    [Plugin] GKWare Stair Maker
    49 Posts 13 Posters 14.8k Views 13 Watching
      Garry K
      Stair Maker plugin version 1.0.21 is now available.
        Garry K
        I've now added straight stairs to stair maker.
        Here is one with what we call a foot.
        The straight stair is available with flares.
        I'm Just finishing off with testing.
        Straight Stair
          BMoffa
          Great. So now you need to be able to combine a spiral and straight which is what I need right now--A 180 spiral then straight to the top).
            Garry K
            Yes Robert - that is the plan.
            However, Next will be quarter and half landings.
            Then I think I should add posts and balusters.
            Straight treads combined with curved need the following options.
            1. straight treads at top of inside stringer
            2. straight treads at bottom of inside stringer
            3. straight treads at top of outside stringer
            4. straight treads at bottom of outside stringer
            Also need to look at notching points - where stair goes from beside a wall and then opens up.
              Garry K
              Stair Maker plugin version 1.0.22 is now available.
              • N Offline
                Nick1
                I no longer carry credit cards and don't have any accounts like Paypal. I can send you a money order for $50.00 whcih is the price. But where can I mail it to?
                Thanks again for your work.
                  Garry K
                  Nick1
                  I've sent you a private message.
                    Garry K
                    Version 1.0.23 is now available.
                    • pbacotP Offline
                      Thanks Garry. Impressive plugins!
                      • E Offline
                        Esense3d
                        Hello Garry
                        First Your server is on Limit
                        I cant buy your great Stair plugin
                        but i can translate for you to German
                        Need little help with the following Strings
                        What exactly does:
                        Progressive Flare
                        Flare Count
                        The current translation is complete except for these strings
                        Greetings from Swiss
                        Roland F
                        German File
                          Garry K
                          Roland,
                          Send me your user ID and I will extend your trial.
                          This is a progressive flare - where the treads at the center get progressively larger.
                            db11
                            Just wanted to register my satisfaction with this plugin. I bought it to help me generate a set of half-spiral stairs for a client project.
                            The plugin itself is well-done and works flawlessly. But what really impressed me is how well Garry K supports it. He has been tremendously helpful in showing me how to generate output from it that it was not specifically designed to do. (in this case a single central steel stringer)
                            And with every query —and there were several in my case!— his replies were prompt and on-point. Really a pleasure to deal with.
                            Highly recommended to anyone who needs to resolve a spiral stair conundrum.
                            Doug
                              Garry K
                              Here are 2 more 2D stair videos.
                              • KrisidiousK Offline
                                Krisidious
                                A man after my own heart... Curved Stairs Pro Style...
                                By: Kristoff Rand
                                  Garry K
                                  Here are a few more videos:
                                  Flattening stringers for machining - CNC or by hand.
                                  Adding finished bottom to stair.
                                  Second method for adding a finished bottom.
                                    Garry K
                                    New version 1.0.32 now available for download
                                    • Version number now shows up on title bar of web dialog
                                    • Now uses same License strategy as cabmaker
                                    • Check license now first deletes old license and then updates license
                                    • Has preferred setting for users who have license issues
                                      garystan
                                      Sketchucation :
                                                       I'm not sure HOW to install this add-on.  I'm running Sketchup 8.    garystan
                                        Garry K
                                        Log on to my website and email me from there. I'll walk you through it.
                                          garystan
                                          Hi everybody :
                                                             I tried running Stair Maker, Version 1.0.23, and I noticed that it didn't have the OKAY button.  Suggestions ?
        garystan
                                            Garry K
                                            Stair Maker's current version is 1.0.32
                                            Are you sure you installed 1.0.23
                                            What does it say at the top of the form?
                                            With your input, this post could be even better šŸ’—
                                            • 2 / 3
