    Honeycomb lamp
    113 Posts 18 Posters 31.0k Views 18 Watching
      @Oli
      Have you updated your Safari version ?
      All of the newest main-stream browsers now have WebGL abilities by default etc...
        It's working on modern Safari browsers as Driven has tested.
        Must be your older Mac causing the issue.
        • olisheaO Offline
          olishea
          So that's what the Software Update button does?
          Haven't upgraded my OS either! 😆
          oli
            Gábor
            As TIG said these error messages show that WebGL is either not enabled or the browser is not WebGL compatible. Upgrade to a WebGL compatible one.
              @Oli
              Time to ditch that machine and join the 21st century.
              • BoxB Offline
                Hmmm Oli, reluctant to upgrade, using an old old version of software,.... are you fighting the urge to wear a beret and have a hankering for hanging strings of garlic about your person?
                • Bryan KB Offline
                  That's very cool.
                  What program are you using to create it?
                  • john2J Offline
                    john2
                    Reminds me of a morphed rib cage. REally amazing. 👍 👍 I guess, you are
                    making a raw simple solid form using simple sketchup skills,
                    then making a wire mesh of it
                    then extruding it along edges
                    applying subdivide and smooth. Right?
                    car games roblox
                    Sketchup Make 2017 (64-bit), Vray 4.0 , Windows 10 – 64 bit, corei7-8750H, 16GB RAM, Nvidia GeForce GTX 1050Ti 4GB
                      Wrong.
                      • olisheaO Offline
                        olishea
                        I upgraded my OSX and updated everything. Still can't see the animation thingy from Rich. Strange.
                        oli
                          na-na-nana-na
                            @Oli
                            Ensure your Safari is up to date, then empty its cache.
                            Also check that its options now include WebGL set enabled...
                            Then retry...
                            • olisheaO Offline
                              olishea
                              Has my computer been hacked or something? When I went to the app store it had someone else's email address! 😆
                              Allow WebGL is enabled but still nothing. I don't get the error messages any more, the animation thing just wont start although I can see the buttons.
                              oli
                              • olisheaO Offline
                                olishea
                                oh wait, i can see it now! Is it supposed to move or anything or is just a preview of the model that you can rotate?
                                oli
                                  Gábor
                                  @Oli,
                                  Did you try to drag your mouse over he area? After clicking the placeholder it starts with an empty area but when you click and drag on it it should show the model.
                                  EDIT: We were writing parallel ... 😄
                                  • olisheaO Offline
                                    olishea
                                    Yes that's what I did....works now.
                                    I was expecting it to morph, or animate.....I dunno, it's a cool model viewer though!
                                    oli
                                    • olisheaO Offline
                                      olishea
                                      is there a poly limit for that model viewer? would something like this work?
                                      oli
                                        Send it to me and I'll test
                                        • olisheaO Offline
                                          olishea
                                          Ok...just need to find the model as I have about 10 iterations of it saved in different file formats! 😆
                                          oli
                                          • john2J Offline
                                            john2
                                            @rich o brien said:
                                            na-na-nana-na
                                            So, can you post a tutorial that explains making of these amazing stuff for organic novices like me ❓ Same goes for you oli. A step by step tutorial.
                                            • 4 / 6
