sure to use 100% white in at least one material while rendering.
                      Devin Kendig
                      Developer
                      • omiKronO Offline
                        omiKron
                        In Vray material editor, find your texture and on the right you get the parameters to edit. In Diffuse, click M.
                          LARV
                          I tried importing the map as a .PSD and the result turned out somewhat better (with the image being much larger too in size). It wasn´t great, though, and not up to the task of being used as an infromative map. I´ll leave this for now. Thanks!
                          I did that, but there was no difference. Thanks anyway!
                          • 3dita3 Offline
                            3dita
                            LOL.. Care to elaborate?
                            3dita - Digital Visual Motion
                            • dkendigD Offline
                              dkendig
                              sure
                              Do not apply perfectly white or very close to white materials to a majority of the objects in the scene, as this will cause excessive render times. This is because the amount of reflected light in the scene will decrease very gradually and the light cache will have to trace longer paths. Also avoid materials that have one of their RGB components set to maximum (255) or above.
                              http://docs.chaosgroup.com/display/VRAY2SKETCHUP/Light+Cache#LightCache-Notes
                              Devin Kendig
                              Developer
                              • TedVitale_CGT Offline
                                TedVitale_CG
                                Dont import the map as a .PSD. Open the .JPEG in Photoshop, darken the white area it to a grey tone and save a new .JPEG. Import that new .JPEG and place it in the scene.
                                Ted Vitale
                                Owner | Creative Director
                                http://www.voxl.vision
                                • V Offline
                                  valerostudio
                                  Just because you can import a PSD into SU doesnt mean you should. I have had awful results with this.
