    [Plugin] Originate component axes
    15 Posts 11 Posters 14.0k Views 11 Watching
    • GaieusG
      Prefect, this is exactly what I meant (and nested components are not affected, exactly as I wished).
      Thank you very much, TIG! 😍
      (Note to myself and others: the plugin uses the original world axes so if one moves the axes elsewhere, do not be surprised)
      I'd have a question though. Now I have a bunch of lines of code: what do I need to do to have a plugin from those?
      And thanks Tim as well of course - but I did not go to try after this 😄
      • mitcorbM
        mitcorb
        That's ok, Csaba. If I were TIG, I would have done the same thing as he. 😆
        EDIT: only, it would have taken me a week to get back to you.
        • PixeroP
          Pixero
          Funny, just today I was needing the same thing.
          • GaieusG
            Thanks very much again, TIG!!!
            • simon le bonS
              simon le bon
              Hi Gaï, TIG, tim, Jan, 😄
              Can someone shows in what sort of case this new plugin is (very) useful? Excuse me but my mind is dry to imagine it 😕
              😎 simon
              PS: However, thank you TIG for this one and how many others+++
              • mitcorbM
                mitcorb
                Hi, simon:
                What I understand is this plugin will place the axes/origin of numerous components at the global axes origin of the model space. Gaieus can explain his purpose better than me. I was just cruising the Plugins Index in response to his request.
                • C
                  chrisjk
                  As long as components haven't been purged from model, it would make it very easy to replace stuff that has been deleted from the working model - sort of paste in place for things not on the clipboard.
                  • demD
                    dem
                    It's great plugin!
                    But unfortunately it do not work for proper crop orientation of "make unique texture" function(
                      jaceguay
                      There is a way to make it work on any components and groups in the model not only the top level ones?
                      • john2J
                        john2
                        I would like it to work for all nested components within a component. So if we use the co nand on one component, all the nested components should also get originated axes. Currently it works for a single component. We have to manually select the nested components every tome within a component to make this plugin work.
                        Sketchup Make 2017 (64-bit), Vray 4.0 , Windows 10 – 64 bit, corei7-8750H, 16GB RAM, Nvidia GeForce GTX 1050Ti 4GB
                        • josephkim626J
                          josephkim626
                          In addition to making this work on groups as well as the components, It should have option to work on all nested groups and components?
                          Also, perhaps way to choose which axis to change to. Not limited to the world only, but perhaps to the axis of the currently active component or group?
                          I hope this makes sense.
                          • panixiaP
                            panixia
                            Is there a similar plugin to force align ALL selected component/groups AND nested subgroups/subcomponents local Y+ axes to world Z+?
                            That would be extremely handy when preparing models for game engines and similar stuff..
                            I'm searching everywhere with no luck.. 😢
