    [Plugin] GKWare Stair Maker
    49 Posts 13 Posters 16.3k Views 13 Watching
    • G
      Garry K
      I'm adding a 2D to 3D stair converter to Stair Maker Suite.
      The input box pops up when you press the 2D button. You adjust the total rise, number of risers etc. and click OK. The tread number resets to the first tread.
      Then you select the edge at the front of the tread (or edges) and select the tread face and press the 3D button (or use a hot key - mine is set to Shift 'T').
      Start at the bottom of the stair and work your way up to the top. The Tread number automatically increments and the 2D face reverses (to indicate that you have processed that tread).
      Please note that the first and last tread/riser are handled differently than the middle ones.
      You must temporarily add a few lines at the bottom and at the top of the stair. At the bottom this tells the 3D button which lines to use for the first nosing. This is especially needed for volutes etc. The plugin knows when you have reached the top of the stair as the tread number will equal the number of risers. The extra lines at the top of the stair tell the plugin how to finish off the top riser.
      Here are some examples of different 2D stairs
      • G
        Garry K
        I'm back to adding new features about once a month.
        I'm hoping to add these features next version.
        1. Add partial riser for open riser stair - so that the gap is no larger than 'Maximum Gap'
        2. Allow riser to sit on tread (marble etc).
        3. Modern Rake rail - second rail profile where there are no spindles and instead there are additional horizontal rails every 100 mm (or less)
        4. Modern Glass panel instead of spindles
        We will use the new 'Maximum Gap' rule (defaults to 100mm or 4"), for opening of partial risers and spacing for rake rails and Modern Glass panels. Here is the new 'Codes and Rules' page
        The new 'Stair Configuration' page contains 2 check boxes which are 'Partial Riser', and 'Risers Sit On Treads' as well as 2 drop downs which are 'Spindle Options' and 'Spinde Style'
        Here is an example of a stair that is flared and has 'Open Riser' and 'Partial Riser' checked.
        • B
          BMoffa
          I have a requirement for a staircase that begins as a 180 degree spiral within a 10-12 foot space for the first 6 feet (approximate) of rise. The steps then continue as a straight run to the top--approximately another 5 feet. Is it possible to do this with Stair Maker?
          Also, I haven't seen anything regarding pricing.
          • G
            Garry K
            You can check out prices on my web site. CabMaker32.com
            You must log in to see prices.
            The web dialog currently will not create a stair with curved and straight steps. A future version will add this capability.
            There is a 2D to 3D stair conversion utility that will create treads and risers based on a 2D drawing. You could use the Stair Maker to create the curved portion of the stair and use the 2D to 3D utility to create the rest of the treads.
            • KrisidiousK
              Krisidious
              And it rocks...
              By: Kristoff Rand
              • G
                Garry K
                I've finished testing version 1.0.20 of the Stair Maker plugin Suite.
                I've fixed a number of issues and added new features.
                1. Changed the web dialog
                  the enter key now acts like the OK button.
                  the escape key now acts like the cancel button.
                2. Fixed first time registration bug.
                3. Web dialog is no longer resizeable
                4. Added ‘Open Style Sheet’ drop down. You can now store and retrieve style sheets.
                5. Changed ‘Save As Default’ check box to ‘Save Style Sheet’ drop down. You can now save current style as a named style sheet.
                6. Issue with first nosing. Fixed
                7. Added feature risers now have choice to sit on tread - stone risers etc...
                8. Added feature for partial risers with open riser stair
                9. Added featuer - you can now specifiy side nosing for tread independently from front of tread nosing.
                10. Back of tread was not bullnosed for open riser progressive flare. Fixed
                11. Added checks
                  Web Dialog data entry now pops up message for invalid data entry
                  Tread dado must be less than tread thickness
                  Tread bullnose cannot be negative
                  Tread nosing cannot be negative
                  Tread side nosing cannot be negative
                  Riser nosing cannot be greater than tread nosing
                  Riser nosing cannot be negative
                  Tread bullnose cannot be larger than tread nosing
                12. Riser boards now work with progressive flare.
                13. Updated translation files
                14. Flared risers have stringer dado problem. Fixed
                15. Housed stringer at front of stair not calculating properly. Fixed
                16. Flared treads greater than 65mm had problems. You can now flare tight radius stairs up to around 150 mm.
                Sawtooth 300 mm radius with 150 mm Flare
                Housed 300 mm radius with 250 mm Flare
                • KrisidiousK
                  Krisidious
                  You've been a busy bee... looks great.
                  By: Kristoff Rand
                  • G
                    Garry K
                    Here is an interesting side effect that I didn't expect. Here I put in a -20 mm progressive flare on the last 8 treads and it works - providing you check "Flare Sawtooth Face".
                    Stair with negative progressive flare
                    • G
                      Garry K
                      Stair Maker version 1.0.20 is now available for download from my web site.
                      CabMaker32.com
                      Testing would be appreciated. The new plugin will be uploaded to the Extension Warehouse and the Plugin Store later this week.
                      Anyone who wants to run the trial - but has timed out please email me and I will reset your accounts on my web site. gkernan@telus.net
                      • KrisidiousK
                        Krisidious
                        I'll get the new version...
                        By: Kristoff Rand
                        • G
                          Garry K
                          Stair Maker plugin version 1.0.21 is now available.
                          • G
                            Garry K
                            I've now added straight stairs to stair maker.
                            Here is one with what we call a foot.
                            The straight stair is available with flares.
                            I'm Just finishing off with testing.
                            Straight Stair
                            • B
                              BMoffa
                              Great. So now you need to be able to combine a spiral and straight which is what I need right now--A 180 spiral then straight to the top).
                              • G
                                Garry K
                                Yes Robert - that is the plan.
                                However, Next will be quarter and half landings.
                                Then I think I should add posts and balusters.
                                Straight treads combined with curved need the following options.
                                1. straight treads at top of inside stringer
                                2. straight treads at bottom of inside stringer
                                3. straight treads at top of outside stringer
                                4. straight treads at bottom of outside stringer
                                Also need to look at notching points - where stair goes from beside a wall and then opens up.
                                • G
                                  Garry K
                                  Stair Maker plugin version 1.0.22 is now available.
                                  • N
                                    Nick1
                                    I no longer carry credit cards and don't have any accounts like Paypal. I can send you a money order for $50.00 whcih is the price. But where can I mail it to?
                                    Thanks again for your work.
                                    • G
                                      Garry K
                                      Nick1
                                      I've sent you a private message.
                                      • G
                                        Garry K
                                        Version 1.0.23 is now available.
                                        • pbacotP
                                          Thanks Garry. Impressive plugins!
                                          • E
                                            Esense3d
                                            Hello Garry
                                            First Your server is on Limit
                                            I cant buy your great Stair plugin
                                            but i can translate for you to German
                                            Need little help with the following Strings
                                            What exactly does:
                                            Progressive Flare
                                            Flare Count
                                            The current translation is complete except for these strings
                                            Greetings from Swiss
                                            Roland F
                                            German File
                                            • 2 / 3
