    SketchUcation 3D Viewer (formerly the '[ignore]' thread)
    276 Posts 19 Posters 13.0k Views 19 Watching
      I does. ๐Ÿ˜„
        [sw:38o7uf7x]1MQFwAj2Gp6EJ6d[/sw:38o7uf7x]
        another round of testing...
        today we are adding specularity so you might see failed displays, weird display etc...
          [sw:ox9sdqni]eGLuZQvKUOsWWbk[/sw:ox9sdqni]
          • BoxB Offline
            I think the most brilliant thing about this viewer is that it works with the 'click mouse wheel orbit' that we all try to use on web pages.
              [sw:1lua4n1v]0xRecCKVVHAAR6P[/sw:1lua4n1v]
                driven
                getting there...
                have you tried a LiveIvy skp yet, some of the leaves don't work when I run them in mrdoob
                  @john
                  we are tweaking some transparency settings...
                  [sw:e77ftaiq]AZgxmuMDyVyjfus[/sw:e77ftaiq]
                  ...and
                  [sw:e77ftaiq]hzAY4WUuoQDdlvB[/sw:e77ftaiq]
                  just a case of dialling it in.
                    Sorry...
                    That was a dumb idea by me
                    We have yet to implement saving of transparency in the editor backend. You can set it but not yet save the setting.
                      [sw:1yyfbcir]DyUX11ZLF5yHrIe[/sw:1yyfbcir]
                        Cool viewer! โ˜€
                        You are making a new Sketchfab ?
                          Not really. Ours is focused around SU and leveraging elements in SU to be advantageous in the viewer.
                          • BoxB Offline
                            A little tester.
                            [sw:lxkjkfhq]9s0gUfnBqzhj9xW[/sw:lxkjkfhq]
                            • tademaT Offline
                              tadema
                              Imagine that on a full sized model like Tunstall Court ect ๐Ÿ˜ฒ
                              John
                                Gรกbor
                                @box said:
                                A little tester.
                                Nice. ๐Ÿ˜„ Now you can test the saving of the material parameters as well. ๐Ÿ˜„
                                • BoxB Offline
                                  Yep that works.
                                    Gรกbor
                                    @box said:
                                    Yep that works.
                                    ๐Ÿ‘
                                    (Although it looked better before ๐Ÿ˜„ )
                                    • BoxB Offline
                                      I just changed it so it was obvious. I might have a fiddle when I have time to make it look nice.
                                      I must say, if you can get the swipe to work this would be a godsend on mobile devices. For me it actually works better and faster on my phone than this old laptop I'm stuck with.
                                        Gรกbor
                                        ๐Ÿ‘
                                        Will see..... ๐Ÿ˜‰
                                          Conductor is missing on the top view! ๐Ÿ˜‰
                                            [sw:2nmm7lj7]UiTqF1eYwKc9q5x[/sw:2nmm7lj7]
                                            Specular Tests with various lighting settings
                                            • 13
                                            • 14
                                            • 8 / 14
