    [Plugin] GKWare Stair Maker
    49 Posts 13 Posters 16.3k Views 13 Watching
    • KrisidiousK
      Krisidious
      You've been a busy bee... looks great.
      By: Kristoff Rand
      • G
        Garry K
        Here is an interesting side effect that I didn't expect. Here I put in a -20 mm progressive flare on the last 8 treads and it works - providing you check "Flare Sawtooth Face".
        Stair with negative progressive flare
        • G
          Garry K
          Stair Maker version 1.0.20 is now available for download from my web site.
          CabMaker32.com
          Testing would be appreciated. The new plugin will be uploaded to the Extension Warehouse and the Plugin Store later this week.
          Anyone who wants to run the trial - but has timed out please email me and I will reset your accounts on my web site. gkernan@telus.net
          • KrisidiousK
            Krisidious
            I'll get the new version...
            By: Kristoff Rand
            • G
              Garry K
              Stair Maker plugin version 1.0.21 is now available.
              • G
                Garry K
                I've now added straight stairs to stair maker.
                Here is one with what we call a foot.
                The straight stair is available with flares.
                I'm Just finishing off with testing.
                Straight Stair
                • B
                  BMoffa
                  Great. So now you need to be able to combine a spiral and straight which is what I need right now--A 180 spiral then straight to the top).
                  • G
                    Garry K
                    Yes Robert - that is the plan.
                    However, Next will be quarter and half landings.
                    Then I think I should add posts and balusters.
                    Straight treads combined with curved need the following options.
                    1. straight treads at top of inside stringer
                    2. straight treads at bottom of inside stringer
                    3. straight treads at top of outside stringer
                    4. straight treads at bottom of outside stringer
                    Also need to look at notching points - where stair goes from beside a wall and then opens up.
                    • G
                      Garry K
                      Stair Maker plugin version 1.0.22 is now available.
                      • N
                        Nick1
                        I no longer carry credit cards and don't have any accounts like Paypal. I can send you a money order for $50.00 whcih is the price. But where can I mail it to?
                        Thanks again for your work.
                        • G
                          Garry K
                          Nick1
                          I've sent you a private message.
                          • G
                            Garry K
                            Version 1.0.23 is now available.
                            • pbacotP
                              Thanks Garry. Impressive plugins!
                              • E
                                Esense3d
                                Hello Garry
                                First Your server is on Limit
                                I cant buy your great Stair plugin
                                but i can translate for you to German
                                Need little help with the following Strings
                                What exactly does:
                                Progressive Flare
                                Flare Count
                                The current translation is complete except for these strings
                                Greetings from Swiss
                                Roland F
                                German File
                                • G
                                  Garry K
                                  Roland,
                                  Send me your user ID and I will extend your trial.
                                  This is a progressive flare - where the treads at the center get progressively larger.
                                    db11
                                    Just wanted to register my satisfaction with this plugin. I bought it to help me generate a set of half-spiral stairs for a client project.
                                    The plugin itself is well-done and works flawlessly. But what really impressed me is how well Garry K supports it. He has been tremendously helpful in showing me how to generate output from it that it was not specifically designed to do. (in this case a single central steel stringer)
                                    And with every query —and there were several in my case!— his replies were prompt and on-point. Really a pleasure to deal with.
                                    Highly recommended to anyone who needs to resolve a spiral stair conundrum.
                                    Doug
                                    • G
                                      Garry K
                                      Here are 2 more 2D stair videos.
                                      • KrisidiousK
                                        Krisidious
                                        A man after my own heart... Curved Stairs Pro Style...
                                        By: Kristoff Rand
                                        • G
                                          Garry K
                                          Here are a few more videos:
                                          Flattening stringers for machining - CNC or by hand.
                                          Adding finished bottom to stair.
                                          Second method for adding a finished bottom.
                                          • G
                                            Garry K
                                            New version 1.0.32 now available for download
                                            • Version number now shows up on title bar of web dialog
                                            • Now uses same License strategy as cabmaker
                                            • Check license now first deletes old license and then updates license
                                            • Has preferred setting for users who have license issues
                                            With your input, this post could be even better šŸ’—
                                            • 2 / 3
