    [Plugin] GKWare Stair Maker
    49 Posts 13 Posters 15.7k Views 13 Watching
    • KrisidiousK Offline
      Krisidious
      @garry k said:
      There is a 2D to 3D stair conversion utility that will create treads and risers based on a 2D drawing. You could use the Stair Maker to create the curved portion of the stair and use the 2D to 3D utility to create the rest of the treads.
      And it rocks...
      By: Kristoff Rand
        Garry K
        I've finished testing version 1.0.20 of the Stair Maker plugin Suite.
        I've fixed a number of issues and added new features.
        1. Changed the web dialog
          the enter key now acts like the OK button.
          the escape key now acts like the cancel button.
        2. Fixed first time registration bug.
        3. Web dialog is no longer resizeable
        4. Added ‘Open Style Sheet’ drop down. You can now store and retrieve style sheets.
        5. Changed ‘Save As Default’ check box to ‘Save Style Sheet’ drop down. You can now save current style as a named style sheet.
        6. Issue with first nosing. Fixed
        7. Added feature risers now have choice to sit on tread - stone risers etc...
        8. Added feature for partial risers with open riser stair
        9. Added featuer - you can now specifiy side nosing for tread independently from front of tread nosing.
        10. Back of tread was not bullnosed for open riser progressive flare. Fixed
        11. Added checks
          Web Dialog data entry now pops up message for invalid data entry
          Tread dado must be less than tread thickness
          Tread bullnose cannot be negative
          Tread nosing cannot be negative
          Tread side nosing cannot be negative
          Riser nosing cannot be greater than tread nosing
          Riser nosing cannot be negative
          Tread bullnose cannot be larger than tread nosing
        12. Riser boards now work with progressive flare.
        13. Updated translation files
        14. Flared risers have stringer dado problem. Fixed
        15. Housed stringer at front of stair not calculating properly. Fixed
        16. Flared treads greater than 65mm had problems. You can now flare tight radius stairs up to around 150 mm.
        Sawtooth 300 mm radius with 150 mm Flare
        Housed 300 mm radius with 250 mm Flare
          Krisidious
          You've been a busy bee... looks great.
          By: Kristoff Rand
            Garry K
            Here is an interesting side effect that I didn't expect. Here I put in a -20 mm progressive flare on the last 8 treads and it works - providing you check "Flare Sawtooth Face".
            Stair with negative progressive flare
              Garry K
              Stair Maker version 1.0.20 is now available for download from my web site.
              CabMaker32.com
              Testing would be appreciated. The new plugin will be uploaded to the Extension Warehouse and the Plugin Store later this week.
              Anyone who wants to run the trial - but has timed out please email me and I will reset your accounts on my web site. gkernan@telus.net
                Krisidious
                I'll get the new version...
                By: Kristoff Rand
                  Garry K
                  Stair Maker plugin version 1.0.21 is now available.
                    Garry K
                    I've now added straight stairs to stair maker.
                    Here is one with what we call a foot.
                    The straight stair is available with flares.
                    I'm Just finishing off with testing.
                    Straight Stair
                      BMoffa
                      Great. So now you need to be able to combine a spiral and straight which is what I need right now--A 180 spiral then straight to the top).
                        Garry K
                        Yes Robert - that is the plan.
                        However, Next will be quarter and half landings.
                        Then I think I should add posts and balusters.
                        Straight treads combined with curved need the following options.
                        1. straight treads at top of inside stringer
                        2. straight treads at bottom of inside stringer
                        3. straight treads at top of outside stringer
                        4. straight treads at bottom of outside stringer
                        Also need to look at notching points - where stair goes from beside a wall and then opens up.
                          Garry K
                          Stair Maker plugin version 1.0.22 is now available.
                          • N Offline
                            Nick1
                            I no longer carry credit cards and don't have any accounts like Paypal. I can send you a money order for $50.00 whcih is the price. But where can I mail it to?
                            Thanks again for your work.
                              Garry K
                              Nick1
                              I've sent you a private message.
                                Garry K
                                Version 1.0.23 is now available.
                                • pbacotP Offline
                                  Thanks Garry. Impressive plugins!
                                  • E Offline
                                    Esense3d
                                    Hello Garry
                                    First Your server is on Limit
                                    I cant buy your great Stair plugin
                                    but i can translate for you to German
                                    Need little help with the following Strings
                                    What exactly does:
                                    Progressive Flare
                                    Flare Count
                                    The current translation is complete except for these strings
                                    Greetings from Swiss
                                    Roland F
                                    German File
                                      Garry K
                                      Roland,
                                      Send me your user ID and I will extend your trial.
                                      This is a progressive flare - where the treads at the center get progressively larger.
                                        db11
                                        Just wanted to register my satisfaction with this plugin. I bought it to help me generate a set of half-spiral stairs for a client project.
                                        The plugin itself is well-done and works flawlessly. But what really impressed me is how well Garry K supports it. He has been tremendously helpful in showing me how to generate output from it that it was not specifically designed to do. (in this case a single central steel stringer)
                                        And with every query —and there were several in my case!— his replies were prompt and on-point. Really a pleasure to deal with.
                                        Highly recommended to anyone who needs to resolve a spiral stair conundrum.
                                        Doug
                                          Garry K
                                          Here are 2 more 2D stair videos.
                                            Krisidious
                                            A man after my own heart... Curved Stairs Pro Style...
                                            By: Kristoff Rand
                                            • 2 / 3
